Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2009, 06:02 PM   #1
DHB820
CF Senior Member
St. Jude Donor '09
DHB820's Avatar
Default Battery Replacement Fit for C6
I need to replace the battery in my 2005 C6 Manual. Has anyone replaced the AC Delco OEM with the Optima Red Top, and if so, did it fit properly? The shape of the Optima looks like it might be a problem. Appreciate any feedback.
DHB820 is offline   Reply With Quote
Old 04-01-2009, 08:12 PM   #2
*FAÇADE*
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Support Corvetteforum!
*FAÇADE*'s Avatar
Check it out:
http://www.bugmanweb.com/c6/battery.html
*FAÇADE* is offline   Reply With Quote
Old 04-01-2009, 08:22 PM   #3
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
Optimas are not all they are cracked up to be.
I would stay with the ACDelco Professional grade with a 50 month, free replacement warranty.
TEXHAWK0 is offline   Reply With Quote
Old 04-02-2009, 02:35 PM   #4
HuskerBullet
CF Senior Member
HuskerBullet's Avatar
I haven't needed it, yet, but I've heard nothing but good things about the Optima Red 35. That's probably what I'll get when the time comes.
HuskerBullet is offline   Reply With Quote
Old 04-02-2009, 07:14 PM   #5
pmj341
CF Senior Member
St. Jude Donor '08-'09-'10
pmj341's Avatar
Send a message via AIM to pmj341
I got one yesterday,Optima red Top, it seems I had a dead short in my TB harness.
Had to clean up and solder with shrink tubing the 8 wires that go to the plug
for the TB.
Fittment was great, and matched my Valve Covers!!
pmj341 is offline   Reply With Quote
Old 04-03-2009, 10:27 AM   #6
haljensen
CF Senior Member
haljensen's Avatar
The '05 C6 used a different post and cable location than later 'Vettes. Best try a test fit before you pay.
haljensen is offline   Reply With Quote
Old 04-03-2009, 02:03 PM   #7
mikesul
CF Senior Member
I have a red top in my '08. It fit with no problem at all.
mikesul is offline   Reply With Quote
Old 04-03-2009, 05:57 PM   #8
DHB820
CF Senior Member
St. Jude Donor '09
DHB820's Avatar
Thanks for all of your input. I am now back on the road.
Old 04-03-2009, 07:38 PM   #9
StoplightWarrior
CF Senior Member
is the optima lighter than stock?
StoplightWarrior is offline   Reply With Quote
Old 04-03-2009, 07:55 PM   #10
pmj341
CF Senior Member
pmj341's Avatar
I never checked
Old 04-04-2009, 05:16 PM   #11
Dale_K
CF Senior Member
I was thinking about a type/size 86 from Walmart. I think it will be an acceptable battery and that's all I'm looking for. Has anybody used the generic 86?
Dale_K is offline   Reply With Quote
Old 04-04-2009, 05:46 PM   #12
TCW
CF Senior Member
St. Jude Donor '06-'13
TCW's Avatar
When it comes time to replace your battery all you need to know is, Sears. Sears Die Hard. NOTHING is better!
Tom
TCW is offline   Reply With Quote
Old 04-04-2009, 10:05 PM   #13
timd38
CF Senior Member
timd38's Avatar
I put a yellow 35 in my 06 to save weight.
Click the image to open in full size.
Picture is pre-headers.
timd38 is offline   Reply With Quote
Old 04-04-2009, 10:27 PM   #14
BornSUPERCHARGED
CF Senior Member
BornSUPERCHARGED's Avatar
So you did the reverse battery trickery? Is it pretty easy?
BornSUPERCHARGED is offline   Reply With Quote
Old 04-04-2009, 10:33 PM   #15
timd38
CF Senior Member
timd38's Avatar
Quote:
Simple, took longer to get the old one out. 06 comes with a T5 battery and as you stated the polarity is 180 off, but everything works and fit fine.
Old 04-17-2009, 12:42 PM   #16
HinsonSuperCars
Supporting Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-267-6387
We carry the Optima Yellow Top 34/78 for $110.
http://forums.corvetteforum.com/c6-p...ops-110-a.html
Seth
HinsonSuperCars is offline   Reply With Quote
Old 04-17-2009, 01:24 PM   #17
BornSUPERCHARGED
CF Senior Member
Seth
Damn why didn't I see that???
Old 04-17-2009, 03:12 PM   #18
SvetteC6
CF Senior Member
SvetteC6's Avatar
Timing is everythiing! I just bought the Optima Yellow top 34/78 for $210.00 at a local parts shop.
SvetteC6 is offline   Reply With Quote
Old 04-17-2009, 03:18 PM   #19
BornSUPERCHARGED
CF Senior Member
Old 04-17-2009, 03:43 PM   #20
oldmansan
CF Senior Member
St. Jude Donor '09
oldmansan's Avatar
That Optima is heavy. I will probably pick up an Odyssey. I had one in my other car and is was great and lightweight. Here are some specs.
http://www.septechnologies.biz/index...S&Category=595
San
oldmansan is online now   Reply With Quote
Reload this Page Battery Replacement Fit for C6
Tags
05, 07, 2005, 2006, 2007, 86, battery, c5, c6, corvette, fit, location, m, optima, replacement
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 02:23 PM
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 03:33 AM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 12:59 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
