Who carries a 170 T-stat?
Haven't heard of one, but you can get a good 180 here:
http://performanceunlimited.com/cobr...hermostat.html
Vinci also sells one
I got mine from Vince Hi Perf. When I talked with them, they described it actually as more of a 178 and highly recommended this vs. a 160. Good quality but a little pricey, approx. $70 IIRC. I have mine in conjunction with other mods, including a Ron Zimmer tune and car runs great. I live in GA, and coolant temps stay about 180 on the hiway, and highest I've seen in stop and go is around 200.
Unless You Adjust You Fans To Come On At A Lower Temp You Will See Very Little Difference. Thats The Reason For The 160 Thermostat The Tuners Turn The Fan On At 170
My car now stays between 180-187 with the 160 thermostat and the fans adjusted. Stock it says at 200-205.
My tuner told me with HP tuners you can not lower the fan temperature setting but you can increase the fan speed at turn on.
