Thinking about getting Non-runflats - BFGoodrich g-Force or Michilen PS2?
I have the KDW2's. i absolutly love these tires! they have around 200 track miles on a race track with them and they have done phenomenal!!! They look sick as well!
What are you guys doing on long trips when you don't have the runflats? Do you carry a can of pressurized flat fix? Do you just keep the number of AAA close by?
Thanks,
Glenn
Thanks,
Glenn
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Thanks,
Glenn
Thanks,
Glenn
OK....so there's the problem of getting immediate help once you get a flat...with runflats you can drive a ways to get it repaired...and, hopefully, it will, indeed, be repairable (it may, or may not, thus negating some of the advantage of running them)
a far bigger problem is that of finding a runflat in stock, at a Goodyear dealer who's trained and qualified to swap the tires without damaging anything! you'll have better luck in a large urban area....small town? forget it....
i've made many long trips.....i go by two things: first, that flats are pretty rare in the first place, and second, that AAA will simply tow me when necessary.........so far, 29,000 miles and no flats at all (about half with non-runflats)
Keep the stock run flats for road use. Get another set of wheels
& tires for track use. Then you have the best of both worlds. The Goodyears are fine for normal daily driving.
NCM Lifetime Member
Originally Posted by bccrws
Good question!! I'd love to hear what people's thoughts are on this.
Originally Posted by 4 MY EGO
I carry a small 12v compressor and a self vulcanizing plug kit. Pep Boys, Auto Zone, just to name a few that have these.
Thanks,
Glenn
NCM Lifetime Member
Many excellent suggestions, I think do this trick plus join AAA.
Thanks,
Glenn
Thanks,
Glenn
NCM Lifetime Member
Glenn, check your PM Michael
Originally Posted by Walt White Coupe
Reports on the BFG's are very good. If I needed tires right now, pretty sure that would be what I would get except one size wider front and back.
They're both good tires, I think the PS/2s are a bit better but then they cost a fair amount more. I'd be inclined toward the BFGs if you're really planning on pushing it and going through them pretty fast and the PS2s if you're planning on keeping them for 2 or 3 years. Of course this depends on your tire replacement budget! Other reasonable options are the Toyo T1R and the Falken FK451.
#33
Former Vendor
Thanks,
Glenn
Thanks,
Glenn
I run Falken GR-2 Beta's and love them.
#35
Originally Posted by corvette pilot
you get free roadside assistance from chevy during the warranty period. Don't need AAA.
#36
Originally Posted by burtonbl103
I have the ps2s and love them
Much quieter and stick like glue !
#38
Originally Posted by johnnybegood
BFG's do not even come close to the michelin PS2. Hence the huge difference in price. The KDW's are noisy and they are not a sticky.
and same thing on the stickiness issue.....i've run them at Thunderhill and i didn't feel them slippy at all, and they stuck much better than the stock runflats......
#39
Ok it is open season on which tire to get to replace runflat or non-run flat but which ever tire you get where is the best place to buy them and if applicable have them installed both at the best prices?
Also which all season tire is superior in both wet and dry whether a run flat or not?
#40
The noise claims are : BFG tires are made by Michelin and the KDWs use the same carcass as the Pilot series. The PS2 is nothing more than a Pilot variant.
