Do I need Diamond Embedded Washer for pulley with ARP bolt??
I am reinstalling an OEM LS2 balancer with an ARP bolt, and I'm not sure if I need the POA friction washer or Diamond Embedded Washer if I'm using the ARP balancer bolt. I can't even find the part number at www.gmpartsdirect.com . . .
CF Senior Member
I'm no mechanical expert but with an OEM balancer I'd make sure it had the friction washer. The friction washer became a production part in the 2006 LS2 and LS7. Early 2005's without the DEW suffered problems. Short of pinning the crank I'd want the friction washer.
I don't know about ARP bolts but I believe the part number for the GM torque-to-yield bolt is #12557840. I vaguely recall they cost $5 or $6 and you need two when installing and setting the harmonic balancer.
wayne, thanks for the reply. I read the TSB on the friction washer, and it mentioned that there was a misalignment in the torquing machine, and several crank bolts were not torqued properly. I also had the same impression that the later cars did get the washer from the factory, but I cannot find any data to support that. Thus, maybe the washers were used as a fix to the early cars only . . . Anyways, thanks for your post.
Can anyone comment on this. I am putting an in ASP underdrive pulley since the OEM Harmonic balancer is on "national Backorder". They can't get the diamond embedded washer since it only comes with the OEM piece, but any comment on if i need this washer to go with my aftermarket pulley would be great.
Someone please let me know.
St. Jude Donor '08-'09-'10
ARP Bolts ?
Bolts.
St. Jude Donor '09-'10-'11
The LS7 also uses a diamond washer for the flywheel to crankshaft as well.
The washer is for production dampers. There was one on my 07 LS2, there's not anymore.
Apply a skim coat of Ultra Black starting about half way up the ARP bolt and a thin coat on the shoulder and torque to spec. The silicone is to seal against any unwanted leaks.
I have 7K miles on my ATI damper and ARP bolt, no GM washer.
