Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Tech/Performance
LS2 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Callaway
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-17-2009, 06:38 PM   #1
chad.orourke
CF Member
Default Dealer giving me warranty trouble-RESOLVED
Car:
2007 Corvette M6 Z51
Mods:
Kooks long tube headers
Billy-Boat bi0mode exhaust
Installation Date:
2 months ago
Problem:
So I was recently on a back road and suddenly heard a clicking noise coming from the engine compartment. When I lifted the hood there was no visible problem but when you hit the accelerator pedal there is an audible clicking noise. To me it sounds like there is a rock in the plastic intake, if you can imagine what that sounds like. It is VERY noticeable on the drivers side, and barely audible on the passenger side. To me this means valve-train or intake. I checked for obvious things like something touching but alas it was internal.
Note* I have never heard what a spun bearing or a bent rod sounds like in a car.
So after the hobby mechanic inspection was complete I drove it in to the dealership to get it looked at. A day goes by and the dealership calls back and says they cannot work on the car because it has been modified, which I told the dealership service attendant up front. According to them they cannot even touch it because their engineering department says it has been modded, which means they cannot even tell me what is wrong with the car.
So what I am left with is a car that they cant tell me what is wrong with it because engineering said no, but how can they deny the warranty when they don't even know what the problem is?
I cant get the car diagnosed to even see if the problem is warranty related...PLEASE HELP
-Chad
UPDATE
Audio and video of the interesting problem can be seen here at you tube.
http://www.youtube.com/watch?v=O5chV3KOGuk
chad.orourke is offline   Reply With Quote
Old 09-17-2009, 06:39 PM   #2
chad.orourke
CF Member
I will post a video with sound of the problem in the coming days.
Old 09-17-2009, 07:06 PM   #3
Mikeg4572
CF Senior Member
Mikeg4572's Avatar
Take it to another dealer, those are pretty modest modifications.
Mikeg4572 is offline   Reply With Quote
Old 09-17-2009, 07:07 PM   #4
chad.orourke
CF Member
Wont it be in some master computer database that all GM dealers see? The engineering department evidently got involved.
Also of note they want 4grand to start tearing down the motor. I have not given them the go ahead.
Old 09-17-2009, 07:10 PM   #5
PowerLabs
Mechanical Engineer
Support Corvetteforum!
2006 Chevrolet Corvette
PowerLabs's Avatar
Send a message via ICQ to PowerLabs Send a message via AIM to PowerLabs Send a message via MSN to PowerLabs Send a message via Yahoo to PowerLabs
1- Take it to another dealer and post this dealer's name here. There is no reason they should be denying you warranty work; in fact, it is ILLEGAL for them to deny you work untill they can actually PROVE that whatever is wrong with your car was caused by your mods.
2- A ticking sound from a car with headers is either normal, if its quiet, because the thin walls of aftermarket long tube headers don't isolate sound as well as the thick cast iron manifolds, so you CAN hear some valvetrain noise with them, or it could be an exhaust leak. Check the area around your headers carefully for exhaust leaks. If you used the gaskets that came with the headers, then I can almost guarantee that is what the problem is; those gaskets are junk and will blow almost instantly; the factory gaskets are the ones to use.
3- If that is not the problem run a compression test and probe around the engine with a mechanic's stethoscope so you can identify where the noise is coming from. Take control of your troubleshooting; this is very simple stuff.
PowerLabs is online now   Reply With Quote
Old 09-17-2009, 07:13 PM   #6
Mikeg4572
CF Senior Member
Mikeg4572's Avatar
Old 09-17-2009, 07:14 PM   #7
Silverspeed
CF Senior Member
Silverspeed's Avatar
Location: In the woods, searching for my thrown putter....
Has the car been tuned?
Silverspeed is offline   Reply With Quote
Old 09-17-2009, 07:15 PM   #8
s ladd
CF Senior Member
Send a message via AIM to s ladd Send a message via Yahoo to s ladd
Good advice.. It does sound like an exhaust leak.
s ladd is offline   Reply With Quote
Old 09-17-2009, 07:42 PM   #9
VET4LES
CF Senior Member
VET4LES's Avatar
GM is denying warranty work on modified cars. The long tube headers required the removal of the cats which is a federal emissions law violations. If you had a tune that's another problem they will deny warranty work for. They are looking at extra hp that the engine and drive train was not designed for in addition to possible fine for emissions problem. It's the new GM.
VET4LES is offline   Reply With Quote
Old 09-17-2009, 08:44 PM   #10
chad.orourke
CF Member
It def is not quiet. It is loud enough that the car is ebarassing to drive down the road. I did use the factory gaskets, but it certainly did not sound like an exhaust leak. This is good advice though, and may be worth a shot regardless. I will have to get the car back from the dealer and see if I can get a sound clip or youtube video posted. Can you describe a blown header gasket sound?
I thought it was simple stuff that maybe a dealer could handle while I was getting that pesky airbag light fixed for the 5th damn time.
Old 09-17-2009, 08:45 PM   #11
chad.orourke
CF Member
Can you show this to me in writing though? I have been struggling to find this very thing.
Again thanks for the advice
Old 09-17-2009, 08:46 PM   #12
chad.orourke
CF Member
Quote:
Yes the car was tuned. I debate the quality of it, however.
On this note I called the tuner today. He mentioned he set my redline to 7000 and my shift light in the HUD to 6800.DOH! Thoughts on the long term effects of this?
Old 09-17-2009, 08:49 PM   #13
chad.orourke
CF Member
Quote:
I agree this is their reasoning and they are trying to avoid ANOTHER bankruptcy by saving some cash I guess.
Old 09-17-2009, 08:51 PM   #14
Silverspeed
CF Senior Member
The official statement from GM is floating around here somewhere, but from a quick search I found this, just FYI
http://www.g8board.com/forums/showthread.php?t=12605
Old 09-17-2009, 08:53 PM   #15
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
Car:
Mods:
Installation Date:
2 months ago
Problem:
-Chad
Since you have had the headers now for 2 months, its doubtful that its normal valvetrain noise.
You should have noticed that and grown used to it by now.
No, this is something new, in all probability.
If the car was tuned, and you say so above that it was, then this discussion is over......You may as well open your wallet, or get out your checkbook. I hate to say it, But...you're $#!+ out of luck.
GM is taking a hard line on aftermarket calibrations. Plus the car has headers on it. They may have already discovered the aftermarket calibration and that may be part, or all of the reason why they aren't touching it.
Hind sight is always 20/20 and I know this is no consolation to you, but, don't mod it, unless you are prepared to fix it.
Good luck with the repairs. Its always sad, when mods go bad.
'06 Quicksilver Z06 is offline   Reply With Quote
Old 09-17-2009, 08:59 PM   #16
chad.orourke
CF Member
Quote:
Originally Posted by '06 Quicksilver Z06 View Post
Since you have had the headers now for 2 months, its doubtful that its normal valvetrain noise. You should have noticed that and grown used to it by now.
If the car was tuned, and you say so above that it was, then this discussion is over...... I hate to say it, But...you're $#!+ out of luck.
And I am prepared to do just that, but when I go in to a dealer BEFORE the mod and ask "How will my warranty be affected with headers and an after market exhaust", and they answer "it wont" then this happens i get upset.
Old 09-17-2009, 09:04 PM   #17
'06 Quicksilver Z06
CF Senior Member
I don't see above where you say that you mention the tune while you were making this inquiry. You mention "headers and aftermarket exhaust" above, but "tune" is absent.
Furthermore, the warranty is not your dealer's to give. It is GM's.
Like I say, they MAY have discovered that it has been tuned and this could be the reason why they aren't even touching it.
I'd bet dollars to doughnuts that they have discovered that it has been tuned.
Otherwise, if they had told you what you say above, I can't see them going so far as to not even touch it.
They would at least look at it......unless they know already that IF it is a major failure, that they are going to have to show the regional rep that it had a stock calibration in it before they can get paid to do warranty work on it.
If they could show that, then they'd be jumping on it in all probability, especially after what they told you.
The probable reason why they aren't touching it, is because they know that they are going to have difficulty getting paid by GM for any warranty work.
Now how the *&^% would they know that????
Old 09-17-2009, 09:16 PM   #18
'06 Quicksilver Z06
CF Senior Member
Yes, and its probably already in there.
What is the "engineering department" and what do they do?
Were it me, I'd give the bill to whomever tuned it.
Old 09-17-2009, 09:17 PM   #19
chad.orourke
CF Member
You act like Im trying to pull one over on YOU, or are you maybe a GM employee hiding in here?
Old 09-17-2009, 09:24 PM   #20
'06 Quicksilver Z06
CF Senior Member
Don't shoot the messenger for telling you something that you didn't want to hear.
You asked for help.
The best help anyone can give you at this point is to tell you to buckle down and pay for the repairs, because its sounding like they have discovered the tune.
And if thats the case, it wouldn't matter if I were Fritz Henderson. Being paranoid about who is working for GM is not helping you now.
At any rate, if you have really big balls, you can try taking it back to stock and taking it back in on the off chance that they have not already discovered the non stock calibration in it.
But I would be very leery of that, and wouldn't give it much chance of working. Number one, its fraud, and number two, if they already know its been tuned, then what would be the point? They aren't going to look at it again with the possibility of repairing it under warranty anyway if they already know that it has been tuned.
Reload this Page Dealer giving me warranty trouble-PLEASE HELP
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Forums SLWRNU C5 General 23 05-04-2005 09:48 PM
Car Forum Humor 1971Coupe C3 Tech/Performance 15 10-09-2004 12:56 AM
C5 Forum Faired Okay ... MyVetteDream C5 General 10 10-07-2004 11:36 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
