C6 1/4 Mile Performance Challenge
#3561
1 Post
It sure is, I can't complain a bit. Last night I turned my 253rd run on that poor thing. The track wasn't hooking so I was riding it longer than usual but that wasn't working, so on my PB run I decided to launch out of the groove at 6k and just do a fast release, .0625 of a second from first movement to WOT it hooked and that was a good run.
#3562
As promised, here are my timeslips from Saturday. I was car # 3, which is circled. These were the 2 best runs I had, a 12.102 & 12.278.
timeslips.jpg?t=1228159537
My car:
Bone-stock 2008 LS3 C6 6 Speed AT
Tires: Original GY run-flats @ 30psi
After a burn-out, I launched at about 2000 RPM, with traction control and active handling off. I used the paddle shifters to change gears during all my runs; I NEVER drive the car in automatic mode, even under normal driving conditions.
I had 1/2 tank of Sunoco 93. Outside, it was 45 degrees, no wind and very little humidity, a great day to race!
I stored the car this weekend for winter....god, I miss it already.
Thanks in advance for posting my times!
My car:
#3563
St. Jude Donor '08
Hey all.
I did my last run of the season at Cecil County Dragway in MD, and here is my best time:
2008 Corvette Coupe 2LT.
Showroom stock on original GY Runflats, non-NPP, non-Z-51.
R/T .519
60' 1.919
330' 5.222
1/8 7.904
1000' 10.193
1/4 12.102
MPH 117.60
I will post a pic of the time slip as soon as I am able to.
I have only drag raced at track one other time before, so I guess I did OK, but know I can do better.
R/T .519
60' 1.919
330' 5.222
1/8 7.904
1000' 10.193
1/4 12.102
MPH 117.60
#3564
placement: External Modifications Bolt ons
4. Year Corvette: 2008
5. Type of Trans: Auto
6. Type of Suspension:Z51
7. Stock Performance options (as in optional gears with the automatic, & etc.): Stock Z51
8. Tires utilized: 18X275 19X345 Nitto Invo
9. Modifications if any: AR HEADERS/XPIPE, NPP,LPE CAI,PTB,160STAT,VETTE DOCTORS TUNE, ZO6 REAR, CARBON FIBER HOOD
10. Dyno numbers if you have them:398 W/O PTB
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc: RAN IT IN "S" NO PADDLE. 31PSI N2O
12.
___ Name of the Track:MARYLAND INT'L RACEWAY
___ Date & weather conditions:11/23/08. VERY COLD AND WINDY
___ 60'.............1.825
___ 330'...........4.955
___ 660'...........7.503
___ 660’ mph....97.01
___ 1000'.........9.683
___ 1320'.........11.514
___ 1320’ mph...122.72
Please add me to the list, id like some bragging rights
Thanks!
James
12.
Thanks!
James
#3565
St. Jude Donor '08
Thanks!
James
Thanks!
James
#3566
Frank "Evilways" warming up for another 11 second pass
Please see page 1 post # 6 for instructions & rules
THE LIST
Regarding correction factors:
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest. In cases where ET is the same, the higher MPH determines list order.
________________________________________ ________________________________________ _______
NEW or IMPROVED ELASPED TIMES
7.65 @ 93.64 C5Pilot
11.87 @ 120.02 C5Pilot
7.35 @ 95.10 Joe_G
12.10 @ 117.60 Dingrao
11.51 @ 122.72 James1990
Showroom Stock
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
11.80 @ 118.82 - Gmrulz - 08 A6 Z51, Npp - (3482)
12.10 @ 117.60 - Dingrao - 08 A6 - (3567)
12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744)
12.17 @ 116.80 - Pettvette - 08 A6 - (3290)
12.18 @ 117.72 - Hardhattg - 08 Z51 M6 - (2690)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 Z51 M6 - (337)
12.23 @ 112.86 - 940CACC - 08 Z51 A6 - (2880)
12.27 @ 118.66 - EZ28 - 08 Z51 M6 NPP - (3251)
12.31 @ 114.82 - CYA Vett - 05 F55 M6 - (679)
12.35 @ 117.47 - Bain - 08 A6 2.73 NPP - (2759)
12.38 @ 115.86 - Proney - 07 M6 - (3521)
12.40 @ 114.70 - Jschindler - 08 Z51 M6 NPP - (2138)
12.41 @ 116.15 - JTorchz06 - 09 Z51 A6 NPP - (3190)
12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486)
12.42 @ 113.90 - DrRichie - 05 Z51 M6
12.49 @ 115.54 - 1.8T - 08 Z51 M6 - (2314)
12.49 @ 114.90 - Jschindler - 05 Z51 M6
12.53 @ 113.00 - Wicked07C6 - 07 Z51 M6 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 Z51 A6 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 Z51 A4 - (60)
12.60 @ 114.12 - Beefcake - 08 A6 - (2882)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.65 @ 114.99 - PhillyLS1 - 09 M6 - (3156)
12.65 @ 111.65 - Zippin Zee - 05 Z51 M6 - (51)
12.66 @ 113.61 - CFP40 - 08 A6 2.73 npp - (2834)
12.66 @ 113.03 - Mdrrandall - 07 Z51 M6 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 Z51 A6 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 Z51 M6
12.71 @ 111.00 - Demented - 05 Z51 A4
12.72 @ 111.98 - SR0707 - 06 A6
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 Z51 A6 - (907)
12.79 @ 112.17 - Jchazr - 05 Z51 M6 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 Z51 A6 - (1672)
12.81 @ 112.83 - Vette-oholic - 05 Z51 M6 - (498)
12.81 @ 110.95 - SkyKing - 07 A6 F55 - (2488)
12.83 @ 109.44 - Tommy D - 05 A4 3.15 - (114)
12.84 @ 112.98 - Proney - 06 M6
12.85 @ 114.53 - Mr Z51 - 06 Z51 M6
12.93 @ 111.40 - DiggyMoe - 07 M6 - (969)
12.97 @ 108.00 - Ginny C6 - 05 F55 A4 - (60)
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15 - (123)
12.99 @ 111.70 - C64ME - 05 Z51 M6 - (333)
13.04 @ 109.15 - TMyers - 06 A6 - (532)
13.05 @ 113.31 - RDunn - 06 M6 - (986)
13.10 @ 108.70 - Rothchilds - 05 F55 A4 3.15 - (1087)
13.12 @ 110.40 - JDWK - 05 Z51 M6
13.25 @ 110.60 - C6 Matt - 05 Z51 M6 - (122)
13.26 @ 108.59 - Sfadchi - 06 Z51 A6 - (888)
13.26 @ 105.30 - Joeking - 05 Z51 A4 - (661)
13.30 @ 107.00 - Shurite44 - 06 Z51 A6 - (769)
13.35 @ 108.10 - Phatpharmd - 06 A6 - (595)
13.62 @ 106.18 - Rich28 - 05 Z51 A4
External Engine Modifications (Bolt-Ons)
10.91 @ 124.14 - Dennis50NJ - 05 Z51 A4 - CAI, CB, conv, hdrs, 3.73, tune, DR - (3421)
11.25 @ 121.10 - Theofel - 08 A6 - CAI, CB, conv, hdrs, 315, tune, DR - (3525)
11.39 @ 123.33 - Jbsblownc5 - 08 M6 Z51 - CAI, CB, Hdrs, ported int, 3.73, tune, DR - (3554)
11.51 @ 122.72 - James1990 - 08 Z51 A6 Npp-CAI, cf hood Z06rear, tune, Invos - (3569)
11.55 @ 120.71 - StageIt - 08 Z51 M6 -CB, hdrs, Intake, 3.90, Et St - (3089)
11.56 @ 120.02 - Quicktime - 08 M6 - CAI, CB, Hdrs, ported int/tb, tune DR - (2409)
11.56 @ 118.82 - MCV - 08 Z51 M6 - CAI, DR - (1852)
11.68 @ 121.22 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2594)
11.70 @ 118.54 - Z51 6spd - 08 Z51 A6 Npp - El wp, hdrs, tune - (2175)
11.76 @ 119.00 - NastyC6 - 05 Z51 A4 - CAI, conv, hdrs, 3.73, ported int/tb, tune
11.77 @ 121.58 - Red06vette - 06 Z51 A6 - CAI, CB, hdrs, ported int/tb, tune - (2179)
11.77 @ 121.41 - XStang - 08 A6 Z51 - CAI, Tune - (2522)
11.78 @ 120.65 - HPAvette - 08 A6 - CAI Hdr tune - (3551)
11.79 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 Exhaust, Muff, Tune, DR - (3231)
11.80 @ 118.62 - 8850 - 08 A6 2.73 NPP - CAI, hdrs, tune - (2012)
11.81 @ 118.76 - Joe G - 05 Z51 M6 - CAI, hdrs, 3.90, ported int, tune - (1874)
11.83 @ 119.50 -LS1LT1 - 06 A6 - CAI, tune, DR - (3498)
11.87 @ 120.54 - Braciole - 07 M6 - CAI, CB, hdrs, port Fast, 4.10 tune, DR - (3234)
11.87 @ 120.02 - C5pilot - - 07 Z51 A6 - CAI, Hdr, P/int, Tune, Dr - (3558)
11.87 @ 112.99 - Cucchiara - 05 A4 - CAI, CB, hdrs, conv, tune, DR - (839)
11.94 @ 117.99 - JimSpeed - 06 Z51 M6 - CAI, CB, hdrs - (521)
11.96 @ 118.98 - GMRULZ - 06 Z51 M6 -CAI, hdrs, ported int, bilstein shocks, tune, DR - (2163)
11.98 @ 120.04 - Rock n' Blue08 - 08 M6 -CAI, hdrs, 3.90, Xpipe Z06 muff, - (2894)
11.98 @ 116.44 - C6speedjon - 07 Z51 M6 -CAI, CB, hdrs, ported int/tb, tune DR - (1970)
11.99 @ 120.44 - 1.8T - 08 Z51 M6 - CAI, CB, Hdr, tune, DRs - (2471)
11.99 @ 118.51 - JMT1669 - 06 A6 - CAI, CB, tune - (2176)
12.01 @ 116.00 - Mr Z51 - 06 Z51 M6 - CAI, CB, hdrs, ported int, tune, DR
12.03 @ 120.42 - Quikag - 08 Z51 M6 - CAI, CB, hdrs, tune - (2529)
12.03 @ 118.50 - Serendipity - 06 M6 - CAI, CB, hdrs
12.03 @ 118.43 - Glennhl - 06 Z51 A6 - CAI, hdrs, ported int, tune DRs - (2277)
12.04 @ 115.99 - Bain - 08 A6 2.73 NPP - CAI - (3529)
12.04 @ 114.01 - 06C6FVR - 06 Z51 M6 - Mufflers, tune, DR - (1301)
12.05 @ 117.02 - CYA Vett - 05 F55 M6 - Hdrs
12.08 @ 117.00 - Forrest - 06 Z51 M6 - CAI, CB, hdrs, tune, DR - (1449)
12.08 @ 115.48 - Siffert - 07 A6 - CAI, CB, hdrs, tune, DR - (304)
12.12 @ 118.06 - Badassbu - 09 A6 npp - Removed fuse - (3145)
12.13 @ 115.15 - Ben Diss -07 F55 M6- CAI, hdrs, Nitto Ivos, tune - (1919)
12.17 @ 119.00 - RHecox - 06 Z51 A6 - CAI, CB, hdrs - (1228)
12.17 @ 117.24 - QuickZilver - 08 A6 Z51 npp - Removed fuse - (3544)
12.17 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, Kdw - (2189)
12.18 @ 115.85 - Mdrrandall - 07 Z51 M6 - CAI, CB - (1822)
12.18 @ 114.00 - Toptoneone - 06 Z51 M6 - CAI, CB, hdrs, tune DR - (1824)
12.21 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1323)
12.22 @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdrs, tune - (1706)
12.26 @ 119.40 - Dstage - 06 M6 - CAI, CB, hdrs, Intake - (659)
12.26 @ 116.65 - Waveblaster785 - 06 Z51 A6 - CB, hdrs, Intake - (1118)
12.37 @ 117.67 - Nicodemus - 05 M6 - CAI, CB, hdrs, gears, tune - (368)
12.37 @ 117.17 - Airbuspilot - 08 M6 - CB - (3282)
12.37 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdrs - (69)
12.39 @ 115.50 - Tony96 LT4 - 06 Z51 A6 - CAI, TB, DR - (1473)
12.41 @ 115.40 - Icebourg - 05 Z51 M6 - CAI, CB
12.41 @ 112.07 - WS6JJP - 05 Z51 M6 - CB
12.42 @ 116.12 - YellowVette22 - 05 F55 M6 - CAI, CB, hdrs, DR - (393)
12.44 @ 114.34 - Mike Campbell - 06 A6 - CAI, stat - (2611)
12.46 @ 117.86 - MMartin - 08 Z51 A6 - CAI, hdrs, tune - (2910)
12.48 @ 113.00 - Demented - 05 Z51 A4 - CAI
12.49 @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, CB & hdrs
12.49 @ 113.50 - 12 Oh- 06 A6 - CAI, CB, hdrs, tune, DR - (1249)
12.50 @ 118.00 - Larry Chip - 05 M6 - CAI, CB, tune - (177)
12.50 @ 115.20 - Flooznie - 05 A4 - tune - (216)
12.51 @ 113.56 - Jelsis - 06 Z51 A6 - CAI - (492)
12.52 @ 115.26 - Tony B4 - 06 A6 - CAI, CB, hdrs, tune - (1602)
12.53 @ 113.78 - Ultimate CC - 07 Z51 M6 - CAI - (1641)
12.54 @ 113.63 - Anky1631 - 05 M6 - CAI, CB
12.54 @ 113.24 - NineBall - 05 Z51 M6 - stat
12.55 @ 115.85 - Yell03 - 06 M6 - CAI, CB
12.55 @ 114.95 - Shurite44 - 06 Z51 A6 - CAI, CB, hdrs (843)
12.55 @ 111.98 - 2003Anniversary - 05 Z51 A4 - CAI, CB, hdrs - (240)
12.57 @ 113.04 - Jschindler - 05 F55 M6 - CB - (241)
12.59 @ 114.89 - AZVette2005 - 05 Z51 M6 - CB hdrs, tune - (202)
12.59 @ 113.46 - Badassbu - 07 A6 - CAI - (1769)
12.60 @ 114.00 - SScamaro - 05 Z51 M6 - CAI, CB, hdrs, tune - (59)
12.63 @ 112.93 - 05Vettelag - 05 F55 A4 3.15 - CAI, cb tune
12.63 @ 112.35 - Lusky - 06 Z51 A6 - CAI, 325 tires
12.65 @ 113.70 - Hitman99 - 06 A6 - CAI, hdrs, tune
12.65 @ 111.39 - 30Milesoffshore - 05 M6 - CAI,CB, Tune - (2601)
12.68 @ 113.92 - Sditch - 05 Z51 A4 - CAI - (188)
12.71 @ 113.70 - C6Brian - 07 M6 - Tune - (1616)
12.72 @ 110.85 - AngeloC6 - 05 F55 A4 3.15 open shroud - (1654)
12.77 @ 110.18 - CMB13 - 05 Z51 M6 - CB, DR - (1269)
12.78 @ 112.50 - Dan-t - 06 A6 - tune - (1179)
12.80 @ xxx.xx - Thanos - 05 Z51 A4 - CB - (59)
12.83 @ 111.00 - TMyers - 06 A6 - CAI, tune - (768)
12.88 @ 112.50 - MickyC6 - 05 M6 - CAI, CB, tune
12.89 @ 112.57 - Bunk22 - 05 Z51 M6 - CAI, CB, hdrs rockers, tune - (860)
12.89 @ 112.00 - Tom400CFI - 05 Z51 M6 - CB -(830)
12.90 @ 114.83 - Normlunt - 05 Z51 M6 - tstat - (541)
12.93 @ 110.64 - C6Vette - 05 Z51 M6 - CAI, CB, tune - (1206)
12.97 @ 111.22 - Zoli007 - 06 Z51 M6 - CB - (226)
12.97 @ 109.00 - Tsnipe11 - 05 Z51 A4 - CAI, hdrs, tune - (697)
12.99 @ 111.25 - Parkev - 05 Z51 M6 - CB - (83)
13.30 @ 110.00 - Chempowr - 05 F55 M6 - CAI, CB - (1041) high alt
13.32 @ 108.87 - CorvettePilot - 05 Z51 M6 - CB
13.33 @ 113.31 - Gaussian Mist - 08 F55 Npp M6 - Npp comander - (2706)
13.95 @ 104.94 - Fright88 - 06 A6 -CB, hdrs - (1683) high alt
Internal Engine Modifications
10.66 @ 131.68 - Doug@ECS - 08 Z51 M6 NPP -Blistens, H &C CAI, hdrs, 3.90, tune DR - (3198)
10.76 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (782)
10.87 @ 125.33 - Tek-Newbie - 05 A4 - CAI, CB, conv, H&C, hdrs, 3.42, intake, tune, DR
11.01 @ 122.53 - Thesubfloor - 07 A6 - CAI, cam, Conv 3.42, hdrs, DR - (3154)
11.13 @ 125.03 - Tony B4 - 06 A6 - CAI, Cam, CB, Conv, hdrs, PIntake/TB, udp DR - (3188)
11.17 @ 120.58 - Texasranger - 08 A6 - CAI, cam, hdrs, gears 3.15, tune, DR - (2805)
11.19 @ 129.02 - DSP300C - 07 M6 - CAI, cb, fast H&C, hdrs, gears 4.10, tune, DR - (3444)
11.20 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdrs, no muff, tune,DR - (2478)
11.23 @ 123.00 - Texas Ranger - 07 M6 - CAI, CB, cam, hdrs, 4.10, udp, tune, Z06 tires - (1696)
11.35 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, CB, cam, hdrs, portfast/tb, tune, Dr - (3472)
11.37 @ 124.40 - Evilways - 06 Z51 A6 - CAI, CB, cam, hdrs, L92/L76 Combo tune, PS2 - (2443)
11.39 @ 122.58 - Isaiah48 - 05 Z51 M6 - CAI, CB, H &C hdrs, tune, DR - (2801)
11.45 @ 124.20 - Joe G - 05 Z51 M6 - CAI, CB Cam, hdrs, 3.90, portedfast int, tune, DR - (3523)
11.46 @ 122.96 - Superstock1200 - 06 A6 - CAI, CB, cam, hdrs, portintake - (2847)
11.49 @ 125.62 - Wa$nt me - 06 Z51 M6 - CAI, CB, cam, hdrs, intake, udp, tune - (1610)
11.50 @ 125.76 - BlownV6 - 06 A6 - CAI, CB, H&C, hdrs, tune, DR
11.52 @ 125.73 - High Roller1 - 06 Z51 A6 - CAI, CB, H&C, hdrs, udp, tune, DR - (1909)
11.53 @ 124.97 - Boiler RXC6 - 05 F55 M6 - CAI, CB, H&C, hdrs, intake, tune -(871)
11.55 @ 126.31 - Bowmanized - 07 M6 - CAI, CB H&C, hdrs, PFast, susp tune, DR - (2757)
11.68 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (662)
11.76 @ 116.76 - 1955 Belair - 05 Z51 A4 - CAI, CB, conv, H&C, hdrs, intake, tune, DR
11.79 @ 120.12 - Greentank - 06 A6 - CAI, CB, 3.15, H&C, hdrs - (1821)
11.80 @ 123.50 - Xstang - 05 Z51 M6 - CAI, 3.90, H&C, hdrs, tune, DR - (1178)
11.94 @ 121.11 - Beefcake - 08 A6 - CAI, Cam, hdrs & tune -(3039)
11.98 @ 120.87 - Mr Z51 - 06 Z51 M6 - CAI, Cam, 4.10, hdrs, ported int, udp, DR - (1265)
12.31 @ 119.28 - Black02SS - 07 M6 - CAI, Cam, hdrs & tune
13.12 @ 119.00 - Mitchell242 - 05 M6 - CAI, CB, H&C, hdrs, intake, tune
Power Adders (supercharger, turbo, nitrous)
9.73 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, Cam, conv, hdrs, RPM trans, 3.4 gears, tune DR - (3262)
9.80 @ 146.77 - Todd@RPM - 05 A4 -TT 427, L92 heads, 3.42 RPM Trans DR (3187)
9.93 @ 136.88 - Tekhombre - 05 M6 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune - (1157)
10.29 @ 138.17 - BlownV6 - 06 A6 - N2O, CAI, CB, H&C, hdrs, tune, DR
10.29 @ 135.00 - Willisfast - 06 Z51 M6 - SC with meth, cam, CB, hdrs, DR
10.55 @ 135.06 - The Game - 08 Z51 M6 NPP - ECS Novi2000, alky, hdrs DR - (3238)
10.68 @ 133.21 - Schilitj - 05 Z51 M6 - SC, CB, H&C, hdrs - (3529)
10.81 @ 126.44 - N77nxc - 07 A6 - CAI, cam, conv, hdrs, N20, DR - (3230)
10.86 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, CB, conv, 3.73, hdrs, tune, DR - (480)
10.89 @ 129.93 - DTE - 05 A4 - Gears, Mufflers, Twin Turbo, DR - (939)
10.96 @ 129.73 - Blue Racer - 05 Z51 A4 - SC LPE 427 & RPM trans DR - (1795)
10.99 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, CAI, CB, hdrs, tune, - (3300)
11.09 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdrs, DR - (2825)
11.18 @ 125.42 - Stuart3232 - 06 Z51 M6 - N2O, CAI, CB, DR
11.28 @ 126.48 - MCV - 06 A6 - SC, CAI, CB, tune, DR - (1652)
11.28 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, CB, hdrs - (1804)
11.31 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdrs, tune - (1900)
11.37 @ 126.64 - Nine Ball - 05 Z51 M6 - SC, CB, cam, hdrs, tune, DR - (589)
11.40 @ 121.47 - C6 Roller - 05 A4 - SC, hdrs, DR - (1772)
11.89 @ 120.20 - FLC6 - 05 A4 3.15 - N2O, CAI, CB
1/8 mile (All entries)
7.34 @ 96.69 - Tony B4 - 06 A6 - CAI, Cam, CB, Conv, hdrs, PIntake/TB, tune udp DR - (3056)
7.35 @ 95.10 - Joe G - 05 Z51 M6 - CAI, Cam, 3.90, hdrs, ported fast - (3561)
7.36 @ 98.03 - StageIt - 08 Z51 M6 -Cb, hdrs, 3.90, Intake, Et Street - (2863)
7.50 @ 99.47 - Vettechictwins - 08 Z51 M6 - CAI, Cam, CB, hdrs, PIntake/TB, tune PS2s - (3081)
7.59 @ 95.93 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2556)
7.65 @ 93.64 - C5Pilot - 07 Z51 A6 - CAI, hdrs, PIntake/TB, tune Dr - (3558)
7.83 @ 92.14 - Bunk22 - 05 Z51 M6 - CAI CB, hdrs, Fast, rockers & tune - (2671)
8.14 @ 90.00 - Carmos - 08 A6 Z51 NPP - (2660)
8.45 @ 85.00 - ByByBMW - 05 A4 3.15 - CAI CB, tune - (1664)
The bold numbers refer to the post number utilized to report the elasped times in this thread
#3567
Hey Joe, 11s
Dean & James welcome to the list
Joe it is amazing! but it must be the driver and not the clutch plate
#3568
thanks guys, number 1 for bolt ons w/o DR is almost teeshirt quality hah very cool though, this list helps alot seeing where c6's with similar mods stand. very helpfull, thanks
James
James
#3569
Jo Siffert would be PROUD!
There is a rumor that Siffert snuck out of Ohio and found some good air and some excellent traction. The rumor is that he not only broke 12 seconds, but absolutely killed it with a 11.79 run at 118.9 mph! And that's with a bolt on lowly LS2.
Siffert, YOU ARE MY NEW HERO!!!!!
Glenn
Glenn
#3571
St. Jude Donor '08
Glenn
Glenn
I also heard a little rumor that Dennis snuck out for some of that good air also and ran a 10.69@126.30mph with a whopping 1.43 60ft! All with just bolt ons !
#3572
St. Jude Donor '11
#3573
looking at the top 10 for showroom stock interesting that 6 of the 10 are automatics mainly the 08 a6. So much for those that insist a real performance/sports car has to be an m6
Ted
Ted
#3575
Glenn
Glenn
All he needs now is a loose converter to take out most LS3s!
#3576
Most people that say automatics or paddle shift transmission cars are lame just show how ignorant they are. I have nothing to "prove" by owning a M6 Vette, or any other car. My dad raced top alcohol dragsters in the NHRA for many years, and raced 'Vettes too...and what were his cars?
Automatics.
Who do you think talked me out of buying the M6? Him! He has been racing for longer then I have been alive, I took his advice.
#3577
Automatics.
So you have an automatic in TA/D? really? you sure about that? Airshifters aren't automatics...
As for class racing, you will see most of the cars run autos not because they are quicker but because they can be more consistent and it reduces driver error not because it is any quicker.
Go to the pro categories and you see manuals i.e. ProStock and many of the comp eliminator cars.
#3578
St. Jude Donor '08
Since we are hearing all these rumors about new times i thought i might share this rumor too!
I hear that someone is going to lose there 1st place spot on the H/C list.
#3579
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Of course naturally I'll just take his car back to the track and go faster, and now Ed will want me to do it rather than me asking him.
#3580
Okay, Okay, please don't take me seriously. Just having a little fun. I know you guys run automatics so you can sip on your capacino while going down the track
Anyone who understands drag racing understands that automatics do have several advantages. Nothing wrong with doing what works. No right or wrong answers to the transmission wars. We're all in this together
