09 LS3 Low Speed Bucking with Manual Trans
Old 08-25-2009, 09:03 PM
09C6Coupe
09C6Coupe's Avatar
Originally Posted by Walt White Coupe
09C6Coupe,
If you are in neutral, can you hold any rpm between idle and 1100 rpm? Like say 850 rpm? Mine jumps from idle to 1100 rpm. Can not hold anything in between.
In nuetral, no I can't. In 1st once I get the car rolling I can stay at about 950 smoothly most of time depending on the shoes I am wearing. Dock siders or barefoot gives me the best pedal feel. Running or walking shoes it's a little tougher.
I think ETC motor probably provides a certain percentage of TB butterfly movement based on voltage and it maybe that that percentage is not finite (sp?) enough. It' probably tunable to a point and then it is what is I would think.
Old 08-25-2009, 09:16 PM
Walt White Coupe
Walt White Coupe's Avatar
Received 2,225 Likes on 1,141 Posts
Alright so yours is a little unstable also. What I don't understand is that my 05 never had any indication of this. It was smooth as silk at these speeds.
Can anyone with an LS2 engine (05, 06 and 07's) comment on whether or not they experience this instability?
Old 08-25-2009, 09:32 PM
09C6Coupe
09C6Coupe's Avatar
Well, like I said it's a world of difference in gear when there load on the motor and drivetrain than when I am trying to hold the throttle at a steady rpm in neutral.
Old 08-25-2009, 10:10 PM
Walt White Coupe
All I can say is that on a level road going 9 mph there is essentially no load on the motor and is almost like being in neutral. Now if you were going up a hill that might be a different story.
Old 08-27-2009, 11:20 PM
BOB EAGAN
BOB EAGAN's Avatar
07 m6 smooth as silk when it was stock.
Old 08-29-2009, 04:36 AM
C5 Hardtop
C5 Hardtop's Avatar
nm.
Old 08-29-2009, 09:31 AM
Mez
Mez's Avatar
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I bet it relates to ignition advance table.
Old 08-29-2009, 06:14 PM
SSTEVEGS
SSTEVEGS's Avatar
My car does this too. I never noticed it until I read this post and took the car out for a slow ride up and down my street. My car will not idle between 600 and 1100 either when in neutral. I've never had any bucking problems in traffic since I usually shift into 2nd gear if it's a steady 5mph or more...but it did "buck" slightly in this particular test ride... '08 Z51 MZ6.
Old 08-30-2009, 10:53 PM
talionstallion21
talionstallion21's Avatar
Mine does this also at very low speed. I have an 08 base MN6. I have posted about a related problem as well -- when you are cruising at steady speed and have your foot on accelerator just barely depressed, say going 40 mph in 4th gear, I can feel the slight "bucking" or "surging". I think it is the throttle by wire (or lack of wire). The dealer says if no codes are showing there is nothing they can do. For now I am just living with it. When my foot is into it there is no problem -- only at very light throttle is there an issue. I also have difficulty, when stopped, revving the rpm's into the 600 to 1000 rpm range. I think it is the throttle, which is very touchy between not depressed and slightly depressed. It makes me depressed sometimes.
Old 09-02-2009, 09:36 AM
Walt White Coupe
Any LS2's (05 to 07's) with this problem? I think it's confined to just the LS3 engine.
Old 09-02-2009, 09:40 AM
SpinMonster
SpinMonster's Avatar
Has anyone had any luck in getting this problem fixed under warranty. My 05 LS2 never had this problem.
When my 05 was new and stock it did that. It had a bad hesitation too. I tuned it as soon as software was available.
Old 09-02-2009, 09:18 PM
Amric
Amric's Avatar
I think it is switching between the main spark and the idle coastdown spark tables.
Old 12-02-2009, 11:31 PM
  #33
kingfish
kingfish's Avatar
mY 09 does it dealer says it is fine and looks at me like I'm crazy to ask for a better smoother ride
Old 12-02-2009, 11:40 PM
  #34
kingfish
kingfish's Avatar
My 09 z51 does exactly the same thing
Old 12-03-2009, 12:55 AM
  #35
bps999
bps999's Avatar
I'm not experiencing the problem, so I may not fully relate, but I'd say a normal pull-away from a stop in these cars sees full clutch engagement at about 1500 rpm/12mph. If you get the clutch closed much below 1500 rpm I would kind of expect the car to be bucky, and hyper sensitive to the slightest throttle changes. All manual cars are like that to some extent, and the vette has tall gearing, which is bound to raise the "minmum smooth creep speed"
Old 12-03-2009, 02:08 AM
  #36
YLOFEVR
YLOFEVR's Avatar
St. Jude Donor '09-'10-'11
Default No bucking problems
I've never had any issues on my 06 MZ6 Z51.
Old 12-03-2009, 08:50 PM
  #37
Ragtop 99
Ragtop 99's Avatar
Received 1,182 Likes on 682 Posts
3.90s definitely improved the minimum creep speed.
To 09 LS3 Low Speed Bucking with Manual Trans
Old 07-26-2010, 11:54 AM
  #38
mlav171
3rd Gear
mlav171's Avatar
I have a 2007 LS2 standard that is having this exact problem. I bought the car with 3000 miles on it. It didn't seem to do it when I bought it. It now has 11,000 miles and does it pretty much constantly. Low RPMs, 2nd and 3rd gears between 25 - 40 MPH. If you apply slight accelerator or release the accelerator it bucks and jerks. I've had it to the dealer twice now and they haven't found or done anything. Not sure what to do next...
Old 07-26-2010, 12:04 PM
  #39
tomiboy
tomiboy's Avatar
09 Z-51 MN6. I have this too. I've been calling it a "surging" at 1500-2000 rpms at a steady cruise in 2nd or 3rd. Does it do this worse when cold? When you come to a stop do your revs climb a little and then drop back down?
Old 07-26-2010, 12:31 PM
  #40
mlav171
3rd Gear
mlav171's Avatar
It doesn't seem worse when cold. I've tried to monitor to see if certain conditions aggrevate it but I haven't found anything particular. The funny thing is I had the actual corvette mechanic at the dealer ride with me and he acknowledged he felt the issue. I left it with them for 2 days and they told me that they didn't find anythig and there was nothing else they could do. I do get the rev climb you mention when coming to a stop but it's not all the time.
Quick Reply: 09 LS3 Low Speed Bucking with Manual Trans
