Socket for lugs?
Socket for lugs?
What type of socket do you use that doesn't damage lug nuts? Is a regular 6 point OK or do I need something special? I have rotor hub covers that I would like to install.
Any regular socket will be fine, it's the hammering of the impact that damages the lugs and it takes a several times doing it with an impact before they get damaged. If you use a 4 way or a long ratchet or breaker bar you will be fine. Be sure to torque the lugs when you are done.
I'd recommend a forum vendor, but I don't think one offers coated sockets.
Made One
I like the challenge of making things to solve specific issues I run into....have made many special tools, etc.
I also wanted a socket that wouldn't damage the nuts so I made one.
Using a larger 6 point socket and a standard 19mm lug nut, wrapped it and packed the socket with fiberglass. Put them together and let cure and then pulled the nut out with the results shown.
Mid America also sells a lined socket but is somewhat pricey.
I think the OE lug nuts are actually kinda crapola.
In the picture above you can see where that arrow is pointing - that's where a sheet-metal jacket is crimped onto the steel lug nut. The ones in the pack are my other OE nuts - the McGards are on the car.
I got the McGard 64002's and they are great!
They are chrome plated solid steel. I got mine at Pep Boys for about $7 for a pack of 4.
I was browsing around in Wally World for some cleaning/detailing stuff the other day and they had some chromed solid lug nuts for, I think, around 5 bucks for a 4-pack. They looked really nice.
My McGards require a 13/16" socket, but as Au N Egl said, the OE's take a 19mm (3/4" will work but it's a tiny bit loose, and will probably muck up that sheet metal jacket pretty quick).
Just my $.02, YMMV.
Bob
Just my $.02, YMMV.
Bob
As you can see from my picture above, the one I made has been used (numerous times) and works great. I would never use an impact wrench with it or any other socket on such a lug nut.
BJK
Sorry, but Mid Americas "Soft Socket" is closer to $40 than $20 ($32.99 plus shipping).......Picture was correct but "about" price was a little low.
I made mine for about $7.00 including a new socket from Farm Fleet.
I've got the HF set and there's another benefit - my lock is a different size than my lugs, and the HF set has both sizes on the same socket - you use a 3" extension and flip the socket over. Very handy if you change tires as much as I do (for track purposes).
BJK
http://www.napaonline.com/NOLPPSE/(S...9+99999+109999
This is the Harbor Freight set....currently on sale at $19.99...works OK too though you might not need them all.
http://www.harborfreight.com/cpi/cta...emnumber=40035
dealers / tire shops use impact wrenches too.
It is just a lug nut, an aluminum beauty covered piece of steel.
