07 6 Spd Non Z51 Stock Dyno #s
I dont have a way of posting the graph, but the numbers were as follows
Stock- 340.54 RWHP, 346.42 RWTQ
After Tuning 353.01 RWHP, 353.4 RWTQ
Car has 1000 Miles
This is with 18" CCW 505A wheels, with BFG drag radials (345-30-18).
Going to have Z06 Stock wheels on it, probably will gain a few HP with that, since the CCW's are very heavy.
Just bought the car from Jason at Texas Speed and performance in Lubbock, Tx.
Daren
Car has 1000 Miles
Daren
Right where you should be, you may gain a little more stock hp over the next few thousand miles too. Mine did 342rwhp, and 346rwhp with a Halltech Stinger back in Nov 06. Made a couple changes since that time
That's why it's important to note as many variables when doing a dyno run as possible for comparing one dyno run to a subsequent one. It's also why RWHP numbers are all over the place and shouldn't be taken too seriously.
On a Dynojet chassis dyno, you will see an increase in RWHP if you use lighter tires/wheels or smaller diameter tires/wheels. Most all Dynojets are inertia type dynos, so the same thing that makes you quicker down the 1/4 (less inertia), will show up on the Dynojet as in increase in RWHP. There are many variables that affect RWHP...even tire pressure. Try doing a dyno run with the tires at 20 PSI then at 50 PSI, you'll be surprised at the difference.
I will be taking it to the original dyno that I used on my other car to get an apples to apples comparison. Each dyno will dyno differently. The main thing I was looking for is how much it started with, and how much it ended with. 13RWHP on a completely stock car is about right for a tune. (I got 12 on my other car from the tune).
1/4 Mile times will be coming in a couple of weeks!, that is where we will see if it is really producing the power!
Anyone wanna guess my times?
My pick will be 12.3's consistently with a 12.2 mixed in.
Daren
If youve got a myspace account, you can view one of them here
http://viewmorepics.myspace.com/inde...ageID=19026830
I learn something everyday
St. Jude Donor '08
Ill post some pics in general sometime next week tony, Ive got a couple on my myspace page, but they arent very good pics.
