New DEXRONŽ LS gear oil Cures Rear End Noise?
That doesn't sound like what the fluid update will fix. Almost always the complaint is at very slow speeds, less then 5mph, and it feels like the diff. is binding up, car doesn't want to roll. You could have excessive backlash in the diff. for a clunk but if it is slow to find the gears, or is at the 3-4 shift point, it sounds like a trans. issue.
That is a valid concern for us drag racers. I had a new rear built a while back and it was starting to peg leg on my burnouts....thought I needed a rebuild but tried changing from Royal Purple fluid my shop uses to factory fluid (old type) before I rebuilt it...and sure enough, the peg legging stopped. So you can have too slippery a fluid in there for sure.
I had this done last Saturday along with the axle nut TSB.
The car is quiet, what a difference! I had become accustomed to the the groaning and knocking on accel/decel. Now.....it's all gone. No more noises!!!
The dealership changed the fluid in my 05 three different times and the noise seemed to get worse each time. Took it in for the new TSB with the LS Dextron and it stopped almost immediately. It's been about three weeks now and so far so good. The car actually seems a little more quiet now. Yes, they had to order the fluid but it only took a day to come in.
After the fluid change I am noticing that from a complete stop, if you release the brake and let the car roll forward, it feels like it downshift on its own...???
I had the differential chatter for quite a while on my 05 z51. I took it in to the dealer last November and had them change the fluid and additive, but it didn't help. I had to store the car for the winter, just took it out for the first time this spring and now the chatter is worse. In addition I now also have a sort of grinding sound when turning the wheel in either direction, at any speed. Is the steering issue related to the differential problem? I'd like to have a better idea what is going on before I take it to the dealer. Especially since my warranty has expired.....
Premium Supporting Vendor
Shortly thereafter I changed my diff fluid back to the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 I use in my Z06 (and as an oh by the way the diff fluid plug was completely loose). I did several figure 8's to work the new fluid into the diff and the noise went away... for a day or so, then returned. Although I've never needed AMSOIL Slip-Lock Differential Additive with the AMSOIL Severe Gear as this fluid comes with friction modifier already in it, I considered adding a bottle but didn't have one. So I drove my car for a few more days and the noise went away and has stayed away for about a month now. I suspect that it took longer than I expected to really work the AMSOIL fluid into the diff clutch packs.
In your case, it sounds like your diff fluid has drained out of the clutch packs over the winter. Two suggestions. One - go do a bunch of figure eights to see if you can work the fluid back into the clutch packs. If that doesn't work, consider replacing your fluid with the AMSOIL Severe Gear 75w90 and one bottle of the additive. This approach seems to work very well with quieting the C6 diff.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
New Rear Fluid
The new gear oil works fine for getting rid of the grabbing noise in the rear on turns. It is worse in the Z06 but In some cases it needs to be done twice. Followed by figure 8's in the parking lot to work in the new fluid. You should probably get use to doing it every 15,000 miles the same thing happens to the transfer case fluid in the awd S10 Blazer's and Bravada's. I posted the bulletin on my blog. http://corvettebible.wordpress.com/2...rential-fluid/
1 Post
Cruise-In II Veteran
I had the new LS dif fluid installed about 2 months ago under warranty. The noise prior to the change out was so bad you could feel it when backing out of the garage. Afterwards the noise is gone. If the warranty was over I would change to AMSOil.
Had the oil changed out today under warranty, sound is completely gone and shifts are noticably smoother ---- I guess the clunkyness was the diff.... I'm thrilled car drives completely different!
#35
While passing through the auto store I noticed
mobil1 LS75w90
...diff oil on the shelf. Has anyone had any experience with this >without< adding any gm ltd fluid?
As many have mentioned, finding 2qts of the gm ls oil is entertaining at best, and I could go with another (amsoil, mobil, royal) for the next longest while.
mobil1 LS75w90
#37
Location: You must be young and stupid before you become old and wise... Canton Georgia
#38
Well pricing has changed for the GM Dexron LS.
My GM dealer now says it retails for $20.38/QT and my cost is $15.29/QT.
Since the additive no longer has to be purchased I guess its not too bad.
When chattering starts in my car I will give it a try.
#39
My '08 built in Oct '07 started (@ 5K miles) the chatter/clunking on tight turns when leaving the parking garage when the diff we relatively cool. Doesn't do it when fully up to temp.
Last night I swapped the oil (forget going to the dealer for something so simple as they'll cause a bigger problem in the process). I "think" it solved the problem. Today I didn't hear the noise and we'll see if it is gone tomorrow as well.
As a side note, damn these C6 mufflers get in the way of the oil change. I like the C5 muffler positions better.
I ended up paying $17.32/qt for mine.
#40
Dropped mine off this morning at 7 and they called me at 10:30 to say it was ready. It's nice and quite now. The real test will be tomorrow morning to see if it's completely gone.
