You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
i suppose i'll run a 17" drag radial at the track once i get a stall and converter,
seems like the 3600 stall is the way to go, but wondering which gear would be best as well
3.42, 3.73, or 3.90
if i'm going to stay at the power level i'm at now, i hit 120.46 in the heat with stock gears, whats going to put me going through the traps at the top of 4th, still in 3rd with the 2.56's with a little left
__________________
Stainless Works / Vortech Superchargers Sponsored
2011 Mustang GT 5.0 - 9.99@142.39 http://www.teambeefcakeracing.com
Sold
08 C6 - 10.87@131
00 C5 Vert
00 C5 Coupe
The A6 is a different animal. It has very short gears across the board. The A4 has a 1.0 third gear, the A6 has a 1.53 third. Also, it doesn't need the .5 od because it has a 2.56 final drive. Multiply the gear ratio in each gear by the final gear ratio to look at the whole picture.
yes, but when you go to a 3.42, 3.73 or better, then that takes the gearset out of the equation
If you run a 3.73 or better with the A6, then 1st gear will be useless and all you will do is turn your 6 speed into a 5 speed. Plus, when is the gearset ever out of the equation?
The last time I looked, the equation was (engine torque X transmission gear ratio X rear end ratio) - drivetrain losses = wheel torque. I just assumed he was trying to make some other point and didn't state it very well. Who knows...
Here's an interesting comparison...2 cars VERY similar mods except I've got 3.90 gears and he's got 3.42's. I've got .5 more compression but he's got a FAST.
Here's our dyno sheets overlaid based on RPM on the X-axis. Looks like the same car huh!
But look here - I changed it to MPH on the X-axis, you can see the effect of gears. I have 24 more RWHP at 55 mph up to 47 more at 90 mph! That's why gears make the car feel so peppy.
__________________
2005 Vert Z51 MZ6
Mods by Horsepower Sales 954-984-8040
4:10's, FAST 92, A/R Headers w/cats, G5x3, AFR 205 heads ORIG CLUTCH (70k miles & 490 drag strip passes)
474rwhp/414rwtq
Best pre-cam:1/4-1.730, 11.810@118.76
Best w-cam, pre-FAST 1/4-1.666, 11.540@121.39
Best w-cam & FAST 1/4-1.519, 10.995@126.67 DA-793
Best w-cam & AFR heads 1/4-1.445, 10.815@128.07 DA-581 1/8-1.445, 6.920@99.15 DA-581
Top speed 185 (so far...) 0-60 mph 2.59 sec (track)
But at 140 MPH, the 3.42 car has ~430 HP more than you.
