Brake pads for Street?
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
you may want to ck out some other brands as well. fading, not holding in your situation would NOT be a good thing.
St. Jude Donor '08
Mine faded badly when I would push it a little. I have not had the same problem with the 1521's yet. I have pushed them much harder than the GM ceramics and no fade yet so I'll keep my fingers crossed!
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
Update:
Installed C5 Z06 pads last night and went for a drive. I didn't do anything to the rotors.
- They are definitely compatible with Carbotech pads. I knew backing out of the driveway that they had bite. First stop was good with good initial braking.
- After braking hard from 60-20 three times I could tell no difference.
- Braking from 80-40 proved reliable and predicable. Good initial bite, good progressive braking with additional application of pedal force.
Time will tell how I like the dusting, but so far it looks like this is going to be my street pad.
