that little nut thingy that hols the TPMS in
Old 07-08-2009, 01:57 PM
Road Rage
Road Rage's Avatar
Default that little nut thingy that hols the TPMS in
If I buy a new set of TPMS sensors do they come with the nut that holds them in from the outside or is that a separate item? I ask because it looks like the GM sensors DO NOT come with this nut and if I want to run a second set of wheels with sensors I'm going to need this nut and obviously can't pull them from the other wheels.
Old 07-08-2009, 02:29 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Here's a cut-n-paste from Gene Culley's website
||--Tire Pressure Sensors--||
25758220 – Tire pressure sensor – 57.21 each
15234846 – Tire pressure sensor nut – 3.73 each
Total set of 4 nuts and 4 sensors 267.65 shipped.
Note: The sensor comes with the washer and valve stem cap.
Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts.
If you get some used sensors they may come with the nuts. However, new ones do not come with the nut. As Gene mentions, new ones come with the rubber grommet and a valve stem cap, and also include a valve stem core.
if you get new ones just order the nuts when you order the sensors.
Bob
Old 07-08-2009, 03:48 PM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
i stole the TPMS nuts off my 19" rims to put on my widend 18"ers.
To that little nut thingy that hols the TPMS in
Quick Reply: that little nut thingy that hols the TPMS in
