NPP In a box question
I have ordered and will be installing a set of 2008 NPPs on my 2005 manual C6. My question is in regards to the NPP in a box. I have looked over the instructions about running the vacuum line from the fuse box to the trunk for a coupe, but I have a convertible...does anyone know or has anyone installed one on a convertible who could give me some direction on where/how to run the line from the fuse box? Thanks
Former Vendor
St. Jude Donor '09
It's basicaly the same, I just did not have a vert to use for pictures but you will be able to run it using the same route, you just need to work around the top parts
St. Jude Donor '08
You are going to love this setup! I've had mine for over a year now and the novelty still hasn't worn off. This is, by far, one of the coolest things you can install on a C6.
