LS3 / LS7 Based 427 - What are the Differences?
With the LS3 using a 4.100" stroke and the LS7 using the 4.000", what would be the differences in each setup be (performance wise and dyno charts)?
Thx
Thx
what would the performance differences in a 427 (ls3) vs a 427 (ls7) be?
Ever so slightly better rod ratios on the LS7 I'd guess...Which would translate to an engine that would be safer at higher RPMs...I think the difference would be pretty small, but I guess I could be wrong
Performance wise and dyno charts: You would need to know more than just strokes. Cam size, head work, intake headers , tunning, etc. my LS3 427 made 525rwhp/500rwtq with a somewhat small cam, but had a lot of heads work done to the LS3 heads. There are all kinds of different paramaters to consider. I'm told that a 440 inch LS7 with head work and a small street cam can give as much as 580-600rwhp. for whatever that's worth. Again more info is need.
