Tech 2, can do?
Old 08-02-2007, 07:07 PM
Shrike6
Somba master
Support Corvetteforum!
Shrike6's Avatar
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Default Tech 2, can do?
Can you reset the temps at which the fans come on ( and percentages) useing a tech 2?
GM
Old 08-02-2007, 09:17 PM
Roofless
Roofless's Avatar
St. Jude Donor '11,'13
Sure can
Old 08-02-2007, 10:48 PM
GMautotech
GMautotech's Avatar
You can only command the fans on/off with the Tech II and candi module hooked up to the vehicle. You cannot reprogram the fan temp settings with the tech II.
Old 08-03-2007, 02:32 AM
leres
leres's Avatar
EFILive's V2 FlashScan can program fan settings on a C6. (It can also disable CAGS!)
Old 08-03-2007, 03:00 AM
Evilways
Evilways's Avatar
I'd buy anything on the market if it could turn TM and TPS all the way off.
Old 08-03-2007, 05:21 AM
LS2-Zomb!e
LS2-Zomb!e's Avatar
Yup!
Old 08-03-2007, 11:32 AM
cerino2000
cerino2000's Avatar
why not buy a handheld like predator or something. Tech2 is expensive.
Old 08-03-2007, 11:59 AM
Shrike6
Somba master
Shrike6's Avatar
Don't plan on buying anything. A friend who is a mechanic has a tech 2, and I just wanted to know if it was possible to reset the fan temps with it.
GM
To Tech 2, can do?
Quick Reply: Tech 2, can do?
