Halltech Shroud Mod Gains
My son came by today with his scanner. I wanted to see what my inlet air temps (IAT) were doing with just the K&N inlet. We then logged the same data on CBFR's car that has a K&N inlet and the DIY Halltech Shroud mod. The good news is that I have a free mod that I can do that will help me quite a bit. The bad news is CBFR says it's a real pain to pull that shroud.
Ambient during my logging was around 85F. IAT's ran between 104F and 123F. During a hard run it would get down to 104F and I was letting off at around 55 mph. CBFR IAT's ran 87F to 98F (the ambient was up to 86 during his logging). Plus his temps would drop a lot faster than mine and would never heat up as much as mine. That means he was as little as 1 degree over ambient and the closest I got was 19 degrees above ambient.
So tomorrow I get under the car to remove the shroud. I'll post my temps after doing the mod, but I would expect the same results as CBFR.
If I can improve my IAT by 18 degrees, that is around .15 and 1 mph at the track.
regrading the pita part with that mod halltech cai piece. this is exact reason i told yell03 to just drill a few holes on each side, it is a quick 10 minute job at the most. let me know if you want help.
1 Post
Originally Posted by cbrf4i1
i also added a panel on each side to help direct outside air to the air filter. you sure don't want these ambient air going by the headers and then out of engine compartment without giving the air filter a shot at it first.
If you modify it , you then have the beginning of an air plenum that houses the filter. Working on ducting the fascia extension openings to within a few inches of the filter
Photo Sharing - Upload Video - Video Sharing
You may consider just taping up the holes on the front of the car to block the air flow provided by the shroud.
Location: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Originally Posted by Silver05GTO
Why not just cut the shroud like some of the other CAI's do? If you ever want a full stock peice back they can be bought cheap from GM (like $35 I believe)
for us in AZ, summer time high temp can reach 115*+, (3 straight months of 110*+) stealing air from the radiator to lower the underhood temp is like rubbing peter to paid paul.
Originally Posted by RBYCC
Howard (yell03) mentioned reversing the stock filter shield.
