Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Tech/Performance
LS2 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-23-2009, 01:49 PM   #1
UR2SLO
CF Member
Default C6Z stock dyno... Freak??
i just got my car dynod a couple weeks ago at 8900miles, the car is stock and always seemed to pull strong (as a Z06 should).
After buying and installing a K&N intake on it it felt a little slower so i wanted to get a before and after dyno done to make sure i wasnt losing power with out having it tuned. To my surprise i was losing a tremendous amount of power in the midrange, and topend too. The guy performing the dyno said it felt almost as if it was detinating. Those numbers came out to 454rwhp and 380tq with a nasty midrange tq curve. we swapped out to the stock intake and the car run much better putting down 473rwhp and 438rwtq bone stock!
heres a pic of the dyno chart (scanner having problems):
Red is stock curves, blue is K&N.
and heres a vid of the dyno... at the end of these computer generated daily driver races....
http://user.streetfire.net/video/Str...yno_636148.htm
intake reinstall with tune soon to come
sorry i posted this in the Z06 forum too to get more opinions hopfully
UR2SLO is offline   Reply With Quote
Old 02-23-2009, 02:03 PM   #2
TinSecondRice
CF Senior Member
St. Jude Donor '08-'11
Support Corvetteforum!
TinSecondRice's Avatar
That is odd that it would lose hp. I have heard of several people being around 470 whp and putting headers, exhaust, and intake on and only gaining about 10 whp with all those mods.
TinSecondRice is offline   Reply With Quote
Old 02-23-2009, 02:15 PM   #3
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
First off it's super lean. Over 14:1 on both pulls.
The dip in the torque curve looks like the clutch was slipping or something.
Detonation would make the graph very choppy.
edcmat-l1 is offline   Reply With Quote
Old 02-23-2009, 02:17 PM   #4
adam205348
CF Senior Member
Send a message via AIM to adam205348 Send a message via MSN to adam205348 Send a message via Yahoo to adam205348
Well if it was detonating then it could possibly be that the CAI was letting in so much more air than stock and you said you did not have it tuned that it was leaning out so it was detonating and when the computer sensing detonation it pulls timing till it stops detonating which would result in the MASSIVE drop in power. With the CAI you are letting in more air and the motor does not know how much more fuel to dump in so it leans out. Get it tuned with the K&N and you should atleast come back up to stock power if not a little above.
adam205348 is offline   Reply With Quote
Old 02-23-2009, 02:19 PM   #5
adam205348
CF Senior Member
From that PERFECTLY FLAT AFR line i would suspect that that particular AFR sensor they are using was not working quite right OR you were SO LEAN that i was maxing out the sensor at 14.75 or so.
Old 02-23-2009, 02:25 PM   #6
UR2SLO
CF Member
the afr sensor was not being used on these pulls, they dyno pulls were strictly for numbers
Old 02-23-2009, 02:33 PM   #7
adam205348
CF Senior Member
Then I would go back to my first comment that with the CAI it needs to be tuned for the extra air that is able to get into the motor. Without the tune it is leaning out so bad that it is detonating which is causing the ECU to pull timing which is dropping your power. Put the K&N back on and tune it and I am sure you will pick your power back up and then some.
Old 02-23-2009, 03:12 PM   #8
FloydSummerOf68
CF Senior Member
FloydSummerOf68's Avatar
Send a message via AIM to FloydSummerOf68
If you want to know if a car's a freak you put it on the track
Something is definitely strange about it losing power though.
FloydSummerOf68 is offline   Reply With Quote
Old 02-23-2009, 03:46 PM   #9
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
Quote:
Yeah, it is odd, but if they're just layin on the floor or something, they'll read 18:1. I've had several go bad over the years, and I've never seen one lock in on 14:1. If they go bad, they read either 18:1, or nothing.
The OP said in his other thread, that it wasn't in the tailpipe, but like I said, I've never seen one read 14:1 layin on the floor.
Old 02-23-2009, 03:48 PM   #10
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
That intake wouldn't lean it out so much as to cause detonation. They're pretty damn rich to begin with, and untuned, the new intake would get the A/F ratio closer to what it needs to be.
Besides, the graph looks too smooth to have any amount of detonation.
Old 02-23-2009, 05:38 PM   #11
Fore58
CF Senior Member
Fore58's Avatar
The dyno sheet appears to be indicating STD. Is this correct? I believe SAE correction would be slightly lower. Just checking.
Fore58 is offline   Reply With Quote
Old 02-24-2009, 10:46 AM   #12
Slvr08Z51
CF Senior Member
Slvr08Z51's Avatar
Quote:
Depends on the weather.. But most of the time, SAE would be higher.
Slvr08Z51 is offline   Reply With Quote
Old 02-24-2009, 11:12 AM   #13
Ragtop 99
CF Senior Member
Ragtop 99's Avatar
So did you try taking off the K&N and reinstalling it? I'm wondering if something fluke happened the first time.
Ragtop 99 is offline   Reply With Quote
Old 02-24-2009, 01:48 PM   #14
glass slipper
CF Senior Member
Quote:
Here's all you need:
http://www.land-and-sea.com/dyno-tec...horsepower.htm
The formula for correcting to SAE is:
cf=1.18*[(990/Pd)*[(Tc+273)/298]^1/2] - 0.18
Where cf is correction factor, Pd is ambient pressure in hPa, and Tc is ambient temperture in degrees Celsius.
SAE corrects to 77*F and 29.234 in Hg and STD corrects to 60*F and 29.92 in Hg.
If we want to correct to SAE standards and the engine was tested at ambient conditions of 60*F and 29.92 in Hg, (which just happens to be the STD standards) we have:
cf=1.18*[(990/1013.2)*[(15.56+273)/298]^1/2] - 0.18
cf=.95456, which is the correction factor when going from STD to SAE.
The difference when going from STD to SAE will always be ~4.5%...it doesn't depend on the weather.
glass slipper is offline   Reply With Quote
Old 02-24-2009, 01:56 PM   #15
ramrodw30
CF Senior Member
ramrodw30's Avatar
The MAF will sense any additional airflow and adjust accordingly - you do not need a tune for a different air filter no matter how efficient it may be, that is absurd.
ramrodw30 is offline   Reply With Quote
Old 02-24-2009, 02:40 PM   #16
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
Quote:
Not true. Almost any time you change the intake in front of the MAF, the MAF will need to be recalibrated. Will it be so far out that it's out of the range of adaptability? No. But it will throw it off somewhat. Is this the cause of the power loss in the graph? I highly doubt it.
Old 02-24-2009, 03:11 PM   #17
6Speeder
CF Senior Member
6Speeder's Avatar
Our MAF is a "sampling" type maf. It does not sense all the airflow, it is calibrated for the stock intake. Change the intake and the calibration is off, it won't be telling the PCM a correct value. You will see your LTFT's go up, maybe enough to set codes and the CEL.
__________________
Porsches for breakfast
Ferraris for lunch
6Speeder is offline   Reply With Quote
Old 02-24-2009, 03:39 PM   #18
Fore58
CF Senior Member
Fore58's Avatar
Ok, but in my case the STD was 9 hp higher. Futhermore, this is the very first time I've heard that the SAE is higher....unless I'm missing something here.
Old 02-25-2009, 10:01 PM   #19
Retrotech
CF Senior Member
Retrotech's Avatar
Send a message via AIM to Retrotech
Is it possible that the new CAI caused a knock event and set the car into the low octane tables which are considerably lower.
This happened once while I was tuning on the dyno and had a 30 hp loss on one run only.
Retrotech is offline   Reply With Quote
Reload this Page C6Z stock dyno... Freak??
Tags
470, afr, bone, c6, c6z, dyno, numbers, placement, rwhp, sensor, stock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
