Issue after FORE fuel system install
Old 05-02-2024, 12:56 AM
jayyyw
jayyyw's Avatar
Default Issue after FORE fuel system install
Having a weird issue after installing a FORE double pump fuel system. As far as the install itself, it went fast and pretty easy. The issue I am having is, the tanks are not venting correctly and I'm not able to pump fuel in consistently. I go to put fuel in it and it will fill the fill tube and then start overflowing and then drain into the tank veryyyyy sloooowly. I can stick a rod down the fill tube to open the "plunger" and "burp" the tanks. At this point I can fill it until I stop, then have to use the rod again to burp the tanks. Obviously this is not the right way and something I have not encountered before on these cars. I did not touch the passenger tank (it was already dropped previously to install the regulator block off)
I've tried blowing out the vent lines. If I blow air into the vent line that goes to the filler neck, it will build pressure in the tank and then release out of that line.
I've tried disconnecting the vent solenoid, no change
Seems like it fills no problem if the drivers rear of the car is raised up. Not 100% sure on this tho
Any ideas on other things to check?
Quick Reply: Issue after FORE fuel system install
