Z06 Oil Cooler bolts right on to LS3/Z51 oil lines!!!
Old 05-17-2008, 03:50 AM
jbsblownc5
Support Corvetteforum!
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
Default Z06 Oil Cooler bolts right on to LS3/Z51 oil lines!!!
On my last trip out to Spring Mountain my oil temps hit 290 on my last lap. I see 270 on a hard mountain run. After looking at my options, and doing some research, the Z06 oil cooler seemed like a good choice.
I got a good deal on a next to new cooler, and decided to see if my Z51 lines would mate up with the Z06 cooler. The Z51 cooler lines are in the same position as the Z06 lines where they enter the cooler. The Z06 cooler is about 3 times the size of the Z51 cooler, but starts off in the same place, and goes clear across the shroud. I checked on the part # of the both Z06 and Z51 lines, and they were different, but the end of the Z51 line slid right into the Z06 cooler, and the same clips now hold it in place. The holes to mount the Z06 cooler where already present on the far side of the shroud, so it bolted right in. I guess it's the same shroud.
I started the car, and there are no leaks!! The Z06 cooler even fits nicely with the Vararam!
I've got a nice long Canyon run planned for Sunday, and it's a bit hot here in LA, so it should be a good test!!
Old 05-17-2008, 05:38 AM
FLZ_Boy
FLZ_Boy's Avatar
Have you done the Z06 front brake duct extensions yet? I guess I'll also add another to your list of toys you need: Z06 differential cooler.
Nice information to know on the oil cooler though.
Old 05-17-2008, 06:35 AM
SeanMo
SeanMo's Avatar
St. Jude Donor '10-'11
WOW great find! very useful
Old 05-17-2008, 07:31 AM
timd38
timd38's Avatar
Thanks!
How much was the Z06 cooler?
Old 05-17-2008, 08:24 AM
valdeztke
valdeztke's Avatar
Originally Posted by timd38
Thanks!
Old 05-17-2008, 08:28 AM
Jim_H
Jim_H's Avatar
dealer $620
GMpartshouse.com $459
Old 05-17-2008, 09:23 AM
NYC6
NYC6's Avatar
Old 05-17-2008, 09:29 AM
RFP
RFP's Avatar
St. Jude Donor '09
Great post!
Were you able to do the install without removing the front bumper cover? Did it install from "the top down" or "up from the bottom?"
Old 05-17-2008, 09:58 AM
pmj341
pmj341's Avatar
St. Jude Donor '08-'09-'10
Default Oil Cooler
the oil cooler swap sounds great, what temps did you run in NORMAL city driving vs highway driving?? and how does that compare to the Z cooler??
I'm glad you shared this info, I live in Florida and the temps get up there,
I plan to run at Sebring Raceway and cooler oil temps will help.
THANKS!!!!!
Phil
Old 05-17-2008, 12:15 PM
tdelena
tdelena's Avatar
St. Jude Donor '12, '14-'15, '17, '20
Great info. I am curious to see how much better it cools.
Old 05-17-2008, 12:35 PM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
I've been meaning to get the Z06 ducts to go with my upgraded PF pads and Motol Fluid. Who's got the link to the best price on them??
Thanks,
JB
Old 05-17-2008, 12:36 PM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Thanks!
I got mine almost new for $250 delivered!!
Old 05-17-2008, 12:37 PM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Originally Posted by RFP
Great post!
I did the install without removing the bumper, and could do most of the work from the top down...
Old 05-17-2008, 12:45 PM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
THANKS!!!!!
Phil
My car is not a daily driver, and I don't do much "NORMAL" driving,
but I have a pretty good idea what temps were on the track and canyons. I will report back when I get some comparitive #s with the Z cooler.
Like I said, I'm headed out Sunday for a nice spirited drive in the mountain with very hot temps here in CA right now!
Reports are there will be a VERY HOT Torco Model on this run, pics to follow!!!
Old 05-17-2008, 01:59 PM
oldmansan
oldmansan's Avatar
St. Jude Donor '09
Thanks,
JB
http://www.vetteweb.com/tech/vemp_07.../photo_05.html
I'd like to know also. Anyone?
San
Old 05-17-2008, 04:14 PM
oldmansan
oldmansan's Avatar
St. Jude Donor '09
15829066 and 15829067 are the part numbers for the brake ducts I found here. I'll be giving Gene a call as they're all of around $15 for both.
San
Old 05-17-2008, 06:30 PM
Jim_H
Jim_H's Avatar
Z06 oil cooler $300 shipped
http://forums.corvetteforum.com/show...ghlight=cooler
To Z06 Oil Cooler bolts right on to LS3/Z51 oil lines!!!
Old 05-17-2008, 07:33 PM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Originally Posted by Jim_H
Nice find my friend, but this is the one I bought for 250...
Old 05-17-2008, 08:50 PM
Jim_H
Jim_H's Avatar
Why was it for sale?
Is there an aftemarket unit the Z06 guys switch to?
If so, the aftermarket piece should work for the Z51 too, probably works better and I wouldn't be surprised if it cost less.
Old 05-17-2008, 09:20 PM
RFP
RFP's Avatar
St. Jude Donor '09
Good point.... One would think that there would be an Earl's or a Setrab cooler that would work (as you said, probably even better!) at a slightly better price.
Quick Reply: Z06 Oil Cooler bolts right on to LS3/Z51 oil lines!!!
