LG Motorsports Long Tubes on C6: Any Results???
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
I would like to know anyones experiance with this system on the C6.
Install, Gains etc.
I have Corsa Sports now and would keep if they work well with this setup.
Any info will be appreciated
Install, Gains etc.
Cruise-In VI Veteran
St. Jude Donor '06
Originally Posted by G2Bobby
Here is the graph of Lou's C6 with the LG Pro Long Tubes Headers only.
St. Jude Donor '06
Originally Posted by jimman
That test was with 50 miles on car and no repeatability testing was done, to me very suspect.
Eccentric Member
When I get mine installed I will post the dyno results three ways:
Stock with Corsa Sports
Longtubes / pipes / Corsa's un-tuned
Tuned
I still have about a three week wait to recieve them (Borla's building them as fast as they can) and in that time LS2 EDIT will also be out. RevXtream (forum tuner in Tampa) will do the dyno and tuning for me.
Tuned
Originally Posted by JFTaylor
He may have gained a little as the rings seated but the #s are what stock C6s are running. Dynoed mine this past weekend. @7,100 mi 336HP & 339 TQ. It was cold and wet/rainy. Did get some wheel slippage on the first attempt. I agree is it somewhat suspect but not out of line.
I was just suspect with a 40 ftlb increase of which I haven't seen by anyone since. No one in this business seems to understand repeatability testing. Removing and doing all over again to insure that it isn't a fluke of equipment or tuning fubar.
Todd
I love Lou's headers, but if I'm not mistaken the chart above was with NO Catalytic converters. Someone correct me if I'm wrong.
Lou's headers, as well as Wheel-to-wheels, and the only true long tube headers on the market. The Kooks and TPIS headers are mid-length headers, and don't give you the mid-range that the longer primaries offer.
LG's headers are approx 12" longer before the primaries, and this design was originally done by GM racing and Wheel-to-wheel for the ASA and World Challenge race cars.
Dave
Dave
Originally Posted by WhiteDiamond
Yeah, LGM hasn't installed many sets of this same longtube header on C5s and routinely come up with well into the 30ft/lb of torque increase...Everything for you is suspect in this forum. Leave yours stock, you will never find the product you are looking for
Todd
Todd
St. Jude Donor '06
Sweet
Originally Posted by SteveL2
With the greater reduction of the C6 in emissions, then maybe it is possible to gain that kind of power by removing the cats? But, that's a take your own risk proposition.
Do the testing properly and I haven't have a problem. Incomplete and improper testing of a product a couple of years ago cost me 11 grand. It not only happened to me but several others, one also being from Texas. The so called experts never stood up and made it right. For example do you know how much effort was done on the arrow package for the C6. 420 hours in a wind chamber with a group of areo Engineers, thats what I'm talking about.
You again?
BTW - If your going to present yourself as some sort of expert on engineering or testing, at least learn to spell aero as in aerodynamics.
Mike Frey
BSAE
10500 Flying hours
Sim Instructor DC10 and B727
(just to let you know I DO have an engineering background)
Originally Posted by fdxpilot
You again?
Mike Frey
BSAE
10500 Flying hours
Mike Frey
BSAE
10500 Flying hours
As far as my expertise:
Professor of Engineering on the adjunct faculty for Seven Colleges
PHD in Solid State Physics.
48 years in the Electronic Engineering field
Head up the Application and Reliability Engineering Division of a 10 Billion-Dollar Company
Holder of a Patent in Thermal Dynamics, 1998
Borla Stingers and LG Long Tube Headers
Some feed back from LG - I've got the Borla Stingers with the X-pipe when I asked about adding their Borla long tube headers:
this is ###### with LGM. The cost of the new system with cats will probably be 1895. The Borla X-pipe on your car will not work with our system. We could modify your cat-back to work. I not sure what that would cost if it costs anything. We are getting our first test fit system some time early next month. I put you on the contact list so you will know as soon as we have them. Thanks
Being first is sometimes costly.......
Thanks for the spell check and typing analysis, being a secretary has not been my forte in life. If you have a problem with someone pushing back on some of the vendors that sell to us that’s your choice.
One of the problems I have personally witnessed many times with C5's is that the PCM will temporarily go lean after you install an intake or exhaust. So doing a before and after test without at least driving the car for 50 to 75 miles will show some impressive gains. But re-test after the PCM has had a chance to "lean" and adjust itself and a lot of the gain will be gone.
I saw a 20 RWHP gain with just the install of a BlackWing. Then a few months later my buddy went back to the same dyno to see what his newly installed Corsa Indy's (he has about 200 miles on the install) did and he was surprised to see NO GAIN. We suspect the 20 RWHP gain from switching the intakes while the car sat on the dyno was reduces to 10 or so and the Indy's added some back hence the zero gain.
If I had the $$ and time that's how I would show before and after numbers (absent LS1Edit tuning) else you will get "false positives".
And it's true many times vendors show their before/after numbers w/o the cats on the after. They say so but after a while all that is left are dyno sheets that don't tell the whole story. Not claiming there is anything suspecious going on, just a fact on forums like this. Dyno sheets (unless clearly marked) may be misinterpreted at a later date.
Tom
Tom
