Mobil 1 vs Amsoil
Mobil 1 vs Amsoil
Yes, it's been beat to death but I'm looking for anyone who has actually used both products, performed tear downs or had some other measurable difference between these two oils. Has anyone actually seen a benefit switching out Mobil 1 and using another brand of oil? Such as Amsoil. Thx
The only way to really answer your question is to do a double blind study with multiple vehicles. The only people that could do that would be the oil manufacturers. The other company that could do it would be GM. If anyone can point to such a study, I'd love to see it. Individual results, either positive or negative, have no real value.
- Mark
- Mark
I've used both and immediately noticed higher oil pressure with Amsoil's signature 0-30w (their best oil) I no longer have fuzz on my magnetic oil plugs when I change the oil. I'm sticking with amsoil.
I figured as much. Well, some are saying that Mobil 1 oil filters are showing better results than Amsoil's Eao on bobistheoilguy.com. Particle count results have been showing that Mobil 1 oil filters are actually better than the Eao. I was using the Eao but have since switched.
Oil analysis results favor Amsoil but oil analysis is not an exact science and can be misinterpreted. Some oils hold more particles in suspension than others so it can make it kind of difficult. I lean towards Amsoil overall though.
I use nothing but AmsOil in all my vehicles. I have rebuilt engines that were not using AmsOil and they were pretty worn down from the rings, cylinder walls, crank bearings, and timing chain with only about 30,000 miles on the engine (petroleum-based oils, that is).....the engines were from friends of mine that simply wanted upgrades.
I've taken my own engines using AmsOil that I wanted to upgrade and rebuilt them that had about 45,000 miles on them and everything, and I mean everything internally, still looked like brand new! I've been an advocate for this oil ever since.
On my Corvette, I also use their oil filters and a Filter Mag to catch all the metal particles in the filter. You have a $50,000+ car, why would you use a cheap oil? In a Yugo, sure, but not in a Vette. Use the best that's out there, AmsOil.
easy to get literally about anywhere, recommended by the manufacturer (and most others), proven through service in millions of vehicles, and at the LEAST, good enough 95% of us.
But, I respect the idea that sometimes there IS something better, and a minority of vette owners can easily justify the different oil. I just don't know of anything beyond personal observations (anecdotal "evidence") that proves either or.
I find it very difficult to believe any engine today would exhibit the wear you claim after 30K miles using the cheapest oil available even if the oil was never changed in those 30K miles. I'll go one step further and just call BS on your claim I put in bold above...if you saw the wear you claim, it wasn't due to the oil used. More likely it was from the lack of oil as in the owner allowed the engine to get too low on oil. No oil can provide protection if it isn't there, not even Amsoil.
What difference does the price of a car make as to what oil you should use? Why would I use a cheap oil if I knew my engine was going to fail in 30K miles (as you claim anyway) and subject myself to the expense of an engine change in any car? Why would I use an expensive oil if I knew a cheaper oil would provide all of the protection I need? The fact of the matter is that if a person drove their Corvette on the street only with an occasional short blast to red line, petroleum based oil would give the same exact "performance" (in reference to wear) as synthetic. You sound like one of those infomercials with the ridiculously wild claims in an attempt to make a worthless product appear to have value...the sad part is Amsoil doesn't need that type of hype as it's a good product that can stand on its' own merits.
The next thing you'll be claiming is Amsoil lowers your normal running oil temps...which reminds me, there was another thread I forgot to respond to.
I'm with glass slipper here. I've seen engines run well over 300,000 miles using nothing but conventional oil and they looked brand new inside. Amsoil is not the only oil that keeps an engine clean.
http://online.wsj.com/article/SB123932274269507173.html
I found this interesting. Don't see any Amsoil mentioned here.
The group 4 oils don't make a major difference until you start abusing them, then they show their advantages over other oils.
Location: NJ..."the way I saw it, everyone takes a beating sometimes."
1 Post
It still amazes me that these threads continuously pop up. "This oil is better than that oil!" You're overthinking it. Other than for specific engine and/or race situations, a street driven, daily driver will be fine with just about any of the major off the shelf oil brands.
