Flowtech Terminators on a C6?
I was wondering how tough it would be for an exhaust place or like a Meinekee or something to put on flowtech terminator mufflers or any other mufflers that arent normally made for corvettes IE a universal turbo muffler...i know anything is possible but would like some insight as far as it fitting and stuff...i guess they would have to put some new tubing in at the most maybe new tips...here are the mufflers, they are basically like regular 40 series 2 chamber flowmasters, so i know they will fit; plus measured...
http://cpwstore.carpartswholesale.co...y=1&make_code=
theyre down towards the bottom
guess you need offset inlet offset outlet 2.5 mufflers and anything is possible....
i couldnt decide between borla or b/b PRT but i know terminators would sound similar if not better than the flowmasters
The Magnaflow #14336 are an easy replacement for the stock mufflers, cut the old ones out, weld the new ones in. They are 2.5" in and out so you get increased flow over the less than 2" outlet stock mufflers. They also weigh a lot less and sound much better.
