Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Tech/Performance
LS2 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Callaway
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-11-2009, 11:56 AM   #1
0Mike@G-Force
CF Senior Member
Default All Pro LS7 Heads and cam dyno numbers!
My customer wanted big N/A power without cam surge. We suggested a set of WCCH All Pro Heads and a small cam. The results speak for themselves.
2006 C6 Z06
  • WCCH LS7 All Pro Heads
  • Jesel Mohawk Rockers
  • 230/249 117 LSA Comp Cam LSR lobes
  • Ported LS7 Intake
  • Kooks 1 7/8 Headers and Off Road X-pipe
  • Corsa Exhaust
  • RPM Transmissions Stage 5 3.90 Rear End
  • Driveshaft Shop Stage 5 Half Shafts
  • Meziere Water Pump
  • ATI 10% Underdrive LS7 Balancer
We have found the limit of the stock LS7 Intake as Manifold Pressure would drop as low as 93KPA above 6200 RPMs. I also have a set of 2" Kooks on order that we will test next week.
And for your viewing pleasure a couple of dyno pulls!
http://videos.streetfire.net/video/G...ads_640437.htm
Mike@G-Force is offline   Reply With Quote
Old 03-11-2009, 12:38 PM   #2
Cobra4B
CF Senior Member
CI 3-5-6-7-8 Veteran
Cobra4B's Avatar
Send a message via AIM to Cobra4B
Wow... that's amazing numbers for that sized cam. Any pics of the heads?
Cobra4B is offline   Reply With Quote
Old 03-11-2009, 01:34 PM   #3
Redline Motorsports
Premium Supporting Vendor
Redline Motorsports's Avatar
Send a message via MSN to Redline Motorsports
Those are GREAT numbers! Real nice combination! WCCH get's her done!!!!
Howard
__________________
www.redline-motorsports.net
Upstate New Yorks Full Service Performance Shop!
Authorized Land and Sea Dynomometer Facility
Dealer/Installers for!
ProCharger,APS, Magnuson
AR Headers, Vararam,
2006 Z06 (840 RWHP/788 RWFT on 11 psig)
2008 LS3 Z51 (494/453) cam/headers
2010 SSRS HTR-750 427ci (665/650)
1-518-355-8460
Redline Motorsports is offline   Reply With Quote
Old 03-11-2009, 02:06 PM   #4
JayplaySS2
CF Senior Member
Wow, screw big cams these days
Next 2" Kooks? Wow
JayplaySS2 is offline   Reply With Quote
Old 03-11-2009, 06:59 PM   #5
Ragtop 99
CF Senior Member
Ragtop 99's Avatar
very nice results. A couple questions:
* Was the 93 KPA observed on the stock intake or the ported intake? Is there a CAI and ported TB on the car?
* Why was a big split selected for use on a car with headers? After porting the heads, is the exhaust that far behind to need such help? Especailly with the 2" headers going in could some exhaust duration be traded for intake and gain more power while keeping the docile nature?
Ragtop 99 is offline   Reply With Quote
Old 03-14-2009, 12:57 PM   #6
0Mike@G-Force
CF Senior Member
Intake is ported. Stock TB with a Vararam.
All Ls7/Ls3 style heads require a bigger than normal split. Due to the huge intake ports and small exhaust ports.
Old 03-14-2009, 05:33 PM   #7
IPS Motorsports
IPS Motorsports's Avatar
Send a message via AIM to IPS Motorsports
Nice build! The numbers look nice!
And your absolutely correct about the LS7 intake, they leak air like a sieve. The new LSXr intake manifold will be a great product for this car once its available.
Again nice build up.
-Brandon
IPS Motorsports is offline   Reply With Quote
Old 03-15-2009, 10:03 PM   #8
aTX427
Guest
How much compression?
Reload this Page All Pro LS7 Heads and cam dyno numbers!
Tags
99, cam, comp, corvette, dyno, headers, heads, kooks, ls7, lsr, mufflers, porting, pro, stock, turbo, twin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
