Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-26-2009, 12:51 AM   #1
blackbird345
CF Senior Member
Default Do they make 28 inch slicks for 17 inch rim?
The 26 inch ET Streets I have now just aren't holding in 2nd gear. I was hoping to go up to 27 or 28s on my 17 inch rims, is that possible? Can 16 inch rims fit on the Z51? I have a 2007 Z51 6 sp man ECS supercharger running 15psi, water/meth injection etc. I'm getting ok 60 fts like 1.68 but 2nd gear is just spinning right through....any advice?
blackbird345 is offline   Reply With Quote
Old 04-26-2009, 01:06 AM   #2
LS1LT1
CF Senior Member
LS1LT1's Avatar
Send a message via AIM to LS1LT1
Quote:
M/T doesn't, they have only one 17 inch DOT legal (or otherwise) slick and it's the one listed as 26" (it's actually closer to 26.5").
You might have to go drag radial to get the height you're looking for.
No, not without serious modification and/or a custom made set of CCWs/Bogarts etc.
LS1LT1 is offline   Reply With Quote
Old 04-26-2009, 12:31 PM   #3
chazc6
CF Senior Member
St. Jude Donor '10
chazc6's Avatar
How much air do you have in them? The sidewall should wringle even in second gear with the right amount of air pressure. Your limited to 17'' tires, the only 17''x27'' or 28'' are drag radials.
chazc6 is offline   Reply With Quote
Old 04-26-2009, 03:55 PM   #4
blackbird345
CF Senior Member
I'm running between 12-13 psi
Old 04-26-2009, 04:14 PM   #5
dennis50nj
CF Senior Member
dennis50nj's Avatar
put more air in them, and shift faster, it sounds like the suspension is unloading on the shift because the nose is dropping, try rolling into the throttle after the shift until the front comes up, let Doug try driving it maybe its just driver error
dennis50nj is offline   Reply With Quote
Old 04-26-2009, 06:00 PM   #6
Pro Stock John
CF Senior Member
Pro Stock John's Avatar
Send a message via AIM to Pro Stock John
I've never used M&H Tires but they list some 28" tall, x 17 tires:
http://www.mandhtires.com/store.php?...mode=cat_click
Ever thought about running some QA1 drag shocks up front, they would help keep the nose up and keep traction. I never ran ET Streets below 14-15 cold, because if I had to run them at like 11 cold I felt that I had to work on other aspects of the car tractionwise.
Pro Stock John is offline   Reply With Quote
Old 04-26-2009, 07:54 PM   #7
blackbird345
CF Senior Member
But those you listed from M&H are drag radials...maybe I'll just have to go with new shocks up front, how expensive are the QA1s?
Reload this Page Do they make 28 inch slicks for 17 inch rim?
Tags
17, 17inch, 28, c4, corvette, drags, fit, inch, make, radials, rim, sale, slick, slicks, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
