Racing Seats in Z06
Old 03-24-2009, 11:09 AM
N17RO
N17RO's Avatar
Default Racing Seats in Z06
Guys,
Has anyone fitted race seats in a 2007 Z06 and had any problems with the sensors? If so is there anyway to wire the seats up or use the original seat brackets to help?
Might be a stupid question but I need to know before having a custom bracket made to suit the new race seats!
Old 03-25-2009, 01:31 AM
kelp
kelp's Avatar
I have a RaceTech drivers and Cavarraggio passenger. Each very different. You need to retain the stock rails for the airbag system to function. Not only can this be done, I did, but you retain the functionality of adjustment.
Old 03-25-2009, 01:37 AM
N17RO
N17RO's Avatar
Excellent! Thanks mate!
What brackets did you use to adapt them to the original rails? Were they custom?
Thanks again.
Old 03-25-2009, 08:38 AM
no spin
no spin's Avatar
You might want to reference this thread before you decide how to proceed.
http://forums.corvetteforum.com/c6-z...-no-codes.html
Old 03-25-2009, 11:16 AM
OCCOMSRAZOR
OCCOMSRAZOR's Avatar
There is a wiring harness attached to stock seats that you have to bypass if you want airbag and telescoping steering wheel to work properly. The good news is that Pfadt has an adaptor that you can plug into the harness which allows all of these things to work. It's about $100.00.
Old 03-25-2009, 02:40 PM
N17RO
N17RO's Avatar
Thanks for the help guys. I'll try and keep the original rails and custom make a bracket up to take the new seats.
Old 07-08-2011, 03:38 PM
Corinthian
7th Gear
Corinthian's Avatar
Originally Posted by N17RO
Guys,
I used the hardbar rail (http://hardbarusa.com/hardbar/popup_image.php?pID=46) and used a pfadt harnesswire to override the electrical. now the electrical adjustments for the steering wheel work and the airbag.
http://www.garaget.org/?car=162626&image=1955275
Old 07-08-2011, 05:15 PM
SinisterC6
SinisterC6's Avatar
Im on stock seats but when using my harness I plug the buckle behind the seats. Prevents it from flapping and keep the car happy.
Old 07-08-2011, 11:09 PM
06z06_427
06z06_427's Avatar
What is the weight savings of going to a racing seat?
Old 07-15-2011, 02:32 PM
Corinthian
7th Gear
Corinthian's Avatar
I dunno what the weight is for a raceseat but the original drivers seat in my '07 Z06 is 22.5kg (50 lbs)
To Racing Seats in Z06
Quick Reply: Racing Seats in Z06
