AEM Wideband install...
Old 08-26-2008, 02:59 PM
Modshack
Modshack's Avatar
Default AEM Wideband install...
Followed C6Antwon's lead on this one...Now to break out HP tuners and do a little tweaking on my Spinmonster tune...
Old 08-26-2008, 04:01 PM
6Speeder
6Speeder's Avatar
Looks good. Where did you run the wires through the firewall?
Old 08-26-2008, 04:12 PM
Modshack
Modshack's Avatar
I actually scratched my head on this a bit, and ended up running them around the front edge of the Tunnel plate and up through the shifter opening. Dremeled a small notch in the front corner of the raised lip around the shifter hole so the rubber plate would seal again when re-installed, ran wires down the side of the console and turned left to go across the dash to the gauge.. Power ground leads were run across to under dash area and through the console to the footwell fusebox for power and ground..Not too bad actually..
You can see the O2 wires making the turn at the tunnel plate here:
Old 08-26-2008, 04:18 PM
ZPirate
ZPirate's Avatar
Looks good Steve. I'm glad to see you got it all hooked up and buttoned up. Your interior certainly looks better than when I saw it on Sunday afternoon.
Now you can really see how your car is running.
BTW the dealer had to order a new computer for my truck. The PCM apparently went off the deep end.
Old 08-26-2008, 04:21 PM
Modshack
Modshack's Avatar
...Yeah, it was in MANY pieces!
To AEM Wideband install...
Quick Reply: AEM Wideband install...
