Some more ported intakes and tuning results, FAST, LS7
Old 07-30-2008, 06:20 PM
0Fasterproms
Former Vendor
Fasterproms's Avatar
Default Some more ported intakes and tuning results, FAST, LS7, LS3
Here is another ported LS2 GTO w236/240 cam to that had been fully optimized then upgraded the manifold to a ported FAST and then tuned for.
Here is one of the higher gains we have had porting a FAST on an A-B test.
Here is another Z06 w/ typical results from stk w/ KN to tuned to ported intake
SO we heard somewhere that the ported LS3s werent picking up any power...We have not seen that as the case. There is plenty of room for improvement on this manifold as well as the L76, they are almost the same manifold. Here are a few bolt-on Ls3s before and after porting.
Thank you
Jeremy Formato
Old 07-30-2008, 06:31 PM
danl72
danl72's Avatar
Great numbers.
Old 07-30-2008, 06:43 PM
Wallacefl
Wallacefl's Avatar
any LS3 #s
Old 07-30-2008, 07:08 PM
0Fasterproms
Former Vendor
I reposted with some LS3 graphs as it came to my attention that I needed to put some up there and that there was a rumor that they dont pick up any power.
Jeremy
Old 07-30-2008, 08:36 PM
SlickShoes
_Sloth Whisperer_
Support Corvetteforum!
SlickShoes's Avatar
Whats up with the choppiness in the top end of the LS3 graphs? It seems especially prevalent considering the smoothing was set to three as well.
AFR's could use some polishing here and there, too. Sorry to nitpick. Regardless, the gains are certainly significant. Good job extracting the power.
Old 07-30-2008, 08:40 PM
02gt350
02gt350's Avatar
i just built a 416 LS3 and my intake and Tb is choking me to death. what is yoru cost and turn around time for a port job on both...and I mean port the living **** out of them
Old 07-30-2008, 08:51 PM
Ragtop 99
Ragtop 99's Avatar
Received 1,172 Likes on 677 Posts
Nice gain on the header LS3 car. It is hard to tell, but did the tune change a bit, or is that the natural varation in A/F that can occur just as part of the dyno process?
PM sent.
Old 07-30-2008, 09:00 PM
Daytona Bob
Daytona Bob's Avatar
St. Jude Donor '09 & '12, '14
awesome!!
Old 07-31-2008, 11:01 AM
0Fasterproms
Former Vendor
We can do a very aggressive porting that would be a great advantage for you. For both the intake and TB it would cost $400.00 when done together, vs $300 and $150 when done separately.
If you would like these, just give us a call at 813 476 7364.
Thanks,
Dan
Old 07-31-2008, 11:23 AM
0Fasterproms
Former Vendor
Slick shoes- as far as the chopiness, we did have some spk lead issues and there may have been some knock on either of the runs. Bare in mind that the second (LS3) are not the final pulls fully tuned. I believe that I did 11 pulls er so. The 9th pull made less peak bc of the spike but more avg power.
I wanted to show some of the graphs with minimal tuning, others I show fully optimized such as the Z06 and the LSX. I am trying to be as fair as possible.
Jeremy Formato
Old 07-31-2008, 07:01 PM
Wallacefl
Wallacefl's Avatar
great numbers...I think it is going to be difficult for the upcoming Weiand/Fast LS3 manifolds to provide significantly higher numbers the these...but then if you port them
Old 07-31-2008, 11:14 PM
Finster07
Finster07's Avatar
Excellent numbers Jeremy!
Hey, do you have any numbers for the LS-2 with just bolt-ons, including a ported FAST (no cam)? I was curious as to what you have seen.
thanks
Old 08-01-2008, 04:09 PM
0Fasterproms
Former Vendor
Here are some typical gains some are with tuning and some without.
Old 08-05-2008, 11:48 AM
0Fasterproms
Former Vendor
We will be headed up to indy for a few days and then to PA for the carlisle show. Let us know if we can help you out.
Jeremy Formato
To Some more ported intakes and tuning results, FAST, LS7
Quick Reply: Some more ported intakes and tuning results, FAST, LS7
