Crank bolt happened at 65 MPH!!!
Driving on I-4 in FL, the water temp pegged @ 265++, oil everywhere, belt shredded the hood liner, oil dripping out of the engine. The crankshaft pully bolt is totally out............the only thing that kept it from folling out was the tranny cooler..................Is the engine damaged?? It is smoking!!!
Oy yeah, ALL OF 2,120 miles on the car.....................not bad for $50,000, HUH?
VIN is 110035, build date 11/04.............
Ouch!!!
If you lost engine oil due to this, I would demand a new engine... even the loss of oil pressure for 10 seconds "can" cause damage that would reduce it's longevity, even if they repaired/reassembled everything back together under warranty...
Sorry to hear about this!
This is a reminder for me to do an "advanced search" under the forum for the process to check the crank bolt myself!
Originally Posted by C5 then C6
Sorry this happened to you. It is an OUTRAGE that we have to drive our cars with the gamble of this happening to us. When is the recall coming?
My dealer treated the TSB with concern and performed the work on mine and three other C6's prior to delivery. Here's the earlier post on the subject. http://forums.corvetteforum.com/arch...t-1038771.html
Cruise-In VI Veteran
St. Jude Donor '05
That is why you should wait for the second year of a new generation before you buy one. Let the General work out the kinks and get his act together. In all seriousness, though, sorry to hear about your misfortunes. These things happen. Be thankful it is all under warranty. Sweet ride, I like the color. Chrome rims on the horizon maybe? CCWs?
No big deal IMO. It is under warranty. Mine is one of the VIN's affected but no problems yet. If/when she does let loose I am praying it takes the motor with it. Then I get to start fresh!
Yeah - that is what we all want - our brand new car to fire a crankshaft pulley off, maybe take the engine with it, destroy the paint and hoodliner, and pray you get it fixed properly by the local GM dealer. If I owned one of these cars, I'd take it directly to the dealer today, and demand they fix the problem before the damn car stranded me. But that's just me!
Let's keep this in perspective guys as I've done a lot of research on this issue. We now have 13 confirmed cases of crank pulley failures:
(1) UBETRUN
(2) VIN5922.........5922
(3) N2DEEP
(4) EMTPRES.........8824
(5) RWSjr
(6) M_C6
(7) bangbgC6
(8) 3X2
(9) avvetteguy
(10) skfurr
(11) SHOOTER 49
(12) Datawiz
(13) VNAMVET
While we can't say we've captured all of them here, as of January there were 50 total cases out of about 11,000 cars in the affected VIN range according to a top GM exec. Even though there have likely been a handful more since then, that ain't a very high percentage (less than a half percent)! Also, there have been zero failures to VIN's below 3000 that we know of, so it appears that the problem may have started happening after VIN 3000 but our samples may be too small to tell.
Mike
(1) UBETRUN
(3) N2DEEP
(5) RWSjr
(6) M_C6
(7) bangbgC6
(8) 3X2
(9) avvetteguy
(10) skfurr
(11) SHOOTER 49
(12) Datawiz
(13) VNAMVET
Mike
Originally Posted by mikeyc6
While we can't say we've captured all of them here, as of January there were 50 total cases out of about 11,000 cars in the affected VIN range according to a top GM exec. Even though there have likely been a handful more since then, that ain't a very high percentage (less than a half percent)! Mike
Originally Posted by shopdog
1 in every 200 cars having a catastrophic failure is way too high a failure rate to be complacent about. That's combat odds. If all of the 98,000,000 small blocks produced by GM were made the way the LS2 is, there would have been nearly half a million failures. Anyone would call that a scandal. But fortunately, almost all small blocks keyed the dampener to the crank, and didn't have this problem. The LS2 failure rate represents a serious design error on the part of GM.
To me, the silly part is to suggest that people take their cars in and demand that Mr. BadWrench take apart the whole front end of their car to fix something that may never break. Give it another 6 months and by then, most people will have driven over 2,000 miles. At that time, if there are still occasional CP failures popping up at 4,000 miles, 5,000 miles and beyond, then it might make sense to try to convince a dealer to "fix" it, not before. If after 6 months we are seeing no new failures, it probably means that once you have past a certain mileage you are safe and there is no reason to have your local Chevy grease monkeys butcher your car.
My .02 as usual,
Mike
Loose crank bolt question
I wonder if the loose crank bolt could be done by an individual employee problem not torqing down the bolt properly? I would be interesting to see if it happened only on a certain individual's shift for a certain time limit or is it truly a component design problem?
But when it applies to only 11,000 of them of which only maybe 75 will fail in the worst case, it's hardly a "scandal"! Also, you have no way of knowing whether it is a design flaw, equipment malfunction, production problem, training issue (such as one of the workers not using the proper torque), etc. A lot of times, the design is fine; it's the implementation that falls short.
My .02 as usual,
Mike
My .02 as usual,
Mike
Mike, With all due respect, that's BS. In this day and age you should expect to be able to drive a new $50,000 car across the county in the dead of Winter or Summer, and not have to worry about throwing all the accessories off the front end of the engine. I wouldn't deem it acceptable being stuck in Gallop NM or Kingman AZ for three or four days while parts were obtained and the service was done.
If GM plays hardball with this issue, they have lost me, a longtime supporter who has owned 30 GM cars since I started driving. These 11,000 cars need to be brought in NOW. No excuses, no doubletalk about the low numbers involved. No steering wheel lock kind of evasions.
Loosing belts at speed is also a safety issue I intend to bring up to National Hiway Traffic Safety Administration.
I just may make advocating on this little issue my job for the Spring.
Originally Posted by tom4416
I think its time to start pressuring GM to provide a 5/100 warranty on any car suffering from the belt failure.
