Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-24-2006, 02:38 PM   #1
boogieman
CF Senior Member
boogieman's Avatar
Default Determine rear end gear ratio with th vin #
Is it possible to determine the rear end gear ratio with the last numbers of the Vin # 11552126 ? The is no tag on the rear indicating what it is...so i don't know if it is a 2 or 3 series carrier
boogieman is offline   Reply With Quote
Old 09-24-2006, 03:12 PM   #2
GMautotech
CF Senior Member
GMautotech's Avatar
Is that VIN supposed to be from your Vette (and the last 8 digits)? That VIN is no good in GM's system.
__________________
David - 07 LMB A6 1LT Z51 QX1
Mods: Free Paddle Shifter Mod - LPE CAI - 160 stat - mechanical O2 sims from cbrf4i1
Kooks LT's + off-road X + Bullets = the sound of music
Added steering wheel radio controls and HUD
www.reichertwoodstock.com/
GM VIN reports, build dates and recall info - PM me with your email addy and VIN (98 and newer only)!
GMautotech is offline   Reply With Quote
Old 09-25-2006, 01:51 AM   #3
calemasters
CF Senior Member
calemasters's Avatar
calemasters calemasters
Quote:
If the correct VIN is 1G1YY24U055112126
the car was built with the RPO GU2 - REAR AXLE 2.73 RATIO
calemasters is offline   Reply With Quote
Old 09-25-2006, 02:52 AM   #4
LS1LT1
CF Senior Member
LS1LT1's Avatar
Send a message via AIM to LS1LT1
Jerry if I recall, your car originally had 2.73s (now 3.73s) didn't it?
Are you just trying to determine if you still have the 2 series carrier (housing new gears) or is this for someone else's car?
LS1LT1 is offline   Reply With Quote
Old 09-25-2006, 11:00 AM   #5
aero400
CF Senior Member
aero400's Avatar
Just realized - becaues the C6 has an enclosed torque tube, one cannot simply jack up the rear of the car, spin the rear tires and count the # of revolutions of the driveshaft. So that does make it hard to figure out what the ratio is without having a VIN or other codes.
IS there a way to figure out the ratio without a VIN or other coding?
aero400 is offline   Reply With Quote
Old 09-25-2006, 01:44 PM   #6
LS1LT1
CF Senior Member
LS1LT1's Avatar
Even with the torque tube one should still be able to spin it in neutral with the wheels up I think.
And of course just checking the codes (GU2, G92 etc.) on the little sticker inside the vehicle determines a lot as well.
Old 09-25-2006, 02:41 PM   #7
Michrider
CF Senior Member
Michrider's Avatar
You could do a mph/rpm calculator. See what the RPMS are at 70 in the direct drive gear. 3rd in autos 4th in sticks. And what the tire size is. There are some websites with RPM calculators that you could punch in the different ratios and tire size and it will give you RPMs for those gears.
Michrider is offline   Reply With Quote
Old 09-25-2006, 02:58 PM   #8
aero400
CF Senior Member
aero400's Avatar
Quote:
Yes, you can spin the wheels, but you cannot see the rotating driveshaft to determine how many driveshaft revolutions per wheel revolution (or vise versa).
Quote:
Good idea. But I've found that doing such measurements and calculations, for whatever reason, never yields super accurate results. It might be hard to determine with certainty between say a 3.23 and a 3.42. However, if one is merely trying to distinguish between a 2.73 and a 3.42, that method would do the trick of course. Good info - thanks.
Old 09-25-2006, 03:52 PM   #9
LS1LT1
CF Senior Member
LS1LT1's Avatar
Oh true, I see what you were saying now.
Old 09-25-2006, 06:21 PM   #10
boogieman
CF Senior Member
boogieman's Avatar
That is correct, I now have 3:73s. I purchased a spare C6 automatic transmission and the guy threw in the rear end. Usaully the rear has a tag, this one did not so I am trying to find out if its a 3 series carrier.
Thanks for the replies .......I guess its a 2 series which is really worthless to me. If anyone needs it let me know, make me an offer.
Old 09-27-2006, 04:12 PM   #11
UDRIVESLOW
CF Senior Member
UDRIVESLOW's Avatar
ernest.lockhart
Default ratio
find your rpo code sticker.........
UDRIVESLOW is offline   Reply With Quote
Reload this Page Determine rear end gear ratio with th vin #
Tags
axle, c5, c6, code, corvette, end, find, gear, gears, gm, number, ratio, rear, search, vin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
