What will it take to run 11.90's
2006 A6
INTAKE
UD PULLEY
FLUIDS
CAT BACK
TUNE
DRAG RADIALS or SLICKS
I know this is not enough but what do you think this combo should run?
INTAKE
UD PULLEY
FLUIDS
HEADERS LG'S
TUNE
DRAG RADIALS
Will this combo do it?
What will it take?
2006 A6
INTAKE
UD PULLEY
FLUIDS
CAT BACK
TUNE
INTAKE
UD PULLEY
FLUIDS
HEADERS LG'S
TUNE
DRAG RADIALS
What will it take?
2006 A6
INTAKE
UD PULLEY
FLUIDS
CAT BACK
TUNE
INTAKE
UD PULLEY
FLUIDS
HEADERS LG'S
TUNE
DRAG RADIALS
2006 A6
INTAKE
UD PULLEY
FLUIDS
CAT BACK
TUNE
INTAKE
UD PULLEY
FLUIDS
HEADERS LG'S
TUNE
DRAG RADIALS
Here is how I would start with mods to get into the 11's.
When available a high stall TC and 2.73's (By the way, I would let a few people do this mod before I jumped in head first on it)
Honker or vararam intake
Long tube headers
DR's
This will put you in the 11.9s on a good day.
Oh, by the way I don't own a C6, but I did stay in a holiday in last night.
Originally Posted by EB20003
What he means is that he doesn't own a C6 "yet". We are working on him though.
Fluids, not sure what this can do for you ET wise, I know of no fluids that will make your car go any faster than stock
Many report 8-10 RWHP gains after swapping fluids over (oil trans dif) less friction = more RWHP
LG has a post with redline do not remember the exact #'s
Horsepower tv got ~8.9 RWHP with Royal Purple fluids (LS1).
I have read others but dont recall details.
Great bang for the buck mod IMO.
2006 A6
INTAKE
UD PULLEY
FLUIDS
CAT BACK
TUNE
INTAKE
UD PULLEY
FLUIDS
HEADERS LG'S
TUNE
DRAG RADIALS
2006 A6
INTAKE
UD PULLEY
FLUIDS
CAT BACK
TUNE
INTAKE
UD PULLEY
FLUIDS
HEADERS LG'S
TUNE
DRAG RADIALS
Originally Posted by shurite44
SoldSyclone, I am a little skeptical of those claims. Just my opinion though.
Originally Posted by shopdog
Well, if the intake is a FAST with direct port nitrous running a 200 shot, then you might dip under 12. But an air cleaner housing isn't going to do it. Undersize pulleys won't do it. No magic fluids are going to help. Headers and drag radials will help, but not enough.
DRs and opening the top end.
heads, cam, UD pulleys, headers and a good tune should hit 11s, Id expect.
if you can cut a 1.5-1.6s 60ft...the extra power should push you to 11s.
500-550 RWHP needed to run 11.90's ??????
No, I've seen Z06's with only 355-360 minimum run 11.90's. Then again, I've known of other Vettes with 500 rwhp that could not run 11.90's and that's because of the wrong set up and poor driving skills. From what I have been hearing from people at the track, the C6' probably needs, a Calloway Honker CAI, long tube headers, X-pipe or high flow cats, a set of Borla Stingers or your choice, and most of all a good tune. Tuning in crucial for this particular car for some reason. Some people are getting as much as 20 rwhp and then others are getting as little as 5hp. It all depends on the tuner and application. I would say 375 rwhp/365rwtq with track set up and exceptional driving skills. You would need at least 1.7 60' times to accomplish this task.
Tires, torque converter and tune will get you there at a sea level track in good weather. My 2000 ws6 formula went 7.89 at 87 mph on a 1.69 60' with a well matched converter 17" m/t drag radials and a 345 hp SS air lid.
Hey It was on TV it must be true, I would like to see more independent tests.
Originally Posted by Lusky
i'm sure someone will chime in with these mods and their times & hopefully before I have all this on my car
Lusky
Actually I , I would rather let some other guys experiment first especially with the rear end and TC. But I would be real curious to see what a high stall and 2.73 rear end would do in the A6.
☠☣☢ Semper Ebrius ☢☣☠
INTAKE
UD PULLEY
FLUIDS
CAT BACK
FLUIDS
CAT BACK
TUNE
I have lpe h/c,and there air intake,2800 tq converter ,headers,high flow cats 430 rwh have ran12.1 with tires spinning well into 2nd. need to learn to back off a little on the right foot till tires are hooked up. should be able to get into 11,s with stock runflats.Track closed till spring. Next mod tires.
Originally Posted by Fore58
SoldSyclone,
No, I've seen Z06's with only 355-360 minimum run 11.90's. Then again, I've known of other Vettes with 500 rwhp that could not run 11.90's and that's because of the wrong set up and poor driving skills. From what I have been hearing from people at the track, the C6' probably need, long tube headers, X-pipe or high flow cats, a set of Borla Stingers or your choice, and most of all a good tune. Tuning in crucial for this particular car for some reason. Some people are getting as much as 20 rwhp and then others are getting as little as 5hp. It all depends on the tuner and application. I would say 375 rwhp/365rwtq with track set up and exceptional driving skills. You would need at least 1.7 60' times to accomplish this task.
BTW I was being sarcastic about shopdogs post
I was thinking 380 RWHP may do it with a good 60' ET street may be needed.
I am willing to do all the little things to get the results, I set some records with My stock Turbo Syclone
Stock Motor, Trans, Turbo, etc
Only HP Mods: K&N, Cat back and a Tune
Best ET 12.42@106.8 most run 12.8-13.2.
BTW went 13.4 @ 100 bone stock
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
I ran 11.9@114/w 1.7x 60 ft. with TPIS LTs, no cats, stingers, VR, LS6 intake, tuning, 3:73 and Yank 2800 with a '00 C5 A4. 338HP/340TQ
Cajun
Cajun
Cajun
Cajun
What do you think of 1st gear in the A6, will gears and or a stall be needed?
I run at Las Vegas Motor Speedway whick hooks but is at 2000'
I was thinking of leaving them stock and spraying out of the hole...
Would love to see a 10.99 on the spray!
