265/35/18 & 305/30/19 on stock wheels?
Bridgestone has a tire that's a few $$$ more than Invo and looks like it's a betterr tire. (re-11)
Can I fit 265's and 305's under the skin of my coupe?
That seems to be the direction folks are going, myself included when my F1's wear out
just ordered with a local shop $1,400 installed and alignment otd
Nervous as hell due to nobody else having them.
There's a $100.00 rebate from Bridgestone on them.
I'm hoping that the rears will last longer due to more contact.
I was wondering if these tires would still be ok on the same car if it is lowered, I have adjustable Pfadt coil overs and it is quite a bit lower than stock. I can only fit my index finger in between the center of the fender and the top of the tire? Does everybody still think it would be ok?
Running lowered with these tires, you run the risk of cracking your fender, that's the risk.
Where do you live that you encounter no potholes, driveway curbs, bad roads or "discarded crap"/tires in the highway? Any lower than stock and our cars start to become street sweepers
Im running 275/35/18 and 305/30/19s on stock wheels lowered all the way in the front and lowered all the way in the rear with the bushings cut off. Everything is fine and love the Invos!
By lowered all the way, do you mean using the shorter height bolt? Is it as low as I describe my car, can only get 1 finger between the top of tire and the fender?
That back drive is on a slant as are most driveways. It actually sits level. I know the back looks too low in that pic but its sits level. I have no problems with my car being lowered, you just cant drive it like a truck. I live in west Tx and the roads are horrible here in some places and I have no issues.
