CAM Differences
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
when I did the head/cam work last month, my mod shop owner suggested this cam: Cam 224 230 581/592 114 LSA. When looking at my dyno, great low end torque that continues past 6000rpm. this cam has a mild lope, my wife commented on how "stupid" it felt for the first couple of rides, but now doesn't either notice it or comment on it. I'm afraid to ask in case it is the latter!
Here's my mods and mild cam dyno sheet.
06 Z-51 A6 - Haltech, underdrive pulley, LG headers w/Cats, G5 Executive cam pakage No loss of low end torque here!! Sorry I do not have the cam specs to give you.
Both dyno sheets above show readings from about 2,700 rpm and up. What about UNDER 2,700 rpm?????
As was stated in another post, "streetable" is a RELATIVE term. For many, street torque ("low-end torque") is 1,000 - 3,000, because that's where a street car is used the greatest percentage of the time when on the street. Thus, the above dyno charts do not show true "low-end torque".
Of course, for the drag strip, you may never even see under 2,700 rpm, so in this case, a bigger cam seems to be a worthwhile modification, and the typical dyno chart is useful.
I wonder if dynos can pull and yield accurate readings from as low as 1,000 rpm and up... because such info would be truly useful for "street" tuning.
Rarely do I see a wheel dyno start much below 2500 rpm's on this forum. In my car you are talking about moving the rollers in 4th gear to make a pull so I doubt you will get numbers from idle on a rear wheel dyno like you could an engine dyno. Bogging the motor isn't a good thing. Look at how flat the torque curve is on the dyno sheet between 2500 and 3000 rpms. It is roughly 30 to 40 ftlbs over stock and I would be willing to bet it is better than stock at 1000 or 1500 rpms too. My car is very streetable and had no loss in low end torque and that is all I was trying to say with the dyno graph. Comparing the two dyno graphs I would say it looks like the LS2 has a more low end torque then the LS6 just like C-ya said as well.
Originally Posted by SlickBlackVette
Rarely do I see a wheel dyno start much below 2500 rpm's on this forum.... Bogging the motor isn't a good thing...
One big thing I notice is the before numbers are not tuned. A/F plays alot with how much rwhp a combo makes. The following dyno graph shows 10% less fuel @ the bottom end, not saying one is right but there is a big difference in fuel. Gotta compare apples to apples.
Phil
Phil
I run a 230-236 112 +2 XE-R cam in my full H/C 90/90 setup. I drive it in bumper to bumper DC traffic whenever I want. Even out 66 to Haymarket which is ugly. I idle at 825 and the car pulls cleanly to the 6600 rev limit. I run 11:1 compression which is not that high. I usually shift it at 2600-2700 unless having fun.
I run a Speed Density tune that really tamed the setup. Thanks PHIL97SVT!
My car is NOT a "race car". It's a "gentleman's cruiser". I take it on trips and wouldn't hesitate to take it cross country tomorrow.
EST RWHP 460-470.
EST RWHP 460-470.
I be that car (Stock) had at least 10 HP and 10 Torque with a tune.
I'm also not sure why they are running so lean then so rich (after the tune), maybe it's not tuned? This car has more HP in it, lean it out a bit up top and give it more fuel on the bottom. Torque wants fuel, HP wants air. Either way those are nice numbers and I bet the car is a blast to drive.
Now, I need to pick a cam for myself
Originally Posted by valdeztke
So would you all say this 224/227 .563/.569 114 LSA
is an aggresive cam with alot of low end loss?
Trust me, she's shopping new appliances....
#33
Dave Im right there with ya! Oh these specs are right 224/227 .563/.569 114 LSA the reverse is the other one 227/224 I looked at the Thunder Racing website and they are two different cams. This one is a SC / Juice cam..
WKMCD you have to let me check out your vette one day .. I am down in Alexandria VA ..
#34
Lemme find you a similiar cam tha it proven to be an exceptional cam in LS1's...Gimme a couple of minutes to find it.....
#35
#36
Ok....found it.
This is the cam you want. It is perfectly streetable, will make good power, idles nice, and works great with heads should you decide to get them in the future.
This cam is in tons of LS1's and LS6's and has been proven time and time again.
If you want a mid sized cam, this is it.
224 228 .581 .588 114 LSA
#37
I do believe I will be putting a Thunder Racing cheaTR cam in my car as soon I get a chance. I have heard some on F-bodies and they pick 20-40 hp and keeps the cars very stealthy. Being I have kept my stock cat-back with my Kooks 1 7/8, this is the way to go for me. Over 400 to the wheels and stock Idle and drivability with power everywhere under the curve. You'd be surprised to know that this cam is not that hard on the drivetrain either. You guys can read up on the cam over at LS1tech.com. Do a search for it or patrickg. Plus I believe when I put the procharger on the car I will be well over 500-525.
#39
Originally Posted by CYA-Vett
This a a tuners best friend an untuned car verses a modded tuned car.
#40
