A/C belt came apart!!!!
I installed a new Belt 500 miles ago, and it just came apart today while on a cruise, A/C was not on!!!, tensioner looks good, aligment does too!!
any one have this problem??
thanks
Phil
thanks
Phil
Received 2,240 Likes
Sounds like a bad belt.
I'm sure I had it off couse I was doing some data logging on HP Tuners
as far as the nick, it's possible it went on real hard.
Well, it's a new UD balancer, new belt. aligment was perfect!!
the only thing left is the tensioner!!!
I used all new parts when I assembled the 427, except the A/C belt tensioner.
thanks
thanks
Do you have a laser thing available to align the pullies? That wil ltell you if the lower pulley is out of alignment.
Joe
I took a straight edge from a/c comp to balancer and it's great, the Arp balancer bolt has not moved.
what else do we have??
Hmm. That sounds like good news. Maybe you just got a bad belt, though that sure seems rare anymore. I think I'd buy another belt and watch it in action to see what I saw!
Sounds like a good plan. I have a spare tensioner I would send you, but, unfortunately it's the main tensioner.
Get your car fixed by Saturday and make some passes at the Corvette Challenge this weekend at Palm Beach International! Unfortunately my car has no diff and I've got a work engagement so I can't go to this event. It should be fun there is a lot going on at the track that day, see racepbir.com.
Well after visiting the local GM dealer and speaking to one of the tech's, he mentioned problems with the a/c belt tensioner, He said on the 6.0 trucks the tensioner under full power and higher miles, start to wear side ways causing the belts to come off.
they just replace the tensioner assy with a new one and problem went away.
I have no way of checking mine, so I'll replace it and maybe machine an aluminum idler with sides to keep the belt aligned.
I have a Katech main belt tensioner, I wonder if they make one for the A/C??
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Just a note, for those mentioning that the AC was off, I think the belt is still moving even with the AC off. AC on just puts more load on the belt.
Or did I read those post wrong?
the A/C was off, yes the belt is still freewheeling with no load, when you activate the clutch then the compressor rotates.
