Need help on Z06 exhaust system
You can't just buy the cat back portion and bolt it up. The cats on the regular coupe are 2.5" and the cat-back system of the Z is 3". The biggest gains from the Z06 exhaust system come from installing the Z06 exhaust manifolds (like shorty headers) and then the rest of the system. I recently did that and the love the sound but have not yet had the car dyno'd/tuned.
I have installed a 3" B&B cat back to the 2.5" cat on my CTS-V, and they fit well. I guess B&B made a special flange for this application.
So, if the flanges won't fit. I can weld a 3" - 2.5" adaptor to the Z06 over-axle pipe, connect it to the 2.5" stock H-pipe so I can use the Z06 muffler. Or, I can change the flanges to 2.5" so it will bolt on to the cat.
Will I gain any sound or noise, or am I wasting my time?
Thanks again.
The stock Z06 exhaust will a little louder than the stock C6 plus it will give you the option to install the hardware to use the open/closed system for mild to wild. There is also a mod you can do on the Z06 muffler to make it louder as well.
Let me ask you your experience with the Z06 exhaust, does it drone when the value is open? How about when it's closed? Is it loud enough for you when it is open?
I am debating between the Z06 and the B&B Fusion, Fusion sounds great to me, but it drones very bad!
Thanks.
Sound improvement is subjective, but the stock C6 system is so quiet that almost any change might be worth it.
Cheers,
kent
Premium Supporting Vendor
Is the stock flapper exhaust valve fully controlled by the operator? Or does it open and close at the same points every time like Volkswagen? What happens to performance when the valve is closed?
Thanks.
Thanks.
Unless you buy the mild-to-wild kit they are set at a pre-fixed rpm range to open and close. If you get the kit you can choose the rpm and use the wireless remotes to open and close them
St. Jude Donor '06-'07
On the Z06 it opens based on RPM (3500) the car can run fine with them closed since the muffler has two separate internal pipes, one muffled and one straight through for the valved side. I make a product that allows you to open them anytime via a wireless control
I am running the Z06 catback on my C6 coupe. It will drone a bit under load but not as bad as some other systems. It is not as loud as I hoped open but a nice improvement over stock. As someone metioned there is a modification you can make to the mufflers to make them even louder.
I went with Sunset Orange Creations all in one retro fit system so I can change as desired from quiet to louder. it is great to have the ability to close the flap and talk on the phone.
If you have any questions on installing them let me know. any good muffler shop can handle it for about $100. I paid $75.00
