Need Tire Pressure Sensor 101 for track use
I have searched and read a lot of info about TPS. Can someone help me put it all together?
1. If you stick on wheels with new/different sensors you need to have the Tire Pressure Monitoring (TPM) systems relearn the sensor IDs. The GM TechLink shows two methods for doing this, one using a change in air pressure, the other using the TPM Diag tool. Can anyone confirm that the air pressure change method works?
So what is a good guess at the specified amount of pressure change required to excite a TPS?
2. If I install a set of wheels without TPS and want to track the car, I won't be able to use Competition mode and Trac but can turn them off before go out on the track?
4. Some people feel the problem with using TPS with track wheels & rubber is the diff in cold and warm tire pressures can trigger TPM warnings and disable competition mode? Has anyone experienced this feature??
After all this rambling, what I am really looking for is the C6 tech recipe for installing some track wheels then going back to my stock wheels & tires after the track day is over. I would like to be able to use Competition Mode on the track also.
"When to Perform a Tire Pressure Relearn
The tire pressure sensor (TPS) relearn procedure must be performed after every PDM replacement, every sensor replacement, and every tire rotation. Once the TPM learn mode has been enabled, each of the sensors’ unique ID codes can be learned into the PDM’s memory. There are two ways to excite the sensors and enter the learn mode.
Pressure Change Method -- This is performed by increasing or decreasing the air pressure in each tire by a specified amount, which forces the sensors to transmit in re-measure mode.
In a previous posts some folks said it takes a while before the TPM figures out the sensors are gone. After 50 miles or so the TPM complains and the ECU tries to limit speed briefly with TRAC then gives up. Using reset clears the warnings. If you have car built before Feb05 you may have a different TPM that doesn't create AH and TRAC issues if you don't have TPS installed.
If you have a later build car like I do, I think you would want to turn AH and Trac off before you go out on the track unless you have driven the required miles to have the ECU handle the no TPS fault.
3. In order to use Competition mode for my track wheels I would need to have TPS installed in the wheels and have the TPM learn the new/different sensors IDs?If you have a later build car like I do, I think you would want to turn AH and Trac off before you go out on the track unless you have driven the required miles to have the ECU handle the no TPS fault.
I am experienced on the TPM sensors since having just done this. Change in airpressure does not work on the C6 but it does work on my Tahoe - completely different systems. On the C6, even though there is a mentioned option of using a magentic tool, I could not get this to work with 4 new, never initiaized sensors - maybe the magnet will work with sensors previously initialized. Had to go to the dealer so they could use their special RF induction tool (looks like the handheld inventory devices used in supermarkets). Dealer (non-selling) did it for me in 5 minutes no charge. Sorry I'm not experieinced enought to answer your track questions but I'm sure someone will. Hope this helps.
St. Jude Donor '07
I believe it's going to depend on your build date. My car is a december build, and I am able to disable traction control and active handling. I don;t use competition mode, but I believe Rex said you can make that work too.
Rex has a newer C6 and was unable to disable TC/AH and was also unable to access competition mode. This in direct contrast to his "older" C6. His dealer worked with him and they came away thinking that February was the month that this functionality changed.
Need more help with TPS
I just picked up a set of polished wheels. The plan is to move the run flats and TPS to the polished wheels then get some trackable tires for the painted wheels I have now. Since I have a March build date car I have the later TPM which, if I understand this correctly, you can't disable TC/AH if you don't have 4 TPS that are registered with the TPM.
So I have some more questions.
1. I assume that once the TPM reports I have no sensors the engine control and TC/AH limits the cars performance? By not being able to turn this off I can't track the car.
2. So I was wondering if I could then remove the fuses for the TPM and/or TC/AH and be able to still get full power and have ABS? I don't know what the fuse numbers are at this point so that would be another question.
Another option would be to get 4 TPS for the new tires and see if I can find a local dealer that will register them for me every time I change wheels. This makes me wonder how much the hand held tool costs that the dealer uses to register the TPS with the TPM?
Why does this have to be so dam complicated??
St. Jude Donor '07
I have a little more experience with this now, but my car is a December build so who knows if this applies to you. I had it at the track a couple of weekends ago with track wheels/rubber mounted-no sensors. I did bring along my stock setup in case it rained.
My car was definitely reading the sensors while in the pits parked next to the stock wheels/tires, as I observed the pressure creeping up while the tires sat in the sun.
You can take your street wheels to track so car will read the street sensors.With no senasors at all--your car will read sensors of any other C6 in the area.Or just place sensors(new set) on track wheels.
As Matt mentioned it depends on the build date of the car.
the new cars if you put differnt wheels on or wheels without TPS you will be to "Reduced Speed" mode and limited to 55 MPH.
So switching wheels may not be an option yet. Running with AH/TC off will not change the situation. Purcashing new TPS for each set of wheels AND programing them is going to be a PIA too.
Come on LS2 Edit programers, an other thing to work on.
It appears the performance limiting logic is programmed into the engine ECU. So pulling fuses for the TPM and TC/AH won't solve my problem.
This really sucks. I didn't think I needed LS2 Edit but when faced with crap like this sign me up if it will fix my car so I can use it. They should change the name to "LS2 Fix".
So each time you replace a wheel with a different sensor you have to register the freq ID for the new sensor. Switching between your street and track wheels would require registering the TPS IDs each time you change wheels.
It is also unclear to me how long or far you can drive the car without the original TPS installed before you hit the reduced power mode. The last thing you want to happen on the track is to suddenly lose a lot of power with somebody behind you. So keeping the current TPSs next to the car in the pits probably works but the question is how long it lasts once you start turning laps.
This F'ing sucks!
I got rid of a 2003 Lightning that was faster on the track than most of you here would believe. I got rid of it because I got bit by the road course bug....I got it bad. I spent a fortune making a 5000 lb. truck a track vehicle. Now I buy the car of my dreams (built in April) and I can't run race rubber? I can't afford to go through $2000.00 worth of tires at every track event! At my first event my son and I both drove my Lightning in two different run groups. At the end of the second day with 16 twenty minute sessions and 4000 highway miles on the tires they were gone. $1000.00 down the drain. Why the Hell did GM change the system from the first of the year to the last? All I want to be able to do is turn off all the T/C and A/H. I hate it anyway. This really makes me sick! Is there any hope?
Jerry
Jerry
St. Jude Donor '07
Originally Posted by RedHotBolt
This F'ing sucks!
Jerry
Jerry
Dude it's not that bad-You can get 4 TPMs for 200 and change from Fred Beans. I'd be willing to bet that if you pulled up to the back of the service dept, grabbed a tech and waved a tenner in his face he'd train the sensors for you in about 3 minutes.
I'm sure there will be a more elegant solution soon-either a tool you can train with at home or perhaps LS2 edit can help.
Thanks for the info.
Jerry
This F'ing sucks!
Jerry
Jerry
