What kind of oil comes in the C6 from the factory?
The owner's manual says to use synthetic oil that meets GM standards. Why would GM put one kind of oil in it, only to tell you to use something else? Not many of us want to intentionally void our warranty.
No offense, but geez, open the damn hood and look at the oil filler cap.....
3rd Gear
Originally Posted by jchazr
Aren't you suppose to use mineral oils for the break-in period?
Dude wow, holy crap are you serious?
Where the living heck do you get mineral oil from?
what I am about to say are magic words heed them "10W30 Fully Synthetic" and use Mobil one, or if you can afford it get Redline And oh yeah, you need to put gas in the car too.
I think some of you are misunderstanding what I meant by "mineral-oil." Mineral oil is another term for your natural, non-synthetic, conventional oils. I'm not sure what you thought I meant.
In the future I will use the term "conventional oil" rather than "mineral oil" since it throws some of you off. Sorry.
I have heard and read that it is better to break in an engine using conventional oil, versus synthetics which they say are too slick to allow for proper wear-in/break-in/ring-seal-in. The literature I have read was not specific to corvettes, but cars in general. Basically, use conventional oil for the break in period, and then switch over to synthetic.
I will repeat that I do not have a corvette yet, it is on order. What this means is that I cannot simply go out to my garage and open the hood as some of you have suggested, even after I stated that I did not have a corvette. I guess some people just like to be smart-a$$es.
Since I now know that the vette comes with synthetic, GM obviously doesn't believe in the whole conventiona-oil-for-break-in process. Either that or GM used conventional oils to break the engine in at the factory, and then switched to synthetic.
Any comments/opinions on this?
Sorry, I'm just a smartass in general.
Seriously, all 'Vettes have had Mobil One as the factory fill since at least '92, maybe longer.
I know all LT1 cars had it, and the Callaway Twin Turbo cars in the '80's came with it.
As stated previously, most of the "break in" on a new car these days is to help seat the gears in the rear and transmission, and to help bed in the brake pads. The engines are run in at the factory, so they don't require much in the sense of the traditional break in process.
Enjoy your car when it arrives! It took me six weeks of searching before finding mine.
I just change the oil and when I read your post, I became worried that I put in the wrong weight oil.
I am an engineer and raced motorcycles professionally for years at times wrenching on my own bikes. Break-in was always done with "dino" based oils then a switch to synthetic after break in. If you break in with synthetic the rings would not seat and the engine would essentially never break in resulting in less HP because of a lack of ring seal which translates to compression.
I am not a betting man but if I were I would bet my Vette that the engine came already broke in (pre run) or with a "dino" base oil with the synthetic placard and assumption that all who purchase would use synthetic at the first first oil change.
FYI- Shell rotella T- synthetic oil has the same exact properties as Mobil 1 and cost about 6 bucks a gallon at wal-mart. I use it in all my vehicles... after break in.
Good question? Unfortunately I do not think you can get the answer unless somebody knows somebody at the engine plant. KC
i think everyone should check out this site http://www.mototuneusa.com/break_in_secrets.htm
FYI- Shell rotella T- synthetic oil has the same exact properties as Mobil 1 and cost about 6 bucks a gallon at wal-mart. I use it in all my vehicles... after break in. KC
Originally Posted by C4kid94
Completely agree with you, i even started a thread on this. i hate when people are so closed minded and refuse to believe anything but the owners manual and what those idiots at the dealerships say, with out even reasearching the topic
Originally Posted by fdxpilot
Good luck if you need to make an engine related Warranty claim, since according to the Shell Rotella website, it doesn't meet GM4718M, The GM synthetic oil spec for C5 and C6 corvettes.
