Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 07-09-2008, 02:44 PM   #1
tonycorvettehd
CF Senior Member
tonycorvettehd's Avatar
Default ok im lost - program spare key fob ?
i bought a num 1 key fob on ebay with instructios,but they dont work,i have an 05 with push button ignition with a working number 2 ,,,please guide me ,,,thanks guys tony
tonycorvettehd is offline
Old 07-09-2008, 11:47 PM   #2
'VETTE PHASE
CF Senior Member
Cruise-In VIII Veteran
'VETTE PHASE's Avatar
Method 1 - Key Fob Quick Learn
This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
1. The vehicle must be OFF.
2. Open the rear compartment.
3. Place a known key fob within the interior of the vehicle.
4. At the rear of the vehicle insert the vehicle key in the rear compartment lock cylinder located in the lower left and cycle the key 5 times within 5 seconds.
5. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4).
6. Place the replacement key fob in the glove box fob pocket with the buttons facing right.
7. A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED.
8. If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode.
9. Operate the active portion of each key fob to exit the programming and to verify correct system operation.
The number on the fob doesn't have anything to do with Driver Number. If you are wanting to change your fobs so that Fob 1 corresponds to Driver 1, I believe you will have to go to the dealer and hook it up to a Tech II.
Method 2 - Key Fob Slot Programming
This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicle mechanical key, and a scan tool.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
5. Install a scan tool.
6. Use the scan tool, to access the following:
• Vehicle Control Systems
• Computer/Integrating Systems
• Module Replacement/Setup
• RCDLR
• Program Key Fobs
7. Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to.
8. Place the replacement key fob in the glove box pocket with the buttons facing right. A beep will occur indicating programming completion. The previously known fob is now erased.
9. If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming.
10. Remove the scan tool.
11. Operate the active portion of each key fob to exit the programming and verify correct system operation.
'VETTE PHASE is offline
Old 07-10-2008, 12:54 AM   #3
JimTN
Moderator
Support Corvetteforum!
JimTN's Avatar
The fob that you have that is not yet programmed for your car can only be programmed as a #1 fob or a #2 fob by using method 2 in the post above by 2000C-5. YOU MUST PROGRAM BOTH FOBS, even the one the car already recognizes, when you use that procedure.
If you screw it up, it's possible you could wind up with no fobs that will start your car and your car would have to be flat-bedded to the dealer to fix it.
JimTN is online now
Old 07-10-2008, 02:18 AM   #4
mraoshi
CF Senior Member
• RCDLR
• Program Key Fobs
thank you so much !!!!
let me tell you guys something, I went to a Chevrolet Dealer with my 08' C6, to get 2 new keys and keyfobs.
I went to the parts department and ordered 2 key fobs and keys, when they came in, I went to pick them up, and made a appointment with the service department.
The next day, I went to the service department at 8 O'Clock. The service technician told me that I couldn't use the new 08 FOBs, and needed to use the old FOBs. I was surprised... So I exchanged one of the 08 ones for a older version, but kept one of the new 08's because I had a hunch it could work..
So I had to come in again at 11:00, because they had to order the FOBs. Then after a hour and a half of waiting, at 12:30, the service tech told me that. "their programmer was malfunctioning, it says its okay, but then it doesn't work", and told me to, "maybe call us tomorrow and see if its working, or you could try another chevrolet dealer'.
So I went home, having wasted a lot of time.
Then I went on Corvette forum and found your post, followed it. and programed both my new keyfobs. the 08' version and the old version... all by myself.
It's pretty ridiculous that the service department of a Chevrolet dealer can't do what I just did by just following some very very useful instructions..
mraoshi is offline
Old 07-10-2008, 05:30 PM   #5
'VETTE PHASE
CF Senior Member
Quote:
Actually, if you wanted to start from scratch, you can. It works the same way as Method 1 above, except that it takes 30 minutes before it will start the programming. The DIC will countdown the 30 minutes for you and say "Ready for Fob 1". I guess the 30 minutes is so that someone can't jump in your car and program a fob real quick to steal your car.
Old 07-10-2008, 09:15 PM   #6
tonycorvettehd
CF Senior Member
Default got it
it worked ,thanks im loving this c6
Old 07-19-2008, 02:02 PM   #7
Beatitt
CF Senior Member
My DIC will not display anything when I cycle the key. I've followed the instructions so I don't know what I'm doing wrong. I'm trying to just re-program my #2 FOB.
Beatitt is offline
Old 08-05-2009, 09:43 AM   #8
Sonic03inSC
CF Senior Member
Sonic03inSC's Avatar
Quote:
Same issue here, anyone help?
__________________
Sonic Blue 03' Cobra 609rwhp SOLD
Silver 2006 Z06
Sonic03inSC is offline
Old 08-06-2009, 02:33 AM   #9
Kent1999
CF Senior Member
Kent1999's Avatar
Quote:
For C6's that won't go into "fob learn mode", try this...
http://forums.corvetteforum.com/1570351932-post19.html
Cheers,
Kent
Kent1999 is offline
Old 08-06-2009, 03:48 AM   #10
Barzten1
CF Senior Member
Barzten1's Avatar
subscribed
Barzten1 is offline
Old 08-06-2009, 04:05 AM   #11
Ed 718
CF Senior Member
Ed 718's Avatar
Send a message via AIM to Ed 718
Quote:
Originally Posted by Barzten1 View Post
subscribed
Welcome to the forum Jason and good to see you join out forum. If you have any question let me know brother.
Ed
Ed 718 is offline
Old 05-06-2010, 12:13 AM   #12
bugzweiser
Junior Member
anyone know if the newer style key fob will program to my 2006
bugzweiser is offline
Old 05-06-2010, 12:55 AM   #13
JimTN
Moderator
JimTN's Avatar
Quote:
Yes, but the key that comes with it will not work in the 2006 key slot over the rear license plate.
JimTN is online now
Old 05-06-2010, 06:38 AM   #14
mvcrash
CF Senior Member
mvcrash's Avatar
Start a new one.
mvcrash is offline
Reload this Page ok im lost - program spare key fob ?
Closed Thread
Tags
2006, box, c5, c6, corvette, dic, fob, fobs, glove, key, options, program, programming, slot, tech, unavailable
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
