EnglandGreen Insanity Specials !!!!
Supporting Tuner
ENGLANDGREEN INSANITY SPECIALS
The following package specials are for ANY 1997 to 2009 Corvette – Coupe, Z06, Vert, FRC, doesn’t matter. Any late model Corvette is covered.
* Package 1 - $2395 (normally $2895)
• EnglandGreen Custom Cam install with custom street computer tuning for driveability and performance.
* Package 2 - $4290
• EnglandGreen Custom Cam install with custom street computer tuning for driveability and performance- $2395 (normally $2895)
• LG Pro header system, high flow catalytic converters, x-pipe and midpipe -$1895 free installation with cam package (normally $2295)
* Package 3 - $4689
• EnglandGreen Custom Cam install with custom street computer tuning for driveability and performance - $2395 (normally $2895)
• LG Pro header system, high flow catalytic converters, x-pipe and midpipe - $1895 free installation with cam package (normally $2295)
• Vararam - $399 installed (normally $450-$750 installed depending on year and model)
All EnglandGreen custom cam packages include – EnglandGreen custom grind cam, all GM gaskets and seals, LS2 timing chain, High volume, high flow oil pump, 160 degree thermostat, Patriot Extreme dual valve springs with titanium retainers, chromoly hardened pushrods, 25% underdrive crank pulley and new serpentine belt
SEE THIS LINK FOR MORE CAM DETAILS
Stop Press!!!!
For the A4 automatic cars that will require a stall converter with our cam packages, will are offering the RPM Transmission torque converters in any stall speed for $1095 installed. Normal price is $1495. This offer is only valid in conjunction one of the above cam packages.
A La Carte Packages
* Cold Air Intake Packages
Vararam CAI C5 $395 installed
Vararam CAI C6 $495 installed
* Header Package
$1895 with an insane $99 installation
$1995 Installed (normally $2295 to $2495 depending on year and model)
* Gears Packages
RPM Transmissions Differentials
• C5 Micropolished Gears, (any ratio 3.15 to 4.10), HD Clutch packs, C6 Z06 left side shaft, Media blasted case, new seals
$1495 installed (normally $1795)
• C6 Micropolished Gears, (any ratio 3.15 to 4.10), HD Clutch packs, C6 Z06 left side shaft and C6 Z06 two piece right side shaft, Media blasted case, new seals
$1795 installed (normally $2245)
• C6 Z06 Micropolished Gears, (any ratio 3.15 to 4.10), Upgraded carbon Clutch packs, 300M left side shaft, 300M 2 piece right shaft, media blasted case, HD preload springs, new seals
$3095 installed (normally $3545)
For the C6 A6 folks, we are offering RPM Transmissions 3.15 gears, installed with all fluids and includes transmission tuning
$2195
For the A4 2.73 C5 folks, we are offering a brand new GM C5 Z06 differential with 3.42 gears
$1595 installed
* Clutch Package
Textralia OZ 700 Z-Grip clutch and billet flywheel, GM Master cylinder, GM slave cylinder, remote bleeder, pilot bearing, GM flywheel bolts.
$1995 installed (normally $2295)
* Torque Converter Package
RPM Transmission torque converter in any stall speed
$1295 installed. Normal price is $1495.
* Suspension Packages
Pfadt Coilovers $1790 with $199 install
$1989 installed
Pfadt Street Adjustable Swaybars $845 with $99 install
$944 installed
* Street Tune
Full custom street tuning adjusts your spark, air fuel ratio, automatic shift points, etc. for performance, throttle response, gas mileage and driveability. Stock C6/C5, catback, CAI and headers only. No heads/cam/forced induction.
$199 (normally $400)
So what prompted this madness?
Well, EnglandGreen Inc. in Florida and Gulf Coast Performance Inc. in Texas merged forming a new corporation, EnglandGreen Corp. based in Houston, Texas.
Both Jason and Stephen had birthdays recently, then we had the merger – and Stephen recently became a US citizen so we thought we would have a completely insane sale. This sale is crazy and yes, we know that we’ll be taking a bath on some of these specials!!
EnglandGreen relocated to Houston over 30 days ago so it's time for some specials and a grand opening party!!!!!!!!
ALL OF THESE SPECIALS WILL LAST UNTIL MIDNIGHT ON THE DAY OF THE GRAND OPENING PARTY WHICH WILL BE OCTOBER 12th, 2008 (Thanks to Hurricane Ike )
Here at EnglandGreen, we treat all of my customers like our friends and focus on long term repeat business. And we are Corvette owners as well.
Jason's personal 2002 Coupe, Kjun, is heavily modified with a 402ci LS2 twin turbo engine, Whiplash cam, tricked out drivetrain etc. From the latest build with his new massive turbos, he should be somewhere North of 1000 rwhp. Stephen's personal 2001 Coupe, Grond, is running a forged 402ci LS2, Paxton supercharger, Insanity cam, coilovers, hand built tubs, shaved door handles and lots of other custom goodies. All lovingly hand built in-house and our ongoing projects.
We only work on 1997-2009 Corvettes (Generation 5 & 6 Corvettes) and nothing else. And by specializing to such a narrow field, we feel that we can offer what no other Tuners across the entire US can offer - specialized, focused, in-depth expertise.
Please feel free to give us a call to discuss your requirements. You are always welcome to come down to the shop to see what's going on at EnglandGreen. Just call first to make sure we are in. Our hours are Mon-Fri 9am-6pm & by appointment on weekends.
Stephen Rawlins & Jason Theriot
281 464 2800
sales@englandgreen.com
P.S. If you can make it to our Grand Opening Party, please RSVP here: We will have a few giveaways and food for everyone!!!
Attendance List :
Monterrey Bill
Crankshaft
c6user
TXZ0603 - 3
F4 Woozzo
mojo 1 - 2
NTRBL33
DeadFred
admoreno
Tom/99 - 2
falcn1 -2
peter pan
Mike-C5
GO4URS - 2
cgmoose - 2
back 40
Mojo 97 Vett
blazeone
Snowman
Dashbac
Dr. Sumting Wong
oyealiz
VaraRam - 5
Jeff H.
gonbad
DavzC5
LoneStarFRC
gonzo4496 - 2
Black 00 Coup - 6
Aggie John
Lord Vetter - 2
snide
BlueC5Kitten
ProjecT 9
illmac77 - 2
gotjuice?
ZR1BOB
Wow - good prices.
St. Jude Donor '07-'08-'09
What can we do for a wideband A/F install (Nexus), install FP, and NP gauges in a triple pillar - and install/tune 150 shot dry n2o kit????
Stephen, Jason, buddies - we got to talk.
You guys could be the only ones in Houston doing this.
OK buddy. I'll be the guinea pig. Let's do it. My goal is to maintain 500/500 rwhp/tq on all motor (which I have now) with 650/650 rwhp/rwtq on spray. I want to run 9s around 140 mph trap on N2O on a dialy driviable 10 second all motor car. Who can rise to the challenge.
I want all the bells and whistles on the N2O kit- the best reliable N2O solenoid, rpm window, auto FP shudown switch, purge lines, bottle warmer, and auto AFR sutdown.
We'll call her --- DEMON RAY 1
Supporting Tuner
Location: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Supporting Tuner
ttt
Supporting Tuner
Give us a call when you are ready.
Stephen
281 464 2800
Stephen
281 464 2800
1 Post
Stephen, I have talked to you several times on the phone. Have you fully relocated to Houston? If you are still in the area(Vero) PM me. I will be calling. Houston should be advised that they now have access to one of the best Corvette tuners around.
Supporting Tuner
I'm in Houston. Been here for the past month
