Cold air/ Intake packages...Question...
I'm looking to add a cold air induction package to my C6...I know everyone has their own opinions, but i wanted to know what you guys thought....On my other vette (c5) I had a halltech system and it was okay for the money....
On my c6 z51 I have a diablo programmer, and b&b exhaust..and really need an intake..I was thinking the vararam or the callaway honker system...
But what kind of intake system to you guys reccomend or prefer? Or which system have people had good results with, backed by track or dyno numbers
Thanks!
Sonny
Thanks!
Sonny
Thanks!
Sonny
Thanks!
Sonny
SUBVETTE
I'm using the BPP Vortex CAI. Works well, Looks Great, Superb Quality and installation is relatively easy. This is installed on my bolt-on only LS3 which runs the quarter in 11.2 @121mph. So I feel it does everything the manufacturer claims. My previous CAI on my bolt-on LS2 was the Vararam which also did a great job...BUT... It lacked the fit and finish of the Bpp Vortex. JUST MY OPINION...Good luck in your seection of a good CAI.
I'm looking to add a cold air induction package to my C6...On my c6 z51 I have a diablo programmer, and b&b exhaust..and really need an intake..I was thinking the vararam or the callaway honker system...
But what kind of intake system to you guys reccomend or prefer? Or which system have people had good results with, backed by track or dyno numbers.
CAI's such as the BPP, LPE and Callaway Honker have their openings higher on the upper opposite side of the radiator, making it tougher (but not impossible) to ingest water.
The Callaway Honker has got to be one of the best intakes for street/strip use. Excellent quality, collects virtually zero bugs, no debris, no sucking noise and has a much larger filter area as compared to the Vararam. There is pressure created in the area that the Honker draws from. With the larger filter area, you could get the same power results and gains at speed as the Vararam. The only downer is you cannot get a Honker with an optional pre-cut shroud.
I gained .15 in the 1/4 mile by just propping my shroud open with the "free air mod". You can gain from .10 to .30 in the 1/4 mile with a true closed system Cold Air Intake. I picked up .20 in the 1/4 mile with my Xcelerator (Honker clone) CAI. Good Luck!
I'm very happy with my Honker. Fit and finish is great! They even include pins to put into the upper radiator shroud to cover the holes left from removing the factory unit. I haven't seen another air intake manufacturer do that!
To reap the benefits of a true "cold air" unit the air ingestion must come from outside the engine compartment. If not the air is superheated by the engine heat and the affect is lost. The most popular units here on the Forum seem to be the VaraRam or the Callaway Honker. Both pull cold air from outside the car through the radiator shroud which must be cut to access the air stream in front of the radiator. Not much price difference in the two units. There are many posts on this subject which can be accessed by using the search function. Good Luck in your quest.
On the subject of "Hydrolock" unless you drive through standing water about a foot deep there is no problem. Just don't try to play U-Boat captian and you will be fine.
SUBVETTE
I now run the Airaid intake for the LS2 and it pulls just as hard as it did with the Vararam. I left the cut shroud in place so plenty of cool air can reach the filter.....but being its not a scoop and another 7-8 inches higher I don't expect to have any water issues unless I really submerge the nose of the car.
WRONG, try ankle deep! Read it on the forums from another Vararam user and thought he was nuts.....water that low can't get sucked it. Then it happened to me. Ankle deep is all it took, I was standing in it pushing the car out of this puddle, amazed and pissed that the water was only a few inches high.
St. Jude Donor '09
Silver05GTO, I appreciate you posting up your experience. Sorry it happened, but glad to see you're looking out for others. I'd like to know more about the details of what was damaged and what you wound up doing to fix it if you don't mind. PM me if you want.
San
San
