Show Me Your Honker
Show Me Your Honker
I think I've decide on the Callaway Honker CAI. Mostly because of quality issues with the Vararam. With the exception of a recent Hydrolock (inherant risk with all CAI) and some idle issues with the LS3 the Honker seems trouble free. Post your pictures and comments of the Honker. Thanks
I've been running it for about a year, works great, looks great. Very easy to access the filter for cleaning. No hydrolock issues here and I live in South Florida where it rains quite a bit.
I looked at the blackwing but to be honest I like the way the Callaway looks. It has an almost stock look while still delivering better then stock performance.
Location: ...tearing up the highways, one state at a time™®©
Received 2,104 Likes
Honker kept on honkin' and made the power
I have a Honker. no issues 60,000 miles
I have it just sitting here since i just ordered the A&A kit.
I installed mine without removing the shroud. Here's the procedure:
1)Remove the shroud cover and slide a ¼” piece of plywood in between the shroud and condenser coil. I attached two pieces of duct tape on the top of the wood to hold it in place.
2)Remove OEM air box and install Honker.
3)Drill two “small” pilot holes on the left and right side through the assembled unit to get the reference points.
4)Remove unit and take the ring that holds the filter and attach it using two screws into the shroud. Using a white marker, trace the cut out area. Remove the ring.
5)Very carefully, cut out the opening for the filter assembly. I used a “small hand held” right angle drill with a small circular saw blade. This part was a little nerve racking. I’m sure someone can come up with a better way!
6)Now for the last part of the install, attach the filter ring again with a couple of screws, and using the right angle drill, drill the number of pilot holes using the correct size bit for the rivet through the entire ring (ring is hollow) into the shroud.The very bottom is a little tight and you should test the angle of the size gun you have in order to decide where you will eventually drill the holes.
7)Remove the two screws and the ring and you should have the hole cutout and the pre-drilled holes to attach the filter ring with rivets. Note: I did not use the template or the rivets that come with the kit!
8)To install the filter ring, I used a small rivet gun with a “very short nose”. The ring now has the pilot holes pre-drilled. Remember, the ring is hollow! I used the top pilot hole and drilled a larger hole the diameter of the rivet gun through the top of the ring. Be careful not to go through the back side of the ring. Now you can fit the nose of the gun with a rivet down through the larger hole and mount the ring to the shroud using pop rivets. I used some black RTV on the back of the ring before I started to rivet in place. After I had it attached, I used the remainder to apply a thin bead around the entire ring. The entire install took about two hours. The best thing is to visually plan out this type of install before you start and have all the proper tools. Remember, the key is a “small” handheld right angle drill and the shortest “nose” rivet gun you can find. Hope this helps.
