Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-18-2008, 07:59 PM   #1
Nickvet
CF Member
Nickvet's Avatar
Default questions on vararam install - please help
I’m sorry if these questions have been asked before. I’m installing my Vararam today and have come across a few installation issues/questions.
First of all, what’s the gasket-type 33 inch length of tubular black rubber that’s supplied with the kit?
Second, is anyone using the throttle body spacer – is it worth it?
Lastly, it seems to me the opening I cut in the shroud has large gaps on the sides. Is this what you have also, and will it allow a lot of debris into the engine compartment? I think someone said they used duct tape to seal the gaps.
Thanks a lot for any input you can provide.
Nickvet is offline   Reply With Quote
Old 06-18-2008, 08:48 PM   #2
FUNTRUN
CF Senior Member
Support Corvetteforum!
FUNTRUN's Avatar
Default Vararam help
The 33" gasket is what they give you to line the cutout. I didn't bother to use it myself. I am using the spacer. It was easy to install & I figured, what the heck ,I've got it I might as well use it.
Don't worry so much about the size of the opening as long as the unit fits and is not hitting on any side. When your done you can use tape to seal up the unit so debris doesn't become an issue. You can also make an intake shroud cover using sheets of black plastic that you can buy at any plastic/foam outlet. Or you can buy one from one of the forum venders.
Enjoy.
Dan
FUNTRUN is offline   Reply With Quote
Old 06-19-2008, 09:35 PM   #3
PeterM
CF Senior Member
PeterM's Avatar
Default Fit and finish
The Black Duct tape (Duck Brand) is made to order in this case. Take your time and you can really finish things off quite nicely. Here is the install information I'd posted a few weeks ago: http://forums.corvetteforum.com/show....php?t=2040131
PeterM is offline   Reply With Quote
Old 06-19-2008, 10:11 PM   #4
Nickvet
CF Member
Nickvet's Avatar
Thanks Dan - I appreciate your response. Today I measured the gap. It was 3 inches on top so I riveted a piece of the shroud I cut back onto the original. It worked out well and with the supplied gasket the gap is now only about a half inch at most all the way around. I didn't use the spacer since I didn't have any additional patience at the time. I also spoke with Patrick at Vararam and he was very willing and helpful. He spent a good 35-40 minutes on the phone with me. Top notch guy.
Old 06-20-2008, 04:11 PM   #5
pc07vette
CF Senior Member
Still can't for the life of me understand why Vararam can't provide a template that cuts the opening the correct size. It's a shame that anyone should have to use a $5.00 roll of duct tape on a $40,000 dollar Corvette. I know most people really like the added performance but duct tape?
pc07vette is offline   Reply With Quote
Old 06-20-2008, 04:27 PM   #6
Maui
CF Senior Member
St. Jude Donor '08
Maui's Avatar
Send a message via AIM to Maui
I just taped the template over the shroud and cut it with a box cutter. I set the blade as low as it would go and no issues. Mine came with a nice piece of moulding that went around the cut afterwards. It looks and functions just fine.
Maui is offline   Reply With Quote
Reload this Page questions on vararam install - please help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Air Induction Options MrLeadFoot C5 General 16 08-02-2004 02:52 PM
Vararam Users....Specific Install Question, Please Help?! Mean Green C5 Z06 Discussion 10 08-22-2003 12:52 PM
vortex rammer or blackwing?? 88sk C5 Tech 15 05-28-2003 05:34 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
