C6 1/4 Mile Performance Challenge
#5141
Optimal, I think most of your problem as other have said is your power braking to 1500 rpm.... Here a video of a 12.06 run with a 1.87 60ft time. My car is an 08 A6 2.56 gears and stock, the shroud was propped open on this run. I was at 28 lbs cold in the rears and just did a dead mash to the floor at the green from idle...
http://www.youtube.com/watch?v=PNp83IV6eUE
#5145
Originally Posted by Jerzey LS3
1. Your entire profile completed-check
2. A copy of your entire time slip posted to the thread as in post # _____ -at bottom
3. The complete the details of your pass using this template in your post:
4. Year Corvette -2008
5. Type of Trans -A6 stock
6. Type of Suspension-stock
7. Stock Performance options (as in optional gears with the automatic, & etc.)-base
8. Tires utilized-stock runflats
9. Modifications if any- 1-7/8 ARH + catted X, GHL street axle back, Vararam CAI, ECS tune + ECS trans tune
10. Dyno numbers if you have them-N/A
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc. -warm day approx 62*, warmed up the tires a little, launched at 1400 rpm
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track-Raceway Park
___ Date of the pass & weather conditions-4/9/11, clear around 62*
___ 60'.............-1.820
___ 330'...........-4.958
___ 660'...........-7.512
___ 660’ mph....-96.21 mph
___ 1000'.........-9.705
___ 1320'.........11.545
___ 1320’ mph…-123.09 mph
http://forums.corvetteforum.com/pict...ictureid=79966
Keith
I added the template from your PM
Thank you
Tommy
Keith
Thank you
Tommy
#5146
Frank "Evilways" warming up for another 11 second pass
Please see page 1 post # 6 for instructions & rules. In order to be placed on the list I need a complete timeslip & completed template in your post per the example.
THE LIST
Regarding correction factors:
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest. In cases where ET is the same, the higher MPH determines list order. The bold numbers refer to the post number utilized to report the elapsed times in this thread.
________________________________________ _________________
NEW or IMPROVED ELASPED TIMES
12.31 @ 115.75 GrandSportMan
11.94 @ 121.54 Sebaj
11.54 @ 123.09 JerzeyLS3
Showroom Stock LS2 (2005 -2007)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 M6 Z51 - (337)
12.29 @ 114.29 - Proney - 07 M6 - (4504)
12.31 @ 114.82 - CYA Vett - 05 M6 F55 - (679)
12.42 @ 113.90 - DrRichie - 05 M6 Z51
12.49 @ 114.90 - Jschindler - 05 M6 Z51
12.53 @ 113.00 - Wicked07C6 - 07 M6 Z51 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 A4 Z51 - (60)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.65 @ 111.65 - Zippin Zee - 05 M6 Z51 - (51)
12.66 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 A6 Z51 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 M6 Z51
12.71 @ 111.00 - Demented - 05 A4 Z51
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 A6 Z51 - (907)
12.79 @ 112.17 - Jchazr - 05 M6 Z51 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1672)
12.81 @ 112.83 - Vette-oholic - 05 M6 Z51 - (498)
12.81 @ 110.95 - SkyKing - 07 A6 F55 - (2488)
12.85 @ 114.53 - Mr Z51 - 06 M6 Z51
12.91 @ 111.67 - Brewcitygymratt - 06 A6 - (4582)
12.93 @ 111.40 - DiggyMoe - 07 M6 - (969)
12.97 @ 108.00 - Ginny C6 - 05 A4 F55 - (60)
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15 - (123)
12.99 @ 111.70 - C64ME - 05 M6 Z51 - (333)
13.04 @ 109.15 - TMyers - 06 A6 - (532)
13.05 @ 113.31 - RDunn - 06 M6 - (986)
13.10 @ 108.70 - Rothchilds - 05 A4 F55 3.15 - (1087)
13.12 @ 110.40 - JDWK - 05 M6 Z51
13.25 @ 110.60 - C6 Matt - 05 M6 Z51 - (122)
13.26 @ 108.59 - Sfadchi - 06 A6 Z51 - (888)
13.26 @ 105.30 - Joeking - 05 A4 Z51 - (661)
13.30 @ 107.00 - Shurite44 - 06 A6 Z51 - (769)
13.35 @ 108.10 - Phatpharmd - 06 A6 - (595)
13.62 @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - ????)
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
11.80 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3482)
11.97 @ 116.98 - Proney - 08 M6 Z51, NPP - (4656)
12.05 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5055)
12.10 @ 117.60 - Dingrao - 08 A6 - (3567)
12.10 @ 115.19 - Odin - 09 A6 2.73 npp - (4329)
12.12 @ 116.59 - Pettvette - 08 A6 - (4282)
12.15 @ 115.59 - Old Goat - 09 A6 2.73 - (3712)
12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744)
12.18 @ 117.72 - Hardhattg - 08 M6 Z51 - (2690)
12.23 @ 112.86 - 940CACC - 08 A6 - (2880)
12.24 @ 117.83 - 74Vette - 08 M6 - (4621)
12.26 @ 115.22 - Oklahoma - 08 A6 - (3767)
12.27 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3251)
12.35 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2759)
12.26 @ 116.94 - TNorman - 08 A6 NPP - (4231)
12.40 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2138)
12.41 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3190)
12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486)
12.42 @ 116.67 - Pea-Jay - 08 A6 - (4453)
12.49 @ 115.54 - 1.8T - 08 M6 Z51 - (2314)
12.55 @ 114.70 - Larry R - 08 A6 2.73 - (4058)
12.60 @ 114.12 - Beefcake - 08 A6 - (2882)
12.65 @ 114.99 - PhillyLS1 - 09 M6 - (3156)
12.66 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2834)
13.35 @ 110.78 - M453W - 09 A6 NPP- (4061)
13.42 @ 109.32 - Dan Wendling - 09 A6 NPP - (4036)
Showroom Stock LS3 Grand Sport (2010 - ????)
12.31 @ 115.75 - Grand SportMan - 10 A6 - (5132)
12.80 @ 113.33 - PhillyLS1 - 11 M6 NPP - (5089)
External Engine Modifications LS2 (Bolt-Ons)
10.62 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, hdrs, 3.73, ptb, tune, & more DR - (3948)
10.92 @ 125.13 - LS1LT1 - 06 A6 - CAI, Conv, fast, hdrs, ptb, skinnies, tune, DR - (4305)
11.12 @ 123.23 - Dicky - 06 A6 - CAI, Conv, cutouts, fast, 3.42, hdrs, tune, DR - (4358)
11.29 @ 122.24 - JMT1669 - 06 A6 - CAI, Conv, cb, hdrs, fast, 3.42, tune, DR - (4431)
11.29 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, Conv, hdrs, no cats, Pfast, tune, udp, DR - (5109)
11.34 @ 125.78 - Silvervette05 - 05 M6 – Z06 exhaust, pfast/tb, gto skinnys nitto555 tune - (4426)
11.67 @ 118.76 - Its Stock - 06 M6 - CAI, , hdrs, udp, tune, DR - (4569)
11.74 @ 120.83 - Siffert - 07 A6 - CAI, cb, hdrs, pfast, tune, DR - (3986)
11.76 @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, hdrs, 3.73, pi & tb, tune
11.77 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdrs, pi & tb, tune - (2179)
11.79 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, muff, tune, DR - (3231)
11.81 @ 118.76 - Joe G - 05 M6 Z51 - CAI, hdrs, 3.90, pi, tune - (1874)
11.87 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdrs, pi, tune, DR - (3558)
11.87 @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdrs, tune, DR - (839)
11.94 @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdrs - (521)
11.96 @ 118.98 - GMRULZ - 06 M6 Z51 -CAI, hdrs, pi, bilstein shocks, tune, DR - (2163)
11.98 @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdrs, pi & tb, tune, DR - (1970)
12.01 @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdrs, pintake, tune, DR
12.03 @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdrs
12.03 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdrs, pi, tune, DR - (2277)
12.05 @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdrs
12.05 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, hdrs, tune, 3.73, DR - (4471)
12.08 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdrs, tune, DR - (1449)
12.09 @ 114.63 - 68RSSS -05 A4 F55 - CAI, hdrs, tune, - (5078)
12.13 @ 115.15 - Ben Diss -07 M6 F55 - CAI, hdrs, tune, Nitto Ivos - (1919)
12.17 @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdrs - (1228)
12.17 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2189)
12.18 @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1822)
12.18 @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdrs, tune, DR - (1824)
12.21 @ 115.98 - Mike Campbell - 06 A6 - CAI, DR - (5097)
12.21 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1323)
12.22 @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdrs, tune - (1706)
12.26 @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdrs, - (659)
12.26 @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdrs, - (1118)
12.27 @ 115.94 - TNTC4Vette - 06 M6 Z51 - CAI, bilsteins, hdrs, mufflers, ptb, tune Ps2 (5022)
12.27 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdrs, Z06 Muff, tune - (4227)
12.31 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdrs, tune - (3629)
12.36 @ 114.03 - DMcRacer - 07 A6 Z51 - CAI, Continental tires - (5069)
12.37 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, hdrs, gears, tune - (368)
12.37 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdrs - (69)
12.39 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1473)
12.39 @ 114.83 - DMcRacer - 07 A6 Z51 – CAI, Continental tires - (4526)
12.42 @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdrs, DR - (393)
12.49 @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdrs
12.49 @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdrs, tune, DR - (1249)
12.50 @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (177)
12.50 @ 115.20 - Flooznie - 05 A4 - tune - (216)
12.51 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (492)
12.52 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdrs, tune - (1602)
12.52 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdrs, tune - (4408)
12.53 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.53 @ 113.53 - Vade46 - 07 M6 Z51 - CAI, CB - (4280)
12.54 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4576)
12.54 @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55 @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdrs (843)
12.55 @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdrs - (240)
12.59 @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdrs, tune - (202)
12.59 @ 113.46 - Badassbu - 07 A6 - CAI - (1769)
12.60 @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (59)
12.62 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4525)
12.63 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63 @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65 @ 113.70 - Hitman99 - 06 A6 - CAI, hdrs, tune
12.65 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2601)
12.68 @ 113.92 - Sditch - 05 A4 Z51 - CAI - (188)
12.71 @ 113.70 - C6Brian - 07 M6 - Tune - (1616)
12.72 @ 110.85 - AngeloC6 - 05 A4 F55 3.15 open shroud - (1654)
12.77 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1269)
12.78 @ 112.50 - Dan-t - 06 A6 - Tune - (1179)
12.79 @ 115.58 - Sebaj - 05 M6 - CB, Z06EM, pi & tb, ud, Tune - (4439)
12.80 @ xxx.xx - Thanos - 05 A4 Z51 - CB - (59)
12.83 @ 111.00 - TMyers - 06 A6 - CAI, tune - (768)
12.88 @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.89 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdrs rockers, tune - (860)
12.89 @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(830)
12.90 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (541)
12.93 @ 110.64 - C6Vette - 05 M6 Z51 - CAI, cb, tune - (1206)
12.97 @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (226)
12.97 @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdrs, tune - (697)
12.99 @ 111.25 - Parkev - 05 M6 Z51 - CB - (83)
13.30 @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1041) high alt
13.32 @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.95 @ 104.94 - Fright88 - 06 A6 - CB, hdrs - (1683) high alt
External Engine Modifications LS3 (Bolt-Ons)
10.82 @ 125.82 - HOXXOH - 08 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, & more DR - (4808)
10.98 @ 124.66 - Theofel - 08 A6 - CAI, cb, conv, hdrs, 315, tune, & more DR - (4743)
11.22 @ 125.83 - 8850 - 08 A6 NPP 2.73 - CAI, hdrs, tune Dr - (4854)
11.25 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, hdrs, pi, 3.73, torco & meth inj, tune DR - (3743)
11.51 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdrs, ptb, Z06rear, tune, Invos - (3569)
11.53 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdrs, ptb udp, tune, - (3737)
11.54 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx hdrs, tune (5150)
11.55 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdrs, fast, 3.90, Et St - (3089)
11.56 @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdrs, pi & tb, tune DR - (2409)
11.56 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1852)
11.61 @ 120.86 - HPAvette - 08 A6 – CAI, hdrs tune DR - (3649)
11.68 @ 121.22 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2594)
11.70 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdrs, tune - (2175)
11.72 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdrs, tune DR - (4425)
11.79 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdrs, tune Nitto Ivos - (3790)
11.98 @ 120.04 - Rock n' Blue08 - 08 M6 -CAI, hdrs, 3.90, Xpipe Z06 muff, - (2894)
11.99 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdrs, tune, DRs - (2471)
11.99 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdrs, tune - (4436)
12.00 @ 116.49 - Chets Z06 - 08 M6 - Nittos - (4479)
12.01 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdrs, pi, ud, tune, DR-(4477)
12.01 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4602)
12.03 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdrs, tune - (2529)
12.04 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3529)
12.10 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4224)
12.12 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3145)
12.17 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3544)
12.26 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdrs - (3931)
12.34 @ 118.40 - Airbuspilot - 08 M6 - CB - (3715)
12.46 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdrs, tune - (2910)
12.71 @ 112.79 - Gfish - 08 A6 Z51 NPP - CAI, tune - (4437)
13.33 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2706)
External Engine Modifications Grand Sport (Bolt-Ons)
11.94 @ 118.55 - Agent White - 10 A6 GS NPP - CAI, hdr tune - (4581)
Internal Engine Modifications LS2
10.58 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast H&C, hdrs, 4.10, 100maf, tune, DR - (4334)
10.59 @ 130.09 - Dennis50NJ - 05 A4 Z51 - CAI, cam, cb, conv, ewp, pfast, hdrs, 3.73, ptb, tune, DR - (4302)
10.66 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, hdrs, H&C pfast, 4.10 tune, DR - (4300)
10.82 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C hdrs, udp, tune, & more DR - (4583)
10.84 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdrs, ported int/tb, udp DR - (4014)
10.87 @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, H&C, hdrs, 3.42, intake, tune, DR
10.90 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdrs, tune, DR - (3691)
10.96 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdrs, PI, PTB, Z06 Muff, tune, DR - (4416)
10.99 @ 126.67 - Joe G - 05 M6 Z51 - CAI, cb, cam, hdrs, 4.10, pfast, tune, DR - (4710)
11.01 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, Conv, H&C hdrs, 3.15, tune, DR - (4615)
11.03 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdrs, tune, DR - (3923)
11.19 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdrs, pi & tb, udp DR - (4260)
11.19 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdrs, L92/L76 combo tune, Dr - (4079-80)
11.20 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdrs, no muff, tune,DR - (2478)
11.23 @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, hdrs, 4.10, udp, tune, Z06 tires - (1696)
11.24 @ 123.05 - Its Stock - 06 M6 - CAI, cam, hdrs, udp, tune, DR - (5088)
11.31 @ 121.49 - Justasheet - 05 A4 Z51 - CAI, cb, cam, conv, hdrs, ptb pfast, Z06 Muff, tune, 3.73, DR - (5037)
11.35 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, hdrs, pfast/tb, tune, DR - (3472)
11.44 @ 120.11 - Justasheet - 05 A4 Z51 - CAI, cam, conv, pitb, hdrs, Z06 muff, 3.73, tune, DR - (4791)
11.46 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdrs, pi - (2847)
11.49 @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast hdrs, udp, tune - (1610)
11.52 @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdrs, udp, tune, DR - (1909)
11.53 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdrs, tune -(871)
11.55 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdrs, susp, tune, DR - (2757)
11.76 @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdrs, tune, DR
11.79 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdrs - (1821)
11.94 @ 115.58 - Sebaj - 05 M6 - CB, Z06EM, H&C pi & tb, QA1 shocks, ud, Tune - (5133)
11.98 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdrs, pi, udp, DR - (1265)
11.99 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdrs, fast udp, tune, DR - (4465)
12.12 @ 118.27 - Sebaj - 05 M6 - CB, H&C,Z06EM, pi & tb, ud, Tune PS2 - (4547)
12.31 @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdrs, tune
13.12 @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdrs, tune
Internal Engine Modifications LS3
10.61 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdrs, pi, tune, Z06 susp,DR - (4621)
10.63 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3644)
10.66 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, H &C CAI, hdrs, 3.90, tune, DR - (3198)
10.73 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, ported tb/int, udp tune, DR - (3972)
10.78 @ 127.17 - Theofel - 08 A6 - CAI, cb, cam, conv, ewp, hdrs, 315, tune, & more DR - (5107)
11.03 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdrs, tune, DR - (3900)
11.10 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdrs, shaneTB, tune, DR - (4073)
11.14 @ 129.27 - AndrewAPSU - 08 M6 - CAI, cam, hdrs, Z06 Exhaust, DR - (4211)
11.17 @ 120.58 - Texasranger - 08 A6 - CAI, cam, hdrs, 3.15, tune, DR - (2805)
11.94 @ 121.11 - Beefcake - 08 A6 - CAI, cam, hdrs, tune -(3039)
Power Adders LS2 (supercharger, turbo, nitrous)
9.73 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, hdrs, RPM trans, 3.42 , tune, DR - (3262)
9.93 @ 136.88 - Tekhombre - 05 M6 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune - (1157)
10.29 @ 138.17 - BlownV6 - 06 A6 – N2O, CAI, cb, H&C, hdrs, tune, DR
10.29 @ 135.00 - Willisfast - 06 M6 Z51 - SC with meth, cam, CB, hdrs, DR
10.68 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdrs, DR - (4221)
10.86 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdrs, tune, DR - (480)
10.89 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (939)
10.99 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, CAI, cb, hdrs, tune, - (3300)
11.07 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdrs, DP, DR - (3665)
11.09 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdrs, DR - (2825)
11.18 @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.28 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1652)
11.28 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdrs - (1804)
11.31 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdrs, tune - (1900)
11.37 @ 135.29 - Turboffr - 06 M6 Z51 - CAI, cam, hdrs, fast SC, meth, udp, tune, DR - (4520)
11.37 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdrs, tune, DR - (589)
11.40 @ 121.47 - C6 Roller - 05 A4 - SC, hdrs, DR - (1772)
11.89 @ 120.20 - FLC6 - 05 A4 3.15 - N2O, CAI, cb
Power Adders LS3 (supercharger, turbo, nitrous)
9.75 @ 139.83 - Silver Bullet C6 - 08 A6 - supercharger, alky, cam, cb, hdrs, pi & pt, DR - (5000)
10.55 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdrs, tune, DR - (3238)
10.57 @ 135.18 - Winters 97 GT - 08 M6 - SC, alky, B&B mufflers, tune, DR - (5033)
10.74 @ 136.61 - ZbadestZ - 08 A6 NPP - ECS 2200, hdrs, fuel system, tune DR - (3238)
10.87 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdrs, SC, tune, DR - (3903)
11.30 @ 124.45 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune - (4222)
Larger Displacement (All entries)
9.51 @ 148.77 - Todd@RPM - 05 A4 -TT, 427, fuel sys, L92 heads, 3.42, RPM Trans DR (4278)
9.65 @ 141.11 - Tluck - 05 A4 Z51 - 402 cid, ccw drag pack, 373, N20 & more, DR - (3922)
9.89 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, DR - (4277)
9.95 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, Tune, DR (4469)
10.41 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, .3.42, hdrs, tune, DR - (4198)
10.41 @ 132.71 - Craftfox - 07 A6 Z51 – 440, conv, fast, 3.42, hdrs, tune, DR - (4469)
10.68 @ 133.21 - Schilitj - 05 M6 Z51 - 402, SC, cb, H&C, hdrs - (3529)
10.76 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (782)
11.43 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416 cid, conv, H &C p/fast,& tb, tune, Nitto Ivos - (3740)
11.68 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (662)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.51 @ 107.03 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdrs, tune, & more DR - (4693)
6.94 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, H&C, fast, ptb, 100maf, tune, DR - (4361)
7.19 @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdrs, DR - (3782)
7.21 @ 95.10 - Joe G - 05 M6 Z51 - CAI, Cam, 3.90, pfast, hdrs, - (3793)
7.27 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.27 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdrs, pi & tb, C5-3.90, tune DR - (4534)
7.34 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdrs, pintake/TB, udp, tune, DR - (3056)
7.36 @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdrs, 3.90, Et Street - (2863)
7.50 @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi & tb, hdrs, tune PS2s - (3081)
7.65 @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdrs, tune Dr - (3558)
7.67 @ 94.37 - DavetteGuy - 08 A6 - CAI, Ptb tune - (5068)
7.83 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdrs, pi, nitto ivos - (4164)
8.09 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4046)
8.45 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1664)
DA http://www.dragtimes.com/da-density-...calculator.php
Thank You CALLAWAY for sponsoring the C6 Tech & Perf section & making this list possible
#5147
Hey Sebaj
very nice improvement
Keith sorry for the confusion great run
Grand sport man welcome to the list, nice run
With regard to short times:
I would expect the GS to have a better short time than the base model as it has wider tires (I do not recall if they are the new GY with a sticker compound)
I do not think the our run craps tend to flatten out as like a regular radial...... maybe a bit but not much & most of us have run with the base tires ...... (not the Z51 rubber when we were stock)
In any event you always have to adjust the air pressure & launch to track conditions.
#5148
Time slip will not post....any pointers?
Here is the you tube link if that counts.
http://www.youtube.com/watch?v=YAag1EFFcWo
4. Year Corvette -2009
7. Stock Performance options -2.56 gear
9. Modifications--none
11. 25psi in rear 30 in front. 70* 800-850 da
___ Name of the Track-State capitol, Baton rouge, la
___ Date of the pass & weather conditions-3/31/11, clear around 70*
___ 60'.............1.97
___ 330'...........5.382
___ 660'...........8.097
___ 660’ mph....90.84 mph
___ 1000'.........10.417
___ 1320'.........12.356
___ 1320’ mph…116.74 mph
#5149
It was a 70 deg evening Test & Tune.
4. Year Corvette-2009
5. Type of Trans-A6
6. Type of Suspension-Z51
8. Tires utilized-Stock Run Flats-30 front 26 rear.
9. Modifications if any-AiRaid Cold Air Intake
10. Dyno numbers if you have them-377HP after this run-390HP after tune. Will post new after tune times soon.
11. Just put the trans in Sport and let the car do the rest. Made 6 hot lap passes. two 12.40's and this as my best.
___ Name of the Track-Edgewater, Cincinnati, OH
___ 60'.............2.007
___ 330'...........5.402
___ 660'...........8.120
___ 660’ mph....90.77
___ 1000'.........10.434
___ 1320'.........12.371
___ 1320’ mph…116.61
5. Type of Trans-A6
#5151
Note to Moderator (Tommy)
The Showroom Stock listing for the Grand Sport should be 2010-???? and not 2008-????, just saying.
#5152
Former Vendor
Can you please add me to the list in the All Entries category
2006 Corvette 427ci
A6
F55/with Z06 springs and sways
fully forged motor, ls7 ported heads, Vararam, Cam, Circle D 3200, Fast 102 unported, NW102, 3.15, Cb, 19' drag radial, tune,
Grandsport conversion with Z06 rotors and calipers (3588lbs with driver)
550rwhp 500rwtq
Toronto Motorsports Park
April 30/2011
60'--------1.480
330-------4.263
1/8-------6.597
MPH------108.47
1000-----8.648
1/4-------10.369
MPH------134.42
http://www.youtube.com/watch?v=j70MrZzaCLE
2006 Corvette 427ci
A6
550rwhp 500rwtq
April 30/2011
60'--------1.480
330-------4.263
1/8-------6.597
MPH------108.47
1000-----8.648
1/4-------10.369
MPH------134.42
#5154
2010 Grand Sport A6 Coupe
Please add to the= External Engine Modifications Grand Sport (Bolt-ons) section.
First time at Cecil County Dragway this year. 260 lb. driver & approx. 5/8 tank of 93 octane gas. The "only" modification from total stock is a "Home Made" CAI. Not bad IMHO for just a CAI on the 430 HP LS3 Grand Sport. Exactly 3 tenths lower ET than stock.
4. Year Corvette= 2010
5. Type of trans= A6
6. Type of suspension= Stock
7. Stock Performance options= None
8. Tires utilized= Stock
9. Modifications if any= CAI (Home Made)
10. Dyno numbers if you have them= None
Sport Mode, Traction Control= Off, 30 psi air pressure all around, slight burnout with two dry hops than launched at approx. 1000 RPM's.
12. Typed in post (as some time slips get deleted & etc after posted)
_Name of track: Cecil County Dragway
_Date of the pass & weather conditions: 3/4/2011 & approx. 45 degrees
_ 60'..............1.860
_330'..............5.135
_1/8..............7.804
_1/8 mph........92.34
_1000'............10.089
_1/4..............12.011
_1/4 mph........117.15
#5155
Cold Air Intake (Home Made) car drives & idles as before mod.
This is the "Home Made" CAI. It was a lot "prettier" before I added the 3M rubber seal to the 3 sided painted black aluminum air box to keep "any" dust from getting into the engine compartment which is most likely NOT NEEDED for performance. Without the 3M seal it looked as good or better than OEM in my book i.e. had a more finished look, the fit between the air box which drops though the shroud approx. 1/2" and shroud was a fairly tight fit. One sided sticky foam rubber was used to seal the front of the intake to the core support.
PS: Made In America by one, real cheap too, approx. $10 if you use the intake assembly that came with the car and no water will get into this CAI; it's above the grill opening and the rectangle hole in the front core support. It also removes as quick and easy as stock, same attachments and you can now get to the front of the radiator to clean the bugs out. Is this the best thing since sliced bread or what?
Note: The aluminum was bent on my table vise using an oxy-acetylene torch to warm the metal so that it would not crack/tear on the 90 degree bends.
#5156
_Date of the pass & weather conditions: 3/4/2011 & approx. 60 degrees
#5160
2008 A6 ,2.56's,ARH 1 7/8 W/ 3'' X-Pipe w/ Cats,Vararam Air Intake,Mike Norris Tune,Nitto 05R's.Stock suspension,Mufflers,Torque converter !
PBIR 5/13/11- 83 Degrees- DA 1612
R/T .086
60' 1.867
330 5.080
1/8 7.669
MPH 95.07
1000 9.880
ET 11.737
MPH 121.89
R/T .086
60' 1.867
330 5.080
1/8 7.669
MPH 95.07
1000 9.880
ET 11.737
MPH 121.89
