Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-16-2008, 01:10 PM   #1
C6Antwon
CF Senior Member
C6Antwon's Avatar
Default AEM wideband gauge installed! (PIC)
Here is a pic of my recently installed AEM wideband gauge. I didnt want to put a double or triple gauge pod in, because...well...I dont need the extra gauges. I hope this helps some of you thinking about putting gauges in your Vette, but dont want a pod.
So I chose to put it here:
Click the image to open in full size.
Thanks,
Anthony
__________________
455rwhp::::422rwtq
::07 Z06 Trans/Rearend::
::Centerforce Clutch::
::IPS Stage2 Heads::
::Custom Comp Cam::
::Kooks 1 7/8 LT's::
::Bassani Exhaust::
::Ported TB::
::Vararam::
C6Antwon is offline   Reply With Quote
Old 06-16-2008, 03:20 PM   #2
LEAVINU
CF Senior Member
LEAVINU's Avatar
Lamarwaldenautomotive
Seems to be becoming a common location for these now. However the last pic I saw of another members location was @ 1" above the vent.
Yours seems to be the top portion of the vent so how was that done? Also is there any issue with heat/cold air blowing on the back of the gauge if it is indeed in the vent?
Nice gauge though- I have thought about one of these a few times.
LEAVINU is offline   Reply With Quote
Old 06-16-2008, 03:57 PM   #3
danl72
CF Senior Member
danl72's Avatar
Send a message via Yahoo to danl72
Nice.
danl72 is offline   Reply With Quote
Old 06-16-2008, 04:40 PM   #4
C6Antwon
CF Senior Member
C6Antwon's Avatar
1: Take the bezel out of the car that goes around the vent and around the cluster.
2: Remove the air vent held in by 2 clips to the back of the bezel/surround.
3: Take the air vent that you removed and do some modification to it by cutting it in half only leaving 3 of the horizontal vents still intact.
4: Take your gauge and wedge it in the air vent oval. Secure it using the strap from the back that comes with the gauge and the 2 nuts that screw to the back of the gauge.
5: Run all of your hookups and reinstall the bezel and you're done!
I have not noticed any issues with hot/cold air on the back of the gauge. I have even done this to multiple cars that I have had also!
__________________
455rwhp::::422rwtq
::Custom Comp Cam::
::Bassani Exhaust::
::Ported TB::
::Vararam::
Old 06-16-2008, 07:16 PM   #5
Corpsvette
CF Senior Member
Corpsvette's Avatar
Nice install but I noticed your breaking the speed limit and almost out of gas
Corpsvette is offline   Reply With Quote
Old 06-16-2008, 08:19 PM   #6
red06c6hm
CF Senior Member
You have headers for the wideband sensor bung, or did you install it into the cat casing on the stock exhaust?
red06c6hm is offline   Reply With Quote
Old 06-16-2008, 09:22 PM   #7
MrDrezzUp
CF Senior Member
MrDrezzUp's Avatar
What is great about that install is looks like you only have to cut the vent. Is that correct? If that is correct then returning the car to stock would entail the purchase of a replacement vent, rather then replacing the dash.
MrDrezzUp is offline   Reply With Quote
Old 06-17-2008, 04:49 AM   #8
C6Antwon
CF Senior Member
C6Antwon's Avatar
Quote:
Yes I have Kooks 1 7/8 LT's....I installed the sensor in the rear o2 bung since I have the rear o2's turned off with HPTuners.
Quote:
Yes you only have to cut the vent! Returning to stock would be as simple as buying a new vent from the dealer, RATHER than replace the whole dash.
__________________
455rwhp::::422rwtq
::Custom Comp Cam::
::Bassani Exhaust::
::Ported TB::
::Vararam::
Old 06-17-2008, 07:21 AM   #9
Mardis Gras
CF Senior Member
Support Corvetteforum!
Mardis Gras's Avatar
Nice work with a finished look
Mardis Gras is online now   Reply With Quote
Old 06-17-2008, 07:47 AM   #10
ben dover
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. TX
Looks like it belongs there.
ben dover is offline   Reply With Quote
Old 06-18-2008, 10:11 AM   #11
C6Antwon
CF Senior Member
C6Antwon's Avatar
Thanks guys. Everyone that has seen it has said the same thing...."It looks factory!"
__________________
455rwhp::::422rwtq
::Custom Comp Cam::
::Bassani Exhaust::
::Ported TB::
::Vararam::
Old 06-18-2008, 04:35 PM   #12
n77nxc
ZO6 Owner
n77nxc's Avatar
Killer install...I have the same wideband on mine, and I'm digging your install. I might just have to give it a shot this weekend.
n77nxc is offline   Reply With Quote
Old 06-18-2008, 07:55 PM   #13
MrDrezzUp
CF Senior Member
MrDrezzUp's Avatar
I don't know what I like better...how slick this install looks...or that you don't have to carve up your dash or put a plastic A-pillar on!
Again...Great work!
Old 06-18-2008, 11:07 PM   #14
ChargedC6
CF Senior Member
ChargedC6's Avatar
nice! i have that and the matching aem boost also best gauges IMO.
ChargedC6 is offline   Reply With Quote
Old 06-19-2008, 02:49 AM   #15
Sportsdude
CF Senior Member
Sportsdude's Avatar
Nice install
Sportsdude is offline   Reply With Quote
Old 06-19-2008, 09:15 AM   #16
C6Antwon
CF Senior Member
C6Antwon's Avatar
Again...Great work!
Old 07-05-2008, 10:12 AM   #17
carlrx7
CF Senior Member
St. Jude Donor '08-'09
carlrx7's Avatar
ive had my AEM UEGO sitting in my garage for like 2 years now. it was gonna be installed in my previous car but i couldn't find a location to install because it had airbags in the a-pillars. i think im gonna do this when i install my LT's
p.s. do you run cats? or ru using the off-road pipe?
-carl
carlrx7 is offline   Reply With Quote
Old 07-05-2008, 10:50 AM   #18
C6Antwon
CF Senior Member
C6Antwon's Avatar
-carl
Im using a borla off-road x-pipe.
__________________
455rwhp::::422rwtq
::Custom Comp Cam::
::Bassani Exhaust::
::Ported TB::
::Vararam::
Old 03-06-2011, 06:36 PM   #19
Rosspbig
CF Senior Member
Does this gauge have a dimming feature that dims it when your headlights come on?
Rosspbig is offline   Reply With Quote
Old 03-06-2011, 10:16 PM   #20
Blk 08 C6
CF Senior Member
Blk 08 C6's Avatar
Send a message via Skype™ to Blk 08 C6
nice great info.would have to consider this when I go FI and LT headers.
Blk 08 C6 is offline   Reply With Quote
Reload this Page AEM wideband gauge installed! (PIC)
Tags
aem, band, c5, c6, corvette, gauge, gauges, install, installation, installed, installing, oem, pod, wide, wideband
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
