Why is my Spec clutch sticking to the floor ?
Just put in a Spec 3plus single disc and when racing or shifting real fast it will stick to the floor between shifts and then pop back up.
My car is an 07 Z06 that makes 530rwhp.
any help ? Fluid was just changed also.
If you overheat the fluid, ANY TIME, it will stick to the floor, and will need to be changed out again. I slid the clutch too long on a start today myself, and the clutch stayed on the floor. It was fine the rest of the day, but when I came home and looked at the fluid, it wasn't clear anymore, was dark again. So more work for me.... My guess is your fluid is cooked, and your driving is the cause.
Considering the mechanics of a pressure plate/clutch assembly, I am still at a loss to figure out how the hell the clutch fluid condition can affect the pedal staying down. Somewhere in there is a **** poor design. The C6 is the only car I have ever owned that had/has this particular issue. Can anyone explain the mechanics of why the pedal sticks? I mean the pressure plate still pushed back out, is the fluid so poor that it loses is compressability?
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
Cerino:
Actually, I've had this happen on the first year G35 coupe, and I was shocked (relatively torquey car but no 400+ lb. ft. of torque!!!). Had never had it happen before on any man trans car, and I've owned quite a few. Nor has it happened yet, on the C6.
One thing to try since it's cheap and easy is to reduce clutch throw. My stock '05 used to have this problem, but never again in 4 years. Now when my fluid is cooked, the clutch is not as smooth, but doesn't get hung up anymore.
Here's how I did it with a 50 cent window track lock:
http://forums.corvetteforum.com/phot...00/ppuser/6747
This gizmo clamps backwards onto the clutch arm 'nubbin' that engages the floor cut out switch. Now the head of the track lock bolt sticks out about a 1/2 inch closer to the switch, effectively reducing clutch throw.
The pedal sticks to the floor only when the disc super heats. That then heats the pressure plate/springs making them less effective until it cools down a few seconds later. Slipping a clutch heats the disc. Hard shifts cause heat because its again slipping. More clamping power = less slippage and less prone to the dead pedal because the springs are stronger with a different heat weakening threshold for a dead pedal.
Location: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
I am aware of the posts caused by a correlation that lead a member to push the idea of the fluid being responsible for the pedal sticking issue (I change my fluid and it doesnt stick doesnt mean the fluid chage prevented the problem). Proof of this is simple: people with a sticking pedal who change fluid still get the dead pedal.....it doesnt fix the problem. Heated or discolored fluid doesnt cause the fluid to not be a fluid which doesnt compress. If the volume of a fluid in a line is constant, the pedal will operate hot or not.
imo, there are a multitude of potentials that will cause the pedal to remain on the floor.
imo, i would look at: the 'adjustment', then clamping strength, then (internal) return strength (spring/fingers,etc.). this assumes () the fluid is fresh and full.
which spec did you get? what is it rated at?
yeah, what he said.
