FYI: Weight Of Stock Wheels/Tires
Location: NJ..."the way I saw it, everyone takes a beating sometimes."
1 Post
I just weighed my stock chrome wheels with GY SC tires at 30psi with 6/32" tread left.
Front 18" = 50lbs
Rear 19" = 60lbs
This was on a bathroom scale so figure maybe a 1-2lb accuracy discrepency. Just thought some people would like to have this info.
Front 18" = 50lbs
Rear 19" = 60lbs
The next time I take my tires to the bathroom I'll weigh one of them
Sorry, I got carried away!
That is why Callaway offers the Dymag Carbon Fiber/Magnesium wheel as an option for C6 Corvettes and standard on their C16 Corvette. The outer shell is made of carbon fiber and the center spokes are made of magnesium and attached to the rim with titanium hardware. A 20 x 12 wheel weights about 16 lbs. You can easily lift it with one hand.
This wheel alone easily removes 20-30 lbs of weight from each corner of the car depending on what the car originally wore.
-Luigi
-Luigi
-Luigi
-Luigi
I'll take your word for it, but (24 - 16) = 8 and (22 - 16) = 6.
The weights for the stock C6 painted rims:
Front: 22.4 lbs w/o tires, w/TPM
Rear: 24.4 lbs w/o tires, w/TPM
Wheels
19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon - Src
22 lbs, front; 29 lbs, rear - 97-99 OEM wagon - Src
17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium - Src
17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium - Src
18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish - Src
17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or center caps - Src
16 lbs, front; 20 lbs, rear - 01 OEM standard high polish - Src
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged - Src
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun - Src, Src
24 lbs, 18x10.5 - 00+ repro high polish - Src
28 lbs, front; 32 lbs, rear - Z06 chrome repro - Src
23 lbs, front; 26 lbs, rear - Z06 chrome repro - Src
23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished - Src
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear - PWO - Src
22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center - Src
27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center - Src
24/25 lbs - Z07 wheel weight, front - Src
28 lbs - Z07 wheel weight, rear - Src
60 pounds for the rears, I knew those big 19" runflats were pigs. I just weighed some brand new drag radials along with the 17" wagon wheels (C5 fronts).
They weigh 43 pounds each. That's a 34 pound savings for the car. Plus, if I remember right, the rule of thumb is that rotating mass is worth twice, so it's equivalent to a 68 pound weight savings. Let's see, not only is it quicker because my 60 foots are .1 quicker, but it's worth another .06 seconds due to the weight savings. Also, since 60's are worth twice in the 1/4, those lighter drag radials are worth around .26 seconds in the quarter mile.
When I did my Widebody conversion I weighed my '08 split spoke wheels, with sensors and Z51 tires, they had about 2k miles....The front weighed 49.6 lbs, and the rear weighed 56.6 lbs.
The wheels I put on were 2007 GM polished Z06 wheels with SC tires, and sensors (~300 miles). The front wighed 50.6 lbs., and the rear weighed 60.6 lbs
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Wheels
Wheels
Since everyone is coming out in the open with their weight...here's some that you may find helpful.
All figures are in pounds.
1998 factory corvette 17 x 8.5 wheel with 245/45/17 runflats 50.00
1998 factory corvette 18 x 9.5 wheel with 275/40/18 runflats 52.40
2001 stock Z-06 17 x 9.5 wheel 20.00
2001 stock Z-06 18 x 10.5 wheel 22.00
2001 factory Z-06 17 x 9.5 wheel with 20/11.5/17 M/T E.T. streets 43.00
2003 factory Z-06 18 x 10.5 wheel with BFG 315/30/ZR18 drag radial 50.00
House of wheels factory reproductions 18 x 12 polished 28.60
NITTO 555R drag radials 335/30ZR18 30.60
CCW SP16A 18 x 11.5 wheel 24.60
CCW SP16A 18 x 11.5 wheel w/ NITTO 555R drag radials 335/30ZR18 55.00 & 55.40
CCW SP16A 18 x 8.5 wheel 22.00
CCW SP16A 18 x 8.5 wheel w/ Pirelli 265/35/18 48.00 & 49.20
CCW Drag pack fronts (mounted w/ bias plys) 32.20
CCW Drag pack rears (mounted w/ BFG drag radials) 49.60
Forgeline SP3P 18 x13 with stainless hardware 27.60
Forgeline SP3P 18 x13 with titanium hardware and lightening pockets 25.80
Forgeline SP3P 18 x 9 with titanium hardware and lightening pockets 22.20
Nitto NT 555 265 35ZR18 26.80
Nitto NT 555R 335 30ZR18 30.40
BFG drag radials 315/30/18 30.00
