2007 z06 ecm location
Old 01-09-2012, 08:54 PM
traderjoe5386
traderjoe5386's Avatar
Default 2007 z06 ecm location
i really need to see a photo of the ecm bolted to the pass. fender. i for the life of me cant figure it out plz someone help with a photo
Old 01-09-2012, 09:30 PM
RicK T
RicK T's Avatar
There are a few pics in Chuck's post here. Hope it helps. There might be better pics on his website.
http://forums.corvetteforum.com/c6-c...rder-tune.html
Old 01-10-2012, 10:52 AM
0Chuck CoW
Former Vendor
Chuck CoW's Avatar
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Thanks Pal!
Thanks Pal!
Chuck CoW
Old 03-11-2014, 06:58 PM
MIZR1
MIZR1's Avatar
Originally Posted by Chuck CoW
Thanks Pal!
Chuck CoW
Except the link is to a picture of a regular C6, not a Z06. Any pictures available of what was asked for, a Z06?
Old 03-16-2014, 03:35 PM
0Chuck CoW
Former Vendor
Chuck CoW's Avatar
Default The ZO6 is slightly....
The ZO6 is slightly different. If it's an 08 and earlier Z then the PCM is just behind the dry sump tank
and it's accessible just the same as the regular C6 from the same method but you just have to get in there
a bit further with your hands.
If it's ANY Corvette after 2009 then the pcm sits up high in the fender just above the opening in the fender well.
You access it just the same as the earlier C6 outlined in the above links, but you should have the vehicle
just a bit higher up off the ground to make it easier to reach up there.
Call me if you're stuck.
Chuck CoW
To 2007 z06 ecm location
Quick Reply: 2007 z06 ecm location
