Plating Gurus: Question about Chrome Plating Rear Sway Bar!
Old 04-18-2008, 10:00 AM
BarneyZ
Support Corvetteforum!
BarneyZ's Avatar
Default Plating Gurus: Question about Chrome Plating Rear Sway Bar!
I'm considering chrome plating my rear sway bar but am concerned that flexing might cause the plating to crack and flake off. Obviously I don't know much about plating. What do you think?
Thanks!
Barney
Old 04-18-2008, 11:58 AM
glennhl
glennhl's Avatar
Thanks!
Barney
If you do chrome plate, make sure you get the bake done right after plate to eliminate hydrogen embrittlement or your 1 piece sway bar will become 2 pieces. I think the chrome might have a tendency to crack.
Old 04-18-2008, 12:02 PM
Gotcha
Gotcha's Avatar
I had the rear bar on my C5 chromed by a local plating company. No problems at all and It looked good.
Old 04-18-2008, 02:25 PM
0JoshS
Former Vendor
JoshS's Avatar
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Instead of the chrome plating you should consider zinc plating. It is much less prone to flaking. Normal zinc plating doesn't quite have the luster that chrome does but you can do a acid zinc plating that is very good. The biggest thing you can do to ensure a good part turn out is to polish the bar prior to zinc plating.
Old 04-19-2008, 02:49 PM
BarneyZ
BarneyZ's Avatar
Thanks for your input! Any more thoughts out there?
Barney
Old 04-19-2008, 03:03 PM
Racer86
Racer86's Avatar
On most road racing cars, we use nickel plating. much safer on high stress suspension parts ,as you don't have to worry about Hydrogen imbrittelment with the chrome process, and the possibility of causing cracks
Old 04-19-2008, 05:08 PM
davekp78
davekp78's Avatar
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Springs on many motorcycles are chrome plated, and hold up OK.
Old 04-19-2008, 05:12 PM
saplumr
saplumr's Avatar
Received 1,251 Likes on 895 Posts
I don't see the problem.
Old 04-19-2008, 08:43 PM
glennhl
glennhl's Avatar
Good point! Guess you don't need to worry about the chrome cracking. However, again, be sure to have the sway bar baked at temperature to drive off the Hydrogen after plating. If not, there is a chance the sway bar will break due to hydrogen embrittlement.
Old 04-22-2008, 12:38 AM
Red86Cfour
Red86Cfour's Avatar
Bright nickel plating is also subject to hydrogen embrittlement. I use it on all my race car suspension pieces.
Old 04-22-2008, 06:34 PM
ground zero
ground zero's Avatar
How about powdercoated???
Old 04-22-2008, 11:03 PM
1fastLT
1fastLT's Avatar
How about Jet-hot coating... they have the new silver luster (or what ever it's called) and it looks great...
Old 04-23-2008, 05:14 PM
Invisiguard
Invisiguard's Avatar
lol, you know your on a corvette forum when people want to chrome-plate their swaybars.
To Plating Gurus: Question about Chrome Plating Rear Sway Bar!
Quick Reply: Plating Gurus: Question about Chrome Plating Rear Sway Bar!
