C5 to C6 Differential swap...DIY write-up????
I've come to the decision of swapping in a C5 diff in my 05 C6. A built 06up diff is a little pricey right now and I need my car up and running soon. Fontana Speedway is open on Halloween day and I want to run down the 1/4 instead of the 1/8 mile for a change.
Does anyone know if there's a write-up for this type of swap. I want to know exactly what is involved to get it done. I've read different threads on this subject but nothing detailed. I know I need to weld in a custom bracket to the cradle in order to bolt up the C5 diff but where and how thick does the plate need to be. I was told Cartek has the special brackets but I didn't see them on their site.
If anyone can post some instructions/pictures or provide a link to some, I'd really appreciate it.
I'm sure i'm not the only CF member who wants to do this swap.
I figured maybe someone had maybe done a writeup on it on how everything came together.
My shop did it for me - you have to call Cartek and tell them you want the conversion brackets. Takes a little time to get them so order now, it's less than $300 for the bracketry. You could measure and make it yourself I guess...but my shop said for that price just buy the brackets they've got he experience in making it the right sizes to make it work.
It's next to impossible to get any pictures that will mean anything without a lift. But with the brackets it's easy to understand what's going on.
There is an aluminum plate that welds to the cradle under the new diff...that plate has bolt holes in it, and you pass the bolts through it and the spacer bracket into the factory mounts in the C5 diff. You also have to grind down some of the cooling fins on the C5 diff a little to fit over the C6 cradle.
You don't use your C6 side covers with the integrated forward brackets anymore as the bolt holes on the C5 diff don't all line up.. According to Spin, some guys have modded their side covers to work, but I didn't want to go through the ha$$le on my setup.
My main reason for going the C5 route is that the diffs are so much cheaper than the upgraded C6 diffs (you can get 2 C5's for the price of 1 C6) - and if you drag race as much as I do I need to be prepared to replace the diff.
I guess the only thing I'm concerned about is if the Cartek brackets come which some type of template or instructions so I know exactly where to weld the bracket. I would hate to weld in a bracket and find out it's not aligned right.
So if i understand you right...all I need to do is weld in the Cartek brackets to the cradle and grind off a few cooling fins for clearance?
Sounds like a few hrs of fun. If I remember i'll be sure and take plenty of pics for those future gear heads looking to do this very same mod.
Thanks for the input Joe.
Since I didn't do the install myself I'm talking only from my observations and it's hard to see when it's all installed....your picture how-to would be a welcome addition for the folks with 05 diffs!!
You got it right! You'll see where to weld the plate, it's pretty obvious when you look at it. I also think, but am not positive, that the plate has slots for a bit of fudge factor.
That's correct. I think it took a little over a week to get them and you're a couple of extra days via UPS than me so I'd call Monday if I was you and you want to make your Halloween deadline...don't forget you have to break in your new rear with not only miles but heat cycles.
I have a 3.42 diff (A4) in my wrecked 2000 C5 along with a forged LS3, and I plan to put the motor and diff in my '05 Z51 M6 C6 (3.73). I did notice some people are using the C6 Z06 diff with the larger ring gear in their C6 with the later transmission tailhousing.
Since I have the C5 diff (probably should drop it off for a rebuild) and a supercharged LS3 could use the lower ratio, maybe that's the better path for me. Or is the Z06 diff the right path? Hmm...
BTW. If you snap off the existing mainshaft like I did you have to replace it anyway.
But the C5 swap is much cheaper than the C6Z swap and I don't think you can get any 3.90 or 4.10 gears for the c6Z diff. Those that have gears never want to go back. Well a least I would never want to go back.
Well I called Cartek today. Looks like they do the modification to the cradle there. They said they don't sell the brackets only. Looks like that plan is out.
Does anyone have pics of the bracket/plate they used or a pic of the modified cradle?
Joe,
Would you by any chance know the thickness of the plate they welded in your cradle? Looks like i'll have to do this myself.
Joe,
Joe,
Joe,
Did you speak to Max? Did you tell them you are from the Forum?
I'll see if I can get some pics and measurments for you, though it's hard to see. I'll also see if my shop can help.
Hmmm. I don't think I am special, though my shop does have a relationship with them....and I bought it from them.
Thanks Joe. Any help would be greatly appreciated. If I can get my hands on some pics or some measurements, i'm sure i can pull this off with no problem.
