ZIP-TIE or something like it...
Old 10-13-2005, 05:16 PM
not08crmanymore
not08crmanymore's Avatar
Default ZIP-TIE or something like it...
will it work w/a c6 since there are 2 air filters i'm told.Will a Z06 filter work??
Old 10-13-2005, 07:52 PM
aaaaa
aaaaa's Avatar
Yes. I just modified mine last week. You don't actually need the zip ties because of the way the filters are held in. Simply cut the top off the air filter covers leaving enough of the sides so that the spring clips still work. Once you get into it, it will be obvious. I was advised to retain the large cover to prevent water from leaking in between the hood and front facia and dripping on the now exposed filters.
Easy job-
Old 10-13-2005, 08:36 PM
not08crmanymore
Default cutting
so,I want to cut the top of the box or the bottom in order to get the AIR but NOT the water from the hood??thanks.I like that Z06 filter,too!It's HUGE!!
Old 10-14-2005, 11:24 AM
aaaaa
aaaaa's Avatar
It's pretty much self explainitory(sp) once you see it. There are individual covers on each filter and a single large cover over both.
Good luck
Old 10-14-2005, 12:16 PM
not08crmanymore
Default covers
thanks!!Hey,I just noticed you're from salt lake city...I went out w/a girl from there in the 70's!Don't know why i bring that up,but what the hell!
Old 10-14-2005, 12:27 PM
J-Rod
J-Rod's Avatar
Good to hear. that cheap and easy mods live on....
Old 10-14-2005, 01:21 PM
aaaaa
aaaaa's Avatar
Read the last two posts. Dating a girl in SLC and cheap and easy mods-just strikes me funny
Old 10-14-2005, 03:19 PM
not08crmanymore
To ZIP-TIE or something like it...
Quick Reply: ZIP-TIE or something like it...
